586,096 active members*
3,012 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > All axis move one direction
Results 1 to 2 of 2
    Unhappy All axis move one direction
    I have stepper motor and breakout board , i had purchase it from china
    then when i connect it with PC , and mach3
    tried many time to move direction, but no way, it just move to one way
    i change every wire and double check it
    when i try to move motor to other direction
    i changed breakout board
    i changed PC ( For change parallel /port )
    i changed mach3 program
    tried every thing can , but no thing change
    Pls any one have any ideas
    be note am new in this
    Jun 2005
    1730
    Re: All axis move one direction
    Check the direction output, does it change from a Low to High or High to Low when you switch directions. You probably do not have the Port and Pin set correct for the direction output pin for each axis.
    Russ
  1. Replies: 1
    Last Post: 01-31-2015, 04:29 AM
  2. How to setup JOG control to move 2 axis with each direction key
    By MickPaul in forum Mach Wizards, Macros, & Addons
    Last Post: 06-29-2013, 12:06 PM
  3. Replies: 7
    Last Post: 01-22-2013, 07:14 PM
  4. x axis will only move 1 direction
    By brent48 in forum Stepper Motors / Drives
    Last Post: 11-09-2010, 06:25 PM
  5. x axis will only move one direction
    By CATCH22 in forum Mach Mill
    Last Post: 12-17-2007, 03:53 AM
