586,069 active members*
3,446 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, what is this formula ?
Results 1 to 11 of 11
    Jun 2015
    4154
    hello again guys & girls please, somehow, do you know what is the meaning of attached formula ? kindly !
    Medan Guest
    Re: pls, what is this formula ?
    Quote Originally Posted by deadlykitten View Post
    Must be cold where you are.
    Anyhow, seems like you're turning threads on a 4-axis machine. If not then the formula means nothing. If so, you're calculating a feed rate for a fixed cycle. Bear in mind that when you turn threads, what's most important is the finish. It's really hard to get in there with a file or sandpaper after. Also, you never (almost never) cut a thread with a single pass so each time you make a pass you take a bit more off. Assuming you're working with a metal (post needs a wee bit more context) the most important thing vis-a-vis machine settings is related to chip load. spin too fast and you burn things out. Spin to slow and you burn things out. The chip is the heat extractor. Find the Goldilocks zone and you can rip a thread without even using coolant (though not recommended, a good coolant leaves a nice finish too).
    So that's my Rp 267 worth (at today's exchange rate). Hope it helps a bit or maybe just stresses you out more. Whoops. A little more info could be useful for the community. Where is the formula coming from? What software/reference/book? What is mu? What is optional parameter (OTHER FUNCTION 1)? What is the meaning of life? Or you could try turning by hand. You'll find you get a feel for feeding the cutting tool in manually. Somewhere in the formula, maybe the parameter setting, you need to specify the material and therefore the cutting speed (ranges from about 150 to 1000). All a little fuzzy, no?
    Good luck. Keep the faith or use the force. It all works out in the end.
    P.S. If you're going to be doing a lot of this, try to get some time on a lathe in somebody's workshop and turning a few by hand. That really helps you understand what all this is about. Didn't have formulas when I started (sigh).
    Jun 2015
    4154
    if you know what is this formula, than you don't need extra infos
    thank you for the show
    Medan Guest
    Sorry. I do enjoy a good story though. Time for tea. :cheers:
    Jun 2015
    4154
    is ok to be funky, but try to keep a balance at least this is what i try to do ...
    Jun 2015
    4154
    hy Medan, look, don't get me wrong
    i just replied like that because your answer was funny, but had no real conection with the question
    yup, there are some tangents, but nothing to solve the issue
    i dont know how much you know, etc
    but this Okuma forum is solid, and generally answers are sharp so think of stories if you also can prove your skills
    otherwise, 2..3...4 more guys / girls telling stories, and the quality of the forum will be lost
    Jun 2015
    4154
    is a sugestion for computing the feed among X axis when a taper is desired near a thread end
    after trials, i can say that expected taper angle and real taper angle are not quite the same
    full control for the end taper requires custom tools; i will explain it soon kindly !
    Aug 2011
    419
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    hy kurmay the measuring unit for the parameter is contradictory : formula uses "microns", and on parameter page is "mm/min" ( attached ); also i always wondered what's the deal with the "8", so how did you find out about the cpu cycle time ?
    i dont see why that formula is listed inside the manuals; somehow things should be simpler
    nice skills kurmay
    Aug 2011
    419
    On the OSP7000L, axis motion is controlled as the control calculates RCON every 12.8 msec.
    The change of variation amount in the repetitive calculation is called "unit amount".
    (in the OSP7000L operation manual, page 409)
    Jun 2015
    4154
    thanks kurmay i also intend to read osp7000 docs, just after i will finish reading the osp300 docs ...
    however, i saw that newer manuals have sections with pages from older manuals, some even written at a typewritter, and i think there may be something interesting
    teahole said a while ago that older manuals contain stuff
    time is my worst enemy kindly !
  1. formula?
    By JOptionPane in forum CNC Machining Centers
    Last Post: 06-23-2008, 07:52 PM
  2. need a formula
    By gravy in forum MetalWork Discussion
    Last Post: 03-29-2008, 01:38 PM
  3. looking for a Formula
    By rusticr6 in forum Haas Mills
    Last Post: 10-18-2007, 04:23 PM
  4. Formula
    By CNCRob in forum Uncategorised CAM Discussion
    Last Post: 07-01-2005, 03:18 PM
  5. formula please!
    By turmite in forum CNC Machine Related Electronics
    Last Post: 11-22-2003, 08:45 PM
