586,104 active members*
3,470 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Replacement bearings for Hitachi MV12...
Results 1 to 9 of 9
    Mar 2010
    621
    Looks like its time to replace the bearings in my MV12 so I was curious where people are buying bearings for those that have replaced them and if there are better options instead of the default Hitatchi bearings...
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Nov 2010
    520
    Re: Replacement bearings for Hitachi MV12...
    I've bought a lot of bearings from Boca Bearings. I've also bought bearings off of ebay.
    I would take the bearings out and measure them (this is where a digital caliper comes in handy) (metric I would guess) and take a look on ebay and see what you can find.
    I'm sure you can find some for a lot less then Hitachi sells them for and you can probably get them faster too.
    I had to replace a bearing in my power hand planner and got a bearing from ebay. Worked just fine.
    May 2005
    3920
    Kaman Industrial Technologies is a good choice if you have a local branch. Kaman now has an internet site Kaman Industrial Technologies and lists close to 300,000 bearings. Beyond that, there are many other online bearing suppliers these days. Just do a Google search for "bearing suppliers".
    I mention Kaman due to working with them a lot at work, very good service but also "industrial prices".
    As far as better bearings that is an interesting question. First rule here is to avoid Chinese bearings. Generally I prefer to stick with German, Japanese or USA made bearings when we can get them. A good bearing supplier can steer you in the best direction for an upgrade if one is available. I say "if" because Hitachi is known to build to a high degree of performance.
    You can look into options like ceramic bearings and synthetic lubes but realize that costs go up significantly.
    Jun 2005
    1730
    Adam,
    I used an M12V for years and had the same issues. I purchased a tube of 10 off of ebay, so let me warn you, do buy the cheap ones you find on ebay. They are not intended for high speed and go bad very fast. I had to order my replacements from an OEM distributor who services the Hitachi tools in my town. They ran about $25 or something in that ballpark and when you put those in and run they are quiet and work correctly. After going through maybe six OEM bearings I finally broke down and purchased a Water Cooled Spindle and it has been working fine for over 10 years and the noise level alone was so much lower that all by itself made the investment worth it to me.
    Russ
    Mar 2010
    621
    Thanks for the posts guys.
    I guess my question should have been about the quality of the Hitachi replacement bearings since the Chinese have flooded the market with inferior product. Do they make a good replacement? They seem to be readily available in the web...
    I realize that RPM is a factor in th bearing purchase and that they will need to be rated for speeds of a router, 30k I would assume.
    I'm also ultimately going to add a spindle but I'm just not ready for it yet. I was hoping for another year out of the router, cutting aluminum was tough on it and I think what brought it down.
    Adam,
    Quote Originally Posted by CNCMAN172 View Post
    Adam,
    Russ
    May 2005
    3920
    Quote Originally Posted by adam_m View Post
    You can buy from Hitachi if you want. I suspect the quality would be better than many suppliers would put forth. This due to Hitachi knowing exactly what was specified bearing wise when the router was built.
    Still I'd locate a bearing supplier you can work with. The bearing son the router right now should have the bearing part number stamped on them. If not you have to measure up the bot, OD and thickness. If you haven't lost the balls getting a count of the number of balls can help as there are two basic types of radial ball bearings, one is called Conrad the other maximum. Generally you will save big time by going through a reputable bearing supplier.
    Adam,
    Mar 2010
    621
    In the States are there any reputable dealers that can be recommended?
    I believe the bearings are:
    608 VVM (608VVC2PS2L)
    600 4VV (6004VVCMPS2L)
    May 2005
    3920
    Well I mentioned Kaman due to experience with them.
    As for online retailers I've heard good things about Boca and VXB but has never dealt with them myself.
    That is actually good as the base bearings are standard, that is 608 and 6004 are standard bearing form factors. The VV's likely indicate seal type. It is the numbers beyond the VV that will be interesting because they could be specifying features for high speed operation. You would need the manufactures catalog to get to the specifics.
    Sep 2003
    1469
    I’ve got bearings. But how do you get that top bearing off not much space to work?
  1. Mikini Spindle Bearings Replacement
    By SGTShop in forum Mikinimech
    Last Post: 06-28-2014, 09:46 AM
  2. Hitachi Seiki CNC lathe replacement parts
    By Limabeans913 in forum Uncategorised MetalWorking Machines
    Last Post: 02-08-2013, 04:00 PM
  3. The Hitachi MV12, Precise Bits, Runout, and Masking Tape
    By NIC 77 in forum DIY CNC Router Table Machines
    Last Post: 06-13-2012, 04:17 PM
  4. Looking for replacement VMC760 spindle or 7013 bearings
    By Interact77 in forum Bridgeport / Hardinge Mills
    Last Post: 08-19-2010, 01:28 PM
  5. Hitachi MV12 Collets
    By Ernie34 in forum DIY CNC Router Table Machines
    Last Post: 06-04-2010, 06:30 AM
