Originally Posted by
mactec54
PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
PD001=0 (1 For Remote Control)
PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
( J1 Also Needs to be set for Terminal Control )
PD003=300
PD004=300
PD005=300
PD006=90
PD007=20
PD008=220
PD009=66
PD010=15
PD011=120 ( This may need to have a higher Minimum Speed for your Spindle watch Temperature )
PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
PD014=10 ( Acceleration Adjust to suit)
PD015=10 (Deceleration Adjust to suit)
PD141=220 ( Motor Rated Voltage )
PD142=9 ( Motor Max Amps)
PD143=2 ( Motor Number of Poles)
PD144=3000 (Max Motor RPM 18,000)
PD070=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
PD072=300
PD073=120 ( This may need to have a higher Minimum Speed for your Spindle watch Temperature )
PD120=120 (Stall Prevention )
PD174=13 ( Your VFD Drives Max Amp Output Rating )
If Minimum Speed is changed then other Parameters will need to be changed also, Your Minimum Speed is related to the temperature of your Spindle to low and it will over heat
