586,052 active members*
3,953 visitors online*
    Jan 2017
    X axis vibration
    Hi. I have the Excitech E3-1325D. All-of-a-sudden, there is a low vibration/rumbling when moving the X-axis.
    This X-axis has 2 drives X and X1. Any ideas on the cause?
    Microstep adjustment? Anyone know this procedure?
    thanks...........dd
    update: while doing a small cut the machine shut down with error Servodrive X1 error
    also X1 position is 0.3mm different from X.
    Jun 2005
    1730
    Re: X axis vibration
    Check the bearings on that axis. Servo drive error could be caused by too much current due to the bearing not working correctly. You might have to disengage the drive motors and see if the axis moves easily, if it is rough that is the problem.
    Russ
    Jan 2017
    hi Russ. yes the x axis glides easily.
    However, in the process of checking the bearings, i found a loose electrical connector.
    then VOILA! success.
    thanks dude, that did the trick!
    my boss was blaming me, now we are back in production.....dd
  1. z axis vibration
    By turpija in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 05:49 PM
  2. In 'X Axis' Having vibration
    By dspjbp in forum DNC Problems and Solutions
    Last Post: 08-09-2012, 08:31 PM
  3. Okuma MA axis vibration
    By Green Button in forum Okuma
    Last Post: 09-19-2011, 02:30 PM
  4. cause of Z axis vibration
    By dahui in forum Shopmaster/Shoptask
    Last Post: 08-17-2007, 03:39 AM
  5. X axis vibration
    By harvard5 in forum Servo Motors / Drives
    Last Post: 08-15-2007, 02:07 AM
