586,655 active members*
3,844 visitors online*
Results 1 to 8 of 8
    Oct 2013
    4
    RDC6442G & RDWorks - Max speed limitation
    Hello,
    I just converted my laser to a RDC6442G controller and have everything working. The problem I'm having is although I set the max speed of the X and Y to 800mm/s in RDWorks v8 (and confirmed it on the machine by reading back the settings), when I engrave the controller is setting my speed to 200mm/s.
    I'm struggling to figure out where this limitation is coming from.
    Any suggestions would be appreciated.
    Dave
    Sep 2011
    60
    Re: RDC6442G & RDWorks - Max speed limitation
    I read the specs on the RDC6442G controller, are you exceeding the 500 KHz of the controller?
    How many pulses does your motor take to travel 800 mm? If it is over 500,000, it will never let you go that fast.
    James L
    Quote Originally Posted by weitzd View Post
    Hello,
    Dave
    Oct 2013
    4
    Hello James,
    My step length is 4.8um on both the X and the Y. If I do that math right, I should be able to go 2400mm at 500kHz.
    I'm actually asking for a speed of 450mm/s in the job, but it is getting knocked down to 200mm/s
    Dave
    Anyone needs IKO, NSK, THK, TBI, CPC, PMI, CSK, STAF, ABBA, HIWIN, SCHNEEBERGER linear guides ball screws supplier/exporter
    Here I am.
    And I can help send goods to your office via DHL/TNT/UPS/FedEx, etc.
    Regards,
    Andy Lee
    :cheers:
    Sep 2011
    60
    Dave,
    Do you have any other drivers or are the motors directly wired to the controller? I don't know your setup, so I'm working from the strict math.
    Also looking at the RDWorks manual, it could also be a setting in your configuration that limits you.
    Not sure at this point.
    I can't really help further without knowing all the components involved.
    James L
    Hello James,
    Dave
    Oct 2013
    4
    Hello James,
    The controller is connected to seperate drivers, one each for the X, Y and Z. They haven't changed, I'm only changing the controller from a 6515/lasercut setup to a 6442/rdworks set-up.
    I believe it's either something I'm missing in the configuration in RDWorks, or there is a hard limitation on the controller board that I need to figure out how to modify.
    On the RDWorks side, I am setting the max speed in the vendor tools configuration section. I don't know if there is any place else to set this.
    Dave
    Hi guys
    I am IKO, NSK, THK, CPC, TBI, CSK, PMI, STAF, ABBA, HIWIN, SCHNEEBERGER linear guides ball screws exporter/supplier
    We can help send goods door to door via DHL/TNT/UPS/FedEx, etc
    Sep 2011
    60
    Hello Dave,
    Sorry, I really do not know at this point. Maybe someone familiar with the laser will chine in, and be able to help.
    James L
  1. Information about RuiDa RDC6442G
    By Labmaster in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-15-2020, 06:56 PM
  2. U Axis on a RDC6442G
    Last Post: 12-28-2018, 12:20 PM
  3. Ruida RDC6442G problem
    By sanyyos in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-24-2017, 08:01 AM
  4. How do I re-program RDC6442G (50w Chinese laser)
    By Moraykidz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-09-2016, 08:27 PM
  5. Speed Limitation of Traditional Slideway??
    By Shooter7 in forum Linear and Rotary Motion
    Last Post: 10-14-2011, 08:35 PM
