586,058 active members*
4,525 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Purchased used Deco 20a with transmit function option
    Apr 2017
    Hello. I have purchased a used Deco 20a with transmit function option and C-axis. But when I try to use a program using transmit function (M198 D-1) the machine alarms and says option not installed. I have checked the required keep relays. What else am I missing? I spoke to Tornos US and they said I need to buy the option and I said the machine already has the option. The new EVO Deco 32 I bought came with the option for no charge. They are trying to nickle and dime everything.
    Nov 2015
    Re: Purchased used Deco 20a with transmit function option
    Tb deco program include 4 pieces ,init, part, end bar, newbar.
    When all program have been deleted and just one block exist with M198 you look z axis and c axis work same time and exactly. But if this block used in standard tb deco program then the alarm option not available appeared. I think one of macro such az g912 or g920 check parameter on controller. I think the machine dont need to upgrade hardware such as encoder or controller. Maybe just one parameter that just tornos engineer know this parameter.
  1. Deco 2000
    By jorgehrr in forum CNC Swiss Screw Machines
    Last Post: 11-19-2017, 11:43 PM
  2. Merge function - climb or unconventional option?
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 08-26-2014, 03:37 PM
  3. Tornos Deco 10
    By crocnc in forum CNC Swiss Screw Machines
    Last Post: 03-22-2014, 12:26 AM
  4. Deco 20A Alarm
    By ORTHO BONE in forum CNC Swiss Screw Machines
    Last Post: 01-06-2014, 04:20 PM
  5. Function "Tracyl/Transmit"
    By hartan in forum SIEMENS -> GENERAL
    Last Post: 06-13-2010, 07:24 AM
