586,111 active members*
3,361 visitors online*
Thread: G code error
    Aug 2016
    5
    G code error
    Hi I use v carve pro 8.5. I designed a project much like I always have except I didnt import any image. I simply want to make a 30"x19" piece with 1/2" slots every inch. I used the lines and rectangle section to do that. But when I try and download it onto the cncsb it says- "Error in G code. File ended with no percent sign or program end (10) Line: 1506 Go X0.0000Y0.0000". Also the file after I saved it ends with nc not tap. example: name of project.tap instead it has- name of project.nc. What am I doing wrong?
    Thank you
    Ray
    Re: G code error
    Sounds like your saving with the wrong post processor.
    Feb 2009
    192
    Re: G code error
    The .NC file may work depending on your control software, however you can select your POST when you save your file....see attached
    Aug 2016
    5
    Re: G code error
    I saved it inn G Code
    Aug 2016
    5
    Re: G code error
    Got it Thanks guys
  1. Need Help - Amada RG 80 Error code 315 / Alarm code 315
    By P2CNC in forum Maintenance DIY Discussion
    Last Post: 04-18-2021, 06:58 PM
  2. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  3. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
  4. Error code 104
    By morpwr in forum Haas Mills
    Last Post: 10-27-2011, 03:37 AM
