machdrives.com announces the release of the new BRC series servo drive. This is our third new servo drive model for 2017, and is a low cost open frame design.
Rated at 20-150VDC input and 20A output, it is ideal for CNC mills, routers, lathes and plasma cutters. List price is AUD $199
Download BRC User Manual
While there are several other similar offerings in the market, the Machdrives BRC servo has some important differentiating features..
- Lower heat generation. The combination of a switching regulator, power saving mode and an efficient MOSFET bridge means the drive can be screwed directly to the control cabinet wall in many applications, without requiring an additional heatsink.
- More accurate tracking. Extending the traditional PID control with velocity feedforward, acceleration feedforward and stiction compensation eliminates tracking errors normally present on starting and acceleration.
- Easier setup and tuning. Connection with a standard USB cable to the free Tuna for Windows application means easy setup without an oscilloscope. The 14 LED indicators show all signal and I/O pin status to streamline commissioning and troubleshooting.
- 20-150VDC 20A brushed DC servo drive.
- Step/Dir input compatible with Mach3.
- Low cost open frame design.
- High efficiency. Minimal heatsinking required.
- 14 LED indicators for easy setup and diagnostics.
- Configure with standard mini-B USB cable.
- Easy tuning with free Tuna™ software for Windows.
- Latest control algorithms. Dual 32bit ARM CPUs.
- Smooth silent operation. No dithering.
- Voltage, current and temperature alarms.
- High noise immunity with isolated control circuitry.
- Designed and manufactured in Australia.
