586,545 active members*
3,241 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > deburring/ rounded edge suggestions?
    Sep 2014
    147
    hey guys, I am laser cutting fairly small (about 1" - 3" ) complex shapes on a 700 watt fiber laser in 16 gauge polished stainless( mirror finish)...the complexity is similar to large jewelry or like belt buckle size..anyway, I have a customer requesting that the pieces have a smooth rounded edge as opposed to the sharp edges that the laser cutter creates and has provided samples from china that are indeed smooth and slightly rounded.
    What post laser cutting process will do this for me while maintaining a mirror finish? All I can think of is vibratory tumbler but that's gotta take forever and require like 5 separate medias...any process you guys suggest where I can get the edges less sharp and even slightly rounded while keeping or re obtaining the mirror finish?
    I do not currently tumble so I don't even know what medias to try.
    All ideas are appreciated. the shapes are complex and small with both inner and outer laser cut edges so I cant just debur with a wire wheel
    Nov 2007
    479
    Re: deburring/ rounded edge suggestions?
    look into electropolishing.
    Sep 2014
    147
    I need very round edges, not sure that can do it.... can it?
    Nov 2007
    479
    Quote Originally Posted by manakawari View Post
    no, but you round the edges with say a buffing wheel then experiment with electropolishing to shine up the edge.
  1. Deburring edge of sheet aluminum
    By Jim27 in forum MetalWork Discussion
    Last Post: 02-19-2017, 07:37 PM
  2. Making a rounded logo
    By Razer in forum BobCad-Cam
    Last Post: 09-09-2012, 10:25 PM
  3. rounded corners when pcb milling
    By jpm000001 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-09-2012, 08:38 PM
  4. rounded corners
    By jc286006 in forum Uncategorised CAM Discussion
    Last Post: 06-25-2006, 06:04 PM
  5. Rounded corners...
    By saturnnights in forum SheetCam
    Last Post: 02-13-2006, 08:06 PM
