586,075 active members*
3,937 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Spindle starts in windows explorer
    Feb 2007
    25
    When I am in windows explore and I click on something my spindle starts up. How do I fix this.
    Jun 2005
    260
    If you are saying that you CNC setup is starting when it's not suppose to, it sounds like a serious safety issue.
    I would unhook/unplug your machine while you are not using it, and be careful if you do, until the issue is fixed.
    You might want to describe your machine, setup, software, and drivers so that someone might help you.
    Jun 2005
    866
    I agree, that is a safety hazard. The power to your spindle is controlled by a relay I assume? Get an E stop on there.
    Feb 2007
    25
    I have a TL511dn Bench top vertical mill with a DSPservo 511 and I am running Mach 3. I do understand the safty issue. But what can I do to fix this problem.
    Feb 2007
    424
    Quote Originally Posted by cut2spec View Post
    Someone was just asking about this unit the other day looks rather homemade, I cannot believe someone would sell that without a e-stop. Ideally the e-stop should disconnect all power(electrical, air, flywheels and hydraulic) to anything which may provide energized motion. It says that it uses digital signal processing from what I understand that relies on a PID. I use PID controllers for heating process control they get wacked out sometimes if they are left on but the gas is turned off, the unit will have a hard time comepensating for a short term once it is restored. I would imagine that it is not used on the spindle control as that would most likely be a PWM of some sort or other as it says its infinetly variable. Could also be the paralell port acting up, I know that certain makes of computers don't give a full 5 volts to the parallel card, also I know that the new IE tends to stress my computers out more, maybe you are having a PSU issue with computer causeing a breif glitch.
    my thoughts at least.
    Chris
  1. Hyudai starts in metric
    By Jedi in forum Uncategorised MetalWorking Machines
    Last Post: 10-18-2006, 01:23 AM
  2. back button on explorer
    By trubleshtr in forum Computers / Desktops / Networking
    Last Post: 10-13-2005, 12:52 AM
  3. Bridgeport Explorer CNCs
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2005, 01:28 AM
  4. Starts
    By AZCoyote in forum Waterjet General Topics
    Last Post: 01-21-2005, 12:33 AM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
