586,075 active members*
4,167 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > How to operate the Richauto DSP A15 and DSP A18? Hope to help you :)
Results 1 to 11 of 11
    Nov 2011
    261
    DSP A15 control system to operate to pneumatic system cnc router:
    https://www.youtube.com/watch?v=XfzMmp2yh-w&t=320s
    How to set up DSP A18 for ratory device:
    https://www.youtube.com/watch?v=Fp3MrzzPhMc
    How to set up DSP A18 to zero:
    https://www.youtube.com/watch?v=vSF0...ature=youtu.be
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    Nov 2011
    261
    Re: How to operate the Richauto DSP A15 and DSP A18? Hope to help you :)
    Guidelines for DSP Handle Using
    Maybe you have been using the handle for a long time, but do you really understand its power? Here are a few useful guidelines for using it.
    1. Error
    The machine coordinates are currently displayed. The workpiece origin cannot be set. Please switch to the workpiece coordinate system setting. The interface display example is as follows?
    Nov 2011
    261
    Cause: The customer misoperation (MENU+0) entered the machine coordinate system, and the origin of the workpiece cannot be set in the machine coordinate system. So when the customer tries to set the origin of the workpiece, the alarm will appear like the picture showed.
    Nov 2011
    261
    Take the DSP A11 for example:
    Attachment 396748
    MENU+ 1/2/3/……/9/0. It is used for switching the coordinate system. A11 has a total of 10 coordinate systems that can be used. While, MENU+0 is switched to the table coordinate system of the machine. The normal panel displays as follows:
    Attachment 396750
    In that case, this is coordinate system 1 (or G54 coordinate system).
    (this is coordinate system 9)
    Solution: MENU +1, switch to coordinate system 1.
    Nov 2011
    261
    2. U Disk Mode
    A lot of raw materials need to be processed at one time, but the U disk file cannot read the date. In the same time, the technician asked for leave. In this case, you don’t need to be in panic. You can use this feature to solve the problem by yourself. Three Solution for your reference.
    The following two ways should be firstly used when the problem happened.
    Inner Format: MENU?SYSTEM SETUP? Inner Format
    Wipe Cache: MENU?SYSTEM SETUP? Wipe Cache
    If the above solution doesn’t solve the problem effectively, only the third can be tried.
    Use computer format DSP handle
    Keep pressing the key “OK+MODE”, and don’t release it.
    Use a USB cable to connect DSP handle to the computer. When the screen prompts the USB disk mode, release your hand.
    Attachment 396822
    In “My Computer”, you will see a drive letter similar to the one inserted in the U disk. A0242740(i is just like DSP handle. You can use the file like a USB disk. Copy to the inside of the system for processing.
    Nov 2011
    261
    3. Machine pulse settings
    Take normal 3 axis, DSP A11 for instance.
    And the step following like this: MENU?MACHINE SETUP? Pulse Equiv
    Attachment 397386
    Nov 2011
    261
    4.Advanced Processing
    There is an option in advanced processing —line processing.
    Select the line selection process first; Then, move the spindle near the position you want to process, and the machine will start processing from that line.
    Nov 2011
    261
    5.Back to home not success
    When customers have problems in processing, please first look at whether the machine Back to home successfully or not.
    Like the picture, it means back to home not success.
    Like the following picture, it means back to home success.
    Nov 2011
    261
    Solutions just as following:
    Press “HOME 9” , then, you will see as the image show. Select “Home all”, then, press “ORIGIN OK”. After finish the above steps, the machine will back to home automatically.
    Attachment 398426
    Press “HOME 9”. If the machine has an action and back to home successfully. It means the machine is fault-free.
    Press “HOME 9”. If the machine has an action but back to home not successfully. In that case, you should check the limit switch for each axis.
    Nov 2011
    261
    6.DSP handle spindle cannot work
    Please check the screen
    Attachment 398504
    Attachment 398506
    If the screen show S1 or F1 , the spindle will not work. You can do like this:
    Attachment 398508
    Attachment 398510
    Attachment 398514
    Nov 2011
    261
    DSP A18 Parameters Set
    MACHINE SET UP
    Attachment 398746
    Pulse Equiv
    Attachment 398748
    Attachment 398750
    Table Size
    Take ELECNC-1325 with rotary for example
    Attachment 398752
  1. How to operate a CNC mill...
    By Joe.B in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2011, 06:56 PM
  2. CNC Set-up/Operate - Cleveland
    By r3juvin8 in forum Employment Opportunity
    Last Post: 01-17-2008, 08:26 PM
  3. Anyone Operate Taig using E.M.C.?
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 12-04-2007, 11:43 PM
  4. How to operate a Citizen FL-42
    By Twistr in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2006, 12:23 AM
