586,835 active members*
2,564 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Problem making paths in Freemill (Visual Mill)
Threaded View
    Dec 2016
    134
    Hello.
    I'm trying to make g-code using Freemill on a step-file.
    I've made the step-file in FreeCAD.
    Step 1: I load the file into Freemill.
    Step 2: Z is upwards so the coordinate system is ok.
    Step 3: I'm not interested in the boundaries at this time, only the pocket in the middle so I set 0 offset.
    Step 4: The pocket is 20mm deep so a 30mm flute tool should be ok?
    Step 5: I guess the speeds really don't matter at this point as this is just to generate the path.
    Step 6: Toolpath display. Stepover is 1mm in horizontal direction, but in Z direction it takes all in one cut. How can I change this?
    Step 7: I can't see anything useful here, can you?
    Step 8: Loaded the output file into UCCNC to see how it turned out.
    Is it possible to make this work in Freemill?
    If not, are there some free CAM programs that can do things like this?
    Attached Files Attached Files
  1. Visual Cam 1.0/visual mill 6.0 5 axis?
    By Swets in forum Visual Mill
    Last Post: 03-05-2017, 10:32 PM
  2. Visual Mill 6.0
    By ibrich in forum Visual Mill
    Last Post: 08-14-2014, 09:48 PM
  3. Visual mill accuracy problem
    By JackWilliam in forum Uncategorised CAM Discussion
    Last Post: 04-25-2013, 07:54 PM
  4. Problem with 3d paths for cutting
    By vinot in forum Composites, Exotic Metals etc
    Last Post: 12-01-2008, 04:44 AM
  5. Visual mill
    By merritt boyd in forum Mach Software (ArtSoft software)
    Last Post: 06-30-2007, 11:24 PM
