I see all these big racks and stand up workstations in big shop areas!.
I work in small slot with everything right there. All I do is pre cut a pile of stock for the parts I plan to make and set in tray on or next to fixture table -tool box on right. That is where I fixture all stock and set and measure tool offsets and machining results. All tools used in programs I place in order along the bottom row of all those trays where the control puck, keyboard and PP display is stationed . foot pedal is on floor between that and pcnc1100 on left. With convenient air for blowing of chips and brushes I can and did set and make all the parts in the below picture with out standing up once
lazy im besides my left foot has been hurting for a while now. Tv is on exact same monitor pivot mounted on the other side of shop. I can turn around and watch tv while long machine ops are going or fixture more material in extra fixtures and collets.
Easy simple its even at eye level so setting offsets is fast. Edit: With path pilot these days and using a 5c collet system You can make piles of small parts. Just turn on machine home it. midi g01 f50 x0 y0 witch is g54 in preset offset page and centered over 5c collet in vice. Then I just set to tool #9 a 1/2 carbide endmill. load program midi m3 run cutter down to stock. touch it mill off top and zero z. m5 run up look at program load first tool on bottom of rack. and run. I dont even use the expensive Hamier probe on the rack or jog around and find anything. easy fast in my case. Just a method I use everyone works differently. Simple enough that I can get up and make a part anytime I want to in very little time
Attachment 358318
Simple parts
Attachment 358320
Having big work spaces is not always that better.
Attachment 358322
I noted in another thread about rubber floor mats they were for the rest of my shop
