586,072 active members*
4,681 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang spindle motor ground
    Sep 2006
    245
    I am getting ready to wire up a Huanyang 1.5KW 110V spindle motor and wonder what to do with the ground pin. The motor uses 3 wires, but it has a 4 pin connector. The limited motor documentation says that pin 4 is "earth wire". However, it appears to be completely isolated from the case and the other 3 wires.
    I ordered some 3 wire 16ga shielded cable that is a bit too large to fit through the connector that came with the motor. It is a perfect diameter if I remove the outer jacket and clamp around the braided shield. This would ground the spindle sleeve and it would end up grounding my entire aluminum CNC router.
    Should I leave pin 4 floating and ground the spindle at the connector? Or should I find a way to just ground what appears to be a floating pin 4 on the motor?
    thanks
    Steve
    Dec 2013
    5717
    Re: Huanyang spindle motor ground
    Normally you would connect the motor ground to the ground lug on the VFD. The ground lug on the VFD should also be connected to machine/panel ground, which should ultimately be connected the Earth via your shop electrical service.
    15362
    Quote Originally Posted by steve323 View Post
    thanks
    Steve
    Bad choice Ground is there to protect you, and your spindle, your spindle needs a Ground
    It is very common the 4th pin is not connected with these spindles, what you have to do is take the top off the spindle and connect the Ground
    So you need to have a 4 wire shielded cable, this cable from IGUS CF35-15-04 16 Gauge CF35-07-04 18 Gauge
    You need to fix the Spindle Ground before you power it up
    Mactec54
    Sep 2006
    245
    Thanks for the feedback Jim and Matec54.
    I opened up the end of the motor and it is a floating connector. I will add the internal lug to protect myself in case one of the wire motors shorts to the frame. It makes perfect sense now.
    Steve
  1. How to Set up a Huanyang VFD and 2.2KW Air Spindle
    By KB2WYL in forum News Announcements
    Last Post: 01-09-2017, 05:04 AM
  2. 1.5kw spindle & Huanyang VFD
    By graphicideas1 in forum Spindles / VFD
    Last Post: 04-04-2014, 04:53 PM
  3. Help Help Help - Huanyang VFd and spindle
    By PsychoPig7 in forum Phase Converters
    Last Post: 06-19-2012, 09:54 AM
  4. Motor Driver where to put ground?
    By Trapper14 in forum CNC Machine Related Electronics
    Last Post: 08-08-2006, 08:20 AM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
