586,546 active members*
3,295 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Nov 2013
    12
    HELP - Blowing Fuses & melting Switches
    I have a couple of the red 60W 500x70mm machines and both of them have been blowing fuses.
    The first unit melted an e-stop switch and then started to blow fuses to the point the machine won't do more than power up and blow a fuse.
    Our second machine seems to have melted the main power switch and is also blowing fuses.
    Any pointers would be great!
    Tim
    Mar 2007
    2083
    Re: HELP - Blowing Fuses & melting Switches
    Hi Tim
    going by the poor quality the connectors use in my "mini lathe" resulting in high resistance connections
    its possible the E-stop & power switch was damaged by the heat from poor connections
    do the switch wires show signs of head damage ??
    the question is did faulty e-stop switch & power switch cause damage to the laser cutters power supplies and / or laser power supplies ??
    or the over current taken by a faulty power supplies and / or laser power supply damage the switches ??
    I would replace the damaged switch & blown fuse then disconnect the mains supply from the laser power supply
    and then test the controls power supply on its own
    depending on the result ,then test the laser tubes power supply on its own
    John
    Nov 2013
    12
    The e-stop on one machine was the first to show heat damage and I replaced it.
    I have the main power switch on both machines show signed of heat damage.
    Any good places to get better quality switches from?
    Tim
    Mar 2007
    2083
    Hi Tim
    living in the UK I would start with
    Farnell element14 UK - Electronic Components Distributor
    RS Components | Electronic and Electrical Components
    but I assume your in USA so try
    https://www.digikey.com/
    Mouser Electronics - Electronic Components Distributor
    from the likes of E-bay its not easy to know how good spare parts will be - they may be as bad as the suspect ones fitted to your machine
    John
    Nov 2013
    12
    The main power switch I have not looks more like the e-stop linked below but both sides are green. Is that NO/NO or NC/NC?
    Emergency Push Button Switch with lock
    Jan 2017
    Hey, I got a 60W Chinese laser in January and I had the same issue. I thought I posted in this forum, but I can't find it.
    Here is what I found after 1) Melting the main switch, 2) Melting the E-Stop swtich, and 3) Blowing a fuse and melting the fuse holder.
    The #1 tip I can give you is to make sure you are NOT running your exhaust fan or air assist pump from the AC outlets on the back of the machine.
    The exhaust fan that was included with my machine was rated at something like 6A or 550W--all of this power has to go through the main fuse if you use the outlet on the back of the machine. This really only leaves about 4A to power the laser, and if you have to use over 70% power or are running a long cutting job, it can melt switches (thats what happend to me.) The power plug on my fan was not a US style plug, so I had to cut and replace the end to make the switch (found a replacement extension cable plug at a local hardware store).
    Double-check the rating on your main fuse. The ones that came with the machine were rated for 250v/10A, which will not reliably blow at 10A at 120V; this is probably why the switches are melting first (Also 10A rated)
    In getting my machine back up and running, I replaced the main power switch with a 20A metal toggle switch. It is overkill, but it works great. The fuse should blow first anyway. The E-Stop should have a red contact block, the main switch a green contact block. The only real difference (aside from the style of switch) is the E-Stop is normally closed, and the Main Power is normally open.
    My new setup has the Laser Cutter, Air Pump, Water Pump, Water Chiller and Exhaust Fan all running on their own outlet on a shared surge protector (nothing on the back of the laser)--I've had no power issues since.
    Jun 2014
    611
    Quote Originally Posted by TimAustinTX View Post
    Tim
    Just replacement them..or add a breaker, it is safer.
    Aug 2006
    16
    Quote Originally Posted by Nolan Yang View Post
    I disagree, circuit breakers are slower to react and are too easy to simply reset after they have tripped, assuming circuit breaker and fuse are correct rating for the load.
    A fuse requires some checking of the circuit before replacing (assuming someone doesn't want to just blow another fuse), I've seen my share of circuit breakers simply reset into a short circuit resulting in arc flash and further equipment damage.
    Fuses are faster to clear a fault resulting in safer operation and typically less damage to equipment.
    Ceramic fuses with a correct load rating and fault clearance rating should be used.
    Jun 2014
    611
    The "best solution" is just replace, and when it happens again, and replace it again..
    However, if you don't want to replace it often, I think breaker is an options, but don't reset it right away when it breaks.
    Feb 2014
    187
    Sorry to disagree but but a fuse that blows or a breaker that pops is telling you something is wrong i.e. not right!
    The correct action would be to investigate what is pulling more current than the circuit is designed for then replace, rewire, or redesign the circuit.
    Fuses and breakers should never go in a correctly functioning circuit.
    Jun 2014
    611
    Um..you're right. I just share a lazy solution..
    Feb 2014
    187
    No worries
    I only mentioned it as these machines get put in the home etc and keeping on flicking a breaker or fitting fuses usually leads to overheating which can lead to fires etc.
    Much better to fix the problem and be safe.
    Jul 2016
    12
    This is a similar issue as we are having on our dual laser. Any additional input would be really helpful. This has melted twice in the past week.. Just want to make sure we are making the correct moves.
    Mar 2007
    2083
    going by your photo
    Attachment 377438
    it looks like it could either be due to faulty riveting of the joint between the metal strap & the fuse clip or
    a poor connection between the fuse and connector - possibly due to the fuse being under size or the connector not providing enough contact pressure ,
    very often the fuse holder can be damaged when a glass fuse is blown by a large fault current
    with a 20mm glass fuse not only does the glass tube explode but the copper fuse wire is vaporised ,
    coating the inside of the fuse holder with a conductive film of copper
    a HRC Fuse (High Rupture Capacity Fuse ) should be used as the ceramic tube contains the explosion if you short circuit the mains supply
    the sand filling quenches the arc
    John
    Jul 2016
    12
    Thanks John! I will give the ceramic fuses a shot!
    Nov 2008
    110
    Quote Originally Posted by VimCommando View Post
    Hmmm as far i know 250v/10A fuses should reliably blow at 10amps /120v (or even 12v ). 250V ratings means that you can use them on 250V mains - they should not "hold" arc after blowing. Automotive fuses cannot be used in 250V (or 120v) mains since they are rated for lower voltage.
    I think "melting switches" problem has more to do with the fact that switch is rated for the same amperage as fuse - which sounds ratcher... echem... interesting choice. Probably components chosen by "use the cheapest" method
    Wysłane z mojego GT-N7100 przy użyciu Tapatalka
    Dec 2003
    24223
    Sounds to me as the machine is miss-wired somehow, probably done for cheapness, an E-Stop circuit traditionally does not carry high current, it is often just a control relay that in turn removes coil voltage etc from contactor coils and other power controlling devices.
    If these machines or any that are of Chinese origin, the wiring has not always conformed to NFPA79/NEC/CEC.!
    Al.
    Albert E.
    Jul 2016
    12
    So while we have been waiting on the ceramic fuses (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1), we replaced the receptacle and put in another glass fuse. This morning that one melted as well. I dissected the last one that melted and it appeared that the glass on the fuse broke, but the wire did not pop. Conversely, the melted outlet this morning had no broken glass, but a popped fuse wire. Keep in mind that this has only started happening in the past few weeks and has happened two separate times on two separate machines. Really the only thing I can think of is it has to be garbage fuses. Maybe I'm using the wrong fuses all together? I am using 10A 5x20mm (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). So, so frustrating.
    Dec 2003
    24223
    That type of fuse is seldom seen in industrial machinery, especially for power circuits, it would pay to replace with industrial style such as CC or similar type fuses, and suitable fuse holder.
    Al.
    Albert E.
    Jul 2016
    12
    Well, tried the ceramic fuses and we are still melting. However, the ceramic fuse did not seem to pop. So for some reason, there is so much heat going into the plug it is melting without popping the fuse. Also, this is happening on two different dual laser and started happening around the same time with both. What the bloody hell? I could always get a metal plug inlet, but I don't think that would really be solving the issue.
Page 1 of 2 12
  1. Blowing Fuses?
    By TimAustinTX in forum Redsail Laser
    Last Post: 04-13-2017, 07:11 AM
  2. Keep blowing fuses
    By bujaman in forum Maintenance DIY Discussion
    Last Post: 01-29-2014, 07:26 PM
  3. Blowing 20a fuses!
    By fgwilson99 in forum Community Club House
    Last Post: 04-28-2011, 02:13 AM
  4. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
