586,106 active members*
3,177 visitors online*
Results 1 to 6 of 6
    Feb 2006
    170
    Jgro in South Africa
    I was wandering if anyone in South Africa is building the Jgro CNC Router.I am seriously considering building this machine but first need to know where to source the parts.Does anyone know where to source the parts in South Africa.I think the design of the machine is brilliant.
    Feb 2006
    170
    Smile
    My bearings arrived this week from the USA, I ordered them from vxb.com.I also ordered the Hobby CNC 3 Axis Pro Chopper Driver board today.I will probably get the wood at the end of the month.My build is progressing very slowly but im on a really tight budget.I will cut out all the wooden parts on a Multicam CNC Router I operate at work.
    Dec 2004
    1316
    Well if that router take a full sheet of MDF, your build will progress a lot faster.
    Are you going to drill all of the top holes with the router as well?
    Jason
    Feb 2006
    170
    Yes it can take a full sheet of MDF, its bed size is 3m x 2m and I am going to do all the holes on the Multicam as well.Im still busy converting the plans to metric and sizing all the holes to accomodate metric fasteners but thats almost done.Would a 12mm threaded rod with a 15TPI be ok for the X and Y leadscrews? I managed to get a ballscrew for the Z Axis from a friend, can I have a ballscrew for the Z and Threaded Rod for the X and Y.I am going to use the HobbyCNC 200oz/in steppers.
    May 2006
    67
    I would try to stay away from threaded rod, atleast thats what I keep hearing from here anyways.
    Feb 2006
    170
    I have cancelled my plans to build the Jgro router, I am going to build the Lionclaw LC50 Router instead it looks a much stiffer machine.The Jgro is a well designed and simple machine to build but I need something that is stronger and bigger.
  1. Any South Australians here?
    By Matty Zee in forum Australia, New Zealand Club House
    Last Post: 08-26-2009, 09:39 AM
  2. Shipping to Soth Africa?
    By sixpence in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 10-20-2008, 07:17 PM
  3. UK - South (or anywhere in the UK really)
    By Ian Barley in forum Mentors & Apprentice Locator
    Last Post: 01-11-2008, 12:07 AM
  4. Montreal/South-shore
    By Daniel Gervais in forum Mentors & Apprentice Locator
    Last Post: 01-28-2007, 05:38 AM
  5. Help in South Central PA
    By soarnut in forum Mentors & Apprentice Locator
    Last Post: 01-01-2006, 05:07 PM
