586,475 active members*
3,342 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Gerber > Gerber Sabre 408 & Push Through letters
    Mar 2017
    Hello I am a new cnc user and a longtime sign maker and I wanted to know if there is any kind of tutorial on how to setup files for push through acrylic. I am working in adode Illustrator for designing and have Artpath for my router. I also have Omega but i am not familiar with this program. What i would like to know is how to setup a file so that the sharp corners fit into push through. I have created one job in the past but I rounded all of the sharp edges so they would fit into the shape from the bit i was using. What i would like to know if there is a easier way of doing this instead of me designing each one by hand? Please if you could point me in the right direction that would be great
    Scott
    Mar 2017
    Re: Gerber Sabre 408 & Push Through letters
    Hello
    I am an Engraver in eastern CT I have been happily running a Dimension 200 router with a high speed precision spindle for 20 plus years I do a lot of work in Omega when I want to do fit together shapes (if I understand correctly) in composer (plt) I select the shape completely go to tools and select fillet corners plug in the radius slightly larger than the cutter .001-.002 select outside corners and apply or ok then go to artpath and cut out in a male path. this is for the inner piece. Barry, Finest Engraving LLC
    - - - Updated - - -
    Hello
    Jan 2020
    buen dia
    si lo hay una forma mas rapida
  1. Gerber Sabre 408 help...
    By crackstar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2018, 01:29 PM
  2. Gerber Sabre 408
    By bulld101 in forum Gerber
    Last Post: 05-04-2016, 10:20 PM
  3. gerber sabre 408
    By nipon in forum Community Club House
    Last Post: 11-10-2013, 07:03 AM
  4. Evaluating a Gerber Sabre
    By ToolslingerNJ in forum Want To Buy...Need help!
    Last Post: 05-22-2011, 02:51 AM
  5. Gerber Sabre 408
    By Pasty in forum Want To Buy...Need help!
    Last Post: 07-21-2008, 03:52 PM
