586,301 active members*
4,206 visitors online*
    Mar 2015
    70
    assessment of design and alignment
    Hi every one,
    well attached are some pics of my cnc router
    4' X 2'
    steel
    Bearings SBR16 LM UU Jinan Yuki
    All steppers NEMA23 2.2 Nm Changzhou Soya
    Dual Y 1:1 Fixed Screw Rotating Nut with HTD5M -25mm
    All Screw 1605-1 Start
    Z stroke 200mm
    1.5 kW Han qi spindle cooled with aluminum car heater core and centrifugal pump
    5 axis BoB sainsmart
    HP600B daisy chained 12VX3 power suppies for 37.5VDC, 24VDC, 12 VDC, 5 VDC
    Finder Control Relays
    Dell Optiplex Pentium 5
    Pentz cyclone DIY 3HP, blower, 6 inch flex
    Also attaching a video of Y axis . I decreased the size and it converted to mp4. mp4 cannot be uploaded. I had to rar it to upload. Please unrar it and please do have a close look.
    Fixed screw, rotating nut.
    I need feedback on the movement in the ball screw. is the alignment OK ? What effect will it have on Life of Ball Nut ?
    Or is it outright outrageous....
    Aug 2011
    999
    Re: assessment of design and alignment
    Probably not outrageous but surely better if you can fix that. I suspect that the support bearing axes for your rotating nut are not really parallel to the screw. Maybe you can shim it?
    The rotating screws of my machine are wobbling similarly due to imperfections of the (rigid) couplers but I have one end of the screw not in a bearing so the wobble does not stress it that much.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Mar 2015
    70
    Hi JerryBurks,
    Thanks for the feedback. I will do something more to make it more parallel.
    Thanks once again.
    Mar 2015
    70
    My dear friend,
    After some usage now a problem as follows has appeared.
    I want to understand something about ball nuts.
    there are 2 plastic rings on both sides of the ball nut. these rings are held by 2 very small screws. if i loose them and turn out the rings slightly the ball nut starts to wobble and also move along the axis on the screws by a small amount. If i turn the rings in and lock them with the screws the wobble or play is finished. I thought these were just wiper seals but it appears they have grooves matching threads and behave like a nut when rotated.
    Is this normal?
    Do i have now to replace the screw.
    Or do i need to replace the ball nut ?
    Or do I need to put in balls of a slightly larger size?
    What will be the next size of balls if needed?
    Best regards.
    May 2005
    3920
    Quote Originally Posted by shujaa View Post
    My dear friend,
    Is this normal?
    Best regards.
    You might want to post pics because I’m not following the description. Ball nuts vary in design so this might be a problem with the nut.
  1. Vertical Mill retrofit Project - Assessment of existing components
    By jwsigler in forum Vertical Mill, Lathe Project Log
    Last Post: 04-13-2016, 02:27 AM
  2. Freedom CNC Assessment
    By atownsend in forum Commercial CNC Wood Routers
    Last Post: 03-03-2016, 04:31 PM
  3. OMNI Passed Bureau Veritas Assessment
    By omnicnc in forum Chinese Machines
    Last Post: 03-12-2014, 07:52 AM
  4. Replies: 0
    Last Post: 05-14-2013, 03:23 PM
  5. Finding Engineering Design Software For Automatic Machine Design
    By hellokitty in forum Uncategorised CAM Discussion
    Last Post: 01-06-2008, 07:39 AM
