Re: Feeds and Speeds, which app do you use?
Originally Posted by
coffeetek
What do you guys use as references for feeds and speeds for slant lathe? I have been trying both GWizard and HSMAdvisor and from some little tests I did they both are way too aggressive. HSMAdvisor works great for me on 440, but everything I have tried for lathe is so aggressive that I have to take the water down numbers so much that tool becomes worthless...
You need to specify turning body size properly. This would give you lower cutting depth. Also important thing to remember is that HSMAdvisor is set up for performance. and when a nice finish is required you need to take it down to 30% Feed sometimes. For finishing often rule of thumb like 0.002 ipr work best.
Other than that it is supposed to give you middle of the road production style values and you have to account for that by setting proper machine profile and using overrides when needed.
http://zero-divide.net
FSWizard:Advanced Feeds and Speeds Calculator
