586,104 active members*
3,419 visitors online*
IndustryArena Forum > CAM Software > UG NX > NX automatic feed rate
Results 1 to 6 of 6
    Dec 2004
    83
    Hello NX users
    Is here anybody who actually uses NX automatic speed and feed library? Is there any tutorial or video how to define tools and speed and feed rates from tool maker database and use it automatically later in NX?
    Tim
    Dec 2004
    83
    Re: NX automatic feed rate
    Hi all
    I have struggled with good solution for automatic speed and feed settings for a milling operation already so long time. I had to do something about it. Luckily I have know coding so here is work of last months.
    To be frank NX solution for finding speeds and feeds from database is not good. Based on part material, tool material, method, tool dimension, and a cutting depth you cannot really find optimal speed and feeds. So I upgraded NX file that is looking for speed and feed parameters from database and added extra information to speed and feed database file. So now NX can to find automatically speed and feeds parameters depending on
    • Part material
    • Tool
    • Method
    • Cutting depth
    • Step over
    At the end I have always the optimum cutting parameters for operation.
    I’ll do presentation and video about this and shall share the link. But if you have any questions you can write to me directly [email protected]
    Aug 2008
    71
    The basic difference is that you are using cut depth and stepover as inputs. In NX these are optional outputs from the machining data.
    Good to know you were able to find a solution by customization.
    Mark Rief
    Siemens PLM
    Dec 2004
    83
    Here is the video link that I promised.
    https://youtu.be/dzKRF72uO3M
    Share and leave comments.
    Dec 2004
    83
    I have been asked about benefits of new method defining NX CAM spindle speed and feed automatically. Here is a little presentation where two methods of defining automatically spindle speed and feed are compared. On the same part two options of defining cutting data were used and machining data as a result was compared.
    Enjoy, and comment what You think.
    Dec 2004
    83
    New video.
    Automatic spindle speed and feedrate definition by cut depth and stepover that is set by programmer.
    Enjoy.
    https://youtu.be/0OP7ueF7IvY
  1. feed rate and plunge rate help required please
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 12-07-2015, 09:30 AM
  2. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  3. Feed rate for 5/8-18 tap
    By Eagle View in forum MetalWork Discussion
    Last Post: 09-24-2008, 03:25 PM
  4. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  5. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
