586,114 active members*
3,144 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Feb 2008
    216
    Automatic Tool Change C Code
    Hi Tom,
    We are trying to write the C Code for the tool change so that we can send a video of it doing everything.
    When I compile and run the Automatic Tool Change Example from the Dynomotion Wiki the console screen shows an error: "Unable to open/read file:c:\Temp\ToolChangerData.txt"
    Is this going to impact the program? How do I correct this error? I'm running windows 10.
    Dan
    May 2006
    4045
    Re: Automatic Tool Change C Code
    Hi Dan,
    That is the file used to keep track of the last loaded tool. It should just contain a number. You might use notepad and create it. Use -1 to do indicate no tool loaded.
    But if KMotionCNC is running and the file isn't valid the operator should be asked to enter the last loaded tool. Is KMotionCNC running?
    Regards
    TK
    http://dynomotion.com
    Feb 2008
    216
    Hi Tom,
    Yeah I get a message at the start every time to identify the last loaded tool. If the file isn't valid that won't impact anything?
    Dan
    May 2006
    4045
    Hi Dan,
    I don't understand what you mean by that and you didn't answer my question whether you are running KMotionCNC.
    Is the Operator asked which Tool is loaded?
    Does your Windows C Drive have a C:\Temp Directory?
    The code is written such that if it can't determine if or which tool is loaded it will not load any tool and will Halt the GCode.
    Regards
    TK
    Feb 2008
    216
    Quote Originally Posted by TomKerekes View Post
    Hi Dan,
    Regards
    Currently I'm writing the C code in the Kmotion C Code editor. I have the Machine Initialized using the KmotionCNC. When I want to run the tool change code I click the "Save/Compile/Download/Run" Button.
    KmotionCNC then asks which tool is in the tool changer. I type 1 and then it begins the unload sequence (that's as far as I am).
    Is there a better way to test my code? Should I assign my test code to the M6 command in the KmotionCNC Tool Setup Screen?
    When I look at the C Drive there is no C:\Temp folder, can I make a new folder anywhere and then reference that new folder? (I tried this and got the same error message)
    May 2006
    4045
    Hi Dan,
    You can test your code using either of those methods but if you run the code from the C Code Editor you should be aware that the code expects the tool number to be loaded into persist Variable #9. So you should manually set that value the same as what the M6 Txx would do automatically. The definition shown below is what determines where the Tool number is expected:
    #define TOOL_VAR 9 // Tool changer desired new tool Var
    It isn't clear to me what you actually tried. But this definition in the code determines what folder is to be used to find which file. (note the double slashes are needed in C to specify a single slash as the slash character is an "escape" character used to treat the following character in a special manner):
    #define TOOL_DISK_FILE "c:\\Temp\\ToolChangerData.txt"
    HTH
    Regards
    TK
    Feb 2008
    216
    Ok thanks that all makes sense. The double/single slash part I had no idea about. I'll try it the correct way this time.
    Feb 2008
    216
    Quote Originally Posted by slimneill View Post
    Hey Tom I got the Tool change working, which I thought would take us a lot longer. Now that I'm debugging it there are a few things that I noticed that I would like to address.
    1. The bigger issue that I'm facing is that I have a number of fail safes built into the tool change and if at any point in the code a fail safe is tripped the tool change is aborted, which is good. But there is no logic for the tool change to ask me what tool is currently in the spindle after a failed tool change attempt. For example, I perform a tool change T2 M6 with current tool being T1. The tool change gets all the way to installing T2 into spindle and then quits outs (Tool 2 is now in the spindle). When I try to do a tool change again it still thinks Tool 1 is the tool in the spindle and try's to drop off Tool 2 into a loaded tool holder. Is there a simple way to add the question of what tool is in the spindle at the moment the machine spits out an error message and aborts the tool change?
    2. If I notice that the tool holder isn't going into the desired location (See issue 1 above) I hit the feed hold button which is set up in my initialization file. But when I go this it only stops the motion, the tool change process continues on with dumping the tool and only aborts when it doesn't sense the new tool. I never really noticed that the C code continues on with the feedhole button activated hit until now. Is there a simple way to change this? Do I modify the Initialization file to freeze all commands or do I do something in the C Code for tool change?
    3. I also noticed that now that I have the tool change Code in the M6 command. When ever I change the Tool on the KmotionCNC Tool ID drop down box the machine automatically does a tool change to that tool even if I'm just flipping through them. Which I don't want it to do during a job setup when I'm working around that area. Is there a way to prevent the tool change feature from activating off of the Tool ID Drop down box?
    Thanks for your help!
    Dan
    May 2006
    4045
    Hi Dan,
    One thought would be to set the LastTool as 0 (undefined/unknown) using SaveCurrentTool(0) on any Tool Change Abort. That should cause the Operator to be prompted whenever the next tool is to be loaded.
    Feed Hold only stops the axes that are defined in the Coordinate System. I suppose you could sprinkle in tests for Feed Hold (CS0_StoppingState != 0) in all your wait loops and do what is appropriate. Such as stop all the axes (Jog to zero speeds), or disable axes, or whatever and then abort.
    Well that is supposed to be what the Tool drop down is for. Why would you be flipping through Tools? Do you have "M6 on Tool Table Changes" selected in Tool Setup | Trajectory Planner? That will cause the tool to be reloaded whenever the Tool Table is Changed/Closed.
    Regards
    TK
    Feb 2008
    216
    Tool Change In Action, Thanks for the Awesome Support Tom!
    More videos to come of the drill and laser in action.
    https://youtu.be/jdgWw4igXnA
    https://youtu.be/0TX8sA44sUI
    May 2006
    4045
    Hi Dan,
    Wow. Impressive machine. Can't wait for the other videos with it actually doing something
    Any chance your willing to share your final Tool Changer Code?
    Regards
    TK
    Feb 2008
    216
    Thanks Tom,
    Its not done yet, this was just as far as I was able to get in one weekend. Once everything is operational and bugs ironed out i'll post the code. I've tried to add to the wiki before but it didn't work when I tried to add the part zero probe code.
    On a side note, the machine still automatically performed a tool change when you select a different tool in the drop down box tool selection box even when the perform M6 command option is unchecked in the tool setup screen. Is there something in my code that needs to be changed or the KmotionCNC?
    Dan
    May 2006
    4045
    Hi Dan,
    We can post any code to the wiki if you have problems doing it.
    The Tool Drop down is supposed to be an easy way to change tools. So that behavior is by design. I'm not sure I really understand the issue. What exactly are you expecting?
    Regards
    TK
    Feb 2008
    216
    Hi Dan,
    Regards
    Next time I'm home I'll video the touch probe and send you the code to post. Email or here?
    My issue with the drop down chart is, just by opening the table to look at the tool database for offsets and data entry etc, when I leave that menu the machine automatically performs the tool change.
    What command is being sent? Is it an actual m6 g code command or something else?
    Feb 2008
    216
    Hi Dan,
    Regards
    Next time I'm home I'll record the touch probe and send you the code to post. Email or here?
    My issue with the drop down chart auto tool changing is, just by opening the table to look at the tool database for offsets and data entry etc, when I leave that menu the machine automatically performs the tool change. Sliding the tool tray into the work area.
    May 2006
    4045
    Hi Dan,
    That would be great either way. But if you post here attach the C files as .txt files don't paste them into the message or the formatting will be lost.
    Selecting a Tool from the drop down should perform a tool change. But opening the Tool Table to edit or view it should not. Are you sure that is the case? I just tested and don't see that. What Version of KMotion are you running?
    Regards
    TK
    Feb 2008
    216
    Regards
    This was the case I recall happening, even if there wasn't a change in tool selection when I clicked away form the menu (anywhere on the screen) causing it drop down list to close, the machine would read a tool change command and execute it even if there was change in tool selection.
    i.e. if Tool 6 was in the spindle, Tool 6 would be dropped off and picked back up again.
    We are running 4.34H
    May 2012
    537
    My machine changes only when you use the drop down list. No action when you open tool table. Also you should add a check to your toolchange program for requested tool and current tool being equal and end the program. No need to actually do a tool change when the current tool is loaded.
    Feb 2008
    216
    Quote Originally Posted by mmurray70 View Post
    Which spindle are you using? I'm curious as to how you verify that it isn't rotating?
    My HSD spindle has a signal that is on/off for 180deg rotation while operating the signal looks like it's on full time but there is a 50% chance that you will get a high signal even when the spindle isn't moving.
    My VFD (HITACHI) has an output signal which goes high when zero RPM is achieved which is what I'm using.
    May 2012
    537
    My toolchange program checks if the spindle is running (just reads the CW and CCW bits) and if it is, it turns it off and waits 3 seconds for it to stop. It then orientates, and waits for orientation signal before actually changing the tool.
    You would probably be safe enough to just check if its on, tell it to stop, wait and then toolchange. Make sure your not using any manual switches or anything that could leave spindle on. If you want to be extra sure maybe you could get it to read that sensor and make sure the state isnt changing for a second or so.
Page 1 of 2 12
  1. DIY CNC - Automatic Tool change with Mach3
    By khanhnguyen in forum Mach Software (ArtSoft software)
    Last Post: 07-17-2016, 10:06 AM
  2. manual automatic tool change
    By krymis in forum Benchtop Machines
    Last Post: 08-15-2011, 08:01 AM
  3. Automatic Tool Change (ATC) - Help!
    By spotlite in forum Mach Wizards, Macros, & Addons
    Last Post: 05-18-2008, 11:16 AM
  4. Fanuc OI-mc Automatic Tool Change
    By dsgent in forum Fadal
    Last Post: 12-20-2007, 11:45 PM
  5. Manual Automatic Tool Change
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 09-29-2004, 06:21 PM
