586,036 active members*
4,277 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > DIY spring loaded engraving tool holder
Page 1 of 2 12
Results 1 to 20 of 40
    Jul 2005
    409
    Thank you for the new forum!
    Does anyone have plans or pictures of a spring loaded tool holder?
    Who has used one, and how well do they work? I have seen pictures of one that had a plastic collar on the end but I would think that would marr or scratch the work.
    Thank you for any help.
    Cutmore
    Sep 2006
    104
    Jul 2005
    409
    Counzero,
    Thank you,That is exactly what I was looking for!
    Have you seen any plans or drawings for one of these? I guess I could stop being lazy & just make 1 now that I have seen the 2 linc pictures. Better to make exactly what you want than buy what someone else offers right?
    Regards,
    Cutmore
    Sep 2006
    104
    Yoy could try contacting the guy that made it, I have not seen any other DIY tools for this.
    Jul 2005
    409
    Thank you for the idea Countzero,
    I have pm'ed the creator, Will wait to hear from him. Hopefully I can make 1 and will post pictures of what I make.
    Cutmore
    Jan 2007
    634
    That is awesome. It looks like both would be easy to make. I have a Taig spindle (hollow lathe type) on my mill so it is very possible to also make one that has the telescoping spring section on the rear so that it sits up inside the bearing block when mounted. This way the bit doesn't protrude any farther than normal and keeps the TIR down.
    Glad to see the basic concept is proven. I hate starting from first principles. I made my first test piece tonight using that hobby store brass model tubing and rod I had laying about, just brazed together and using the spring from a disposable lighter. Fragile as hell and unusable for real work, but surprisingly it did quite well for a mock-up, and using an old chipped 1/8" shank 80 degree half-round vee bit I engraved a pretty decent test piece. Now on to turning a more solid one from stainless stock tomorrow!
    I still would like to see how the gun manufacturers do it with the scanning probe moving just ahead of the bit. Easy to setup physically, but the software to alter the G-code for Z in the look-ahead buffer in real-time would be a nightmare chore to code for anyone who doesn't already work in that field and have source code for something like Mach or DeskCNC.
    May 2004
    350
    All you need to make one is a piece of steel and an old Dremel tool
    Hurm do you think I could sell these?
    And what would be a fair price?
    I found my first prototype I will try to get some pictures of it disassimbled tonight.
    Jul 2005
    409
    Aksess,
    I think you could sell these, Probably not like hotcakes but I think they would sell. I started mine the other night from your info, Thank you.
    In order to guestimate price, Look at the price of the commercially available ones, Determine your time & materials to make one and then you can see if you can sell it for less than the commercially sold ones.
    You could start a poll to see how much people would pay here on the zone too and that might help you.
    I would pay $100-$150 for one that was ready to go, If I had not started to build 1 that is.
    My .02c
    Cutmore
    Jul 2006
    50
    Just checking to see if anyone has completed the tool holder and if so, how does it work. Please post pictures.
    thanks
    May 2004
    350
    Sorry it took so long. I have a photo that will make it easier for you to construct one. This was my first prototype the plans can be improved on.
    Jul 2006
    50
    Aksess, thanks for the picture. I can understand how it works now. Seems very simple. That was some good thinking on your part. I am going to have to give one a try.
    thanks
    May 2004
    350
    You are welcome. Now get buisy and build one.:cheers:
    Sep 2004
    222
    I built one a few years ago. It works great!!
    Mar 2008
    Alternatives to 2linc. spring loaded tool holder
    Need to know if someone knows of another alternative to 2Linc's spring loaded tool holder which is a little pricey for at this moment. I did find someone on this forum who made his own and I'm waiting for his reply. I need the holder for engraving aluminum for trophy plaques.
    Oct 2005
    28
    There's not much to them. This one I built not too long ago. It holds 1/8 " solid carbide engraving cutters. The tension on the cutter can be adjusted. I have found through use that you do not need much tension on the cutter.
    Attached Thumbnails Attached Thumbnails engraving holder 003.jpg   engraving holder 004.jpg
    Jun 2004
    33
    Red face
    just asking
    Are these to be used on a router , if so
    can someone make one or two for me ?
    would like to buy
    May 2004
    350
    Just currious. How much would someone pay me to make them one?
    Sep 2007
    56
    Self made
    I saw linc's high price a few years ago when I priced one.
    I ended up making my own. 1/2 shank, beefy body so I can
    change out to any spring. <I engrave on ss and alum>
    I will post some pics tomorrow.
    I built like 5...planning on selling others on ebay. Got busy and never
    followed thru.
    Swain
    Follow up..
    Never tried to post an image here. It asked me for the url of the image?
    No attach button like email? Anyone explain this to me?
    If I can get image thing figured out, I will post pics.
    322
    Quote Originally Posted by Aksess View Post
    I would guess you could get $75 to $125 probably. The best way to find out would be to make a couple and offer them for sale.
    1/4" shank would be best for me, but 3/8" would probably be OK. The tools would be 1/8" shank - either carbide or diamond.
    -James
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
    322
    Quote Originally Posted by swain View Post
    followed thru.
    Swain
    Follow up..
    Put your images on photobucket then put the URL to that page here.
    -James
Page 1 of 2 12
  1. Spring Loaded Engraving Tool Holder
    By GeorgeRace in forum Engraving Machines
    Last Post: 08-26-2013, 12:08 PM
  2. Spring loaded engraving tool?
    By phatjap in forum Want To Buy...Need help!
    Last Post: 04-20-2010, 06:12 PM
  3. Anyone use a spring-loaded engraving tool?
    By laka in forum MetalWork Discussion
    Last Post: 01-08-2009, 05:09 AM
  4. Is anyone willing to make me a spring loaded tool holder?
    By meisje08 in forum Engraving Machines
    Last Post: 04-17-2008, 04:04 PM
  5. Spring Loaded Engraving Tool
    By djh82uk in forum MetalWork Discussion
    Last Post: 01-11-2008, 05:35 AM
