586,516 active members*
3,909 visitors online*
Results 1 to 12 of 12
    Aug 2009
    119
    RichAuto vs Mach3
    I'd like to know how the RichAuto controllers compare to Mach3?
    I know both Laguna and Axiom use them is relatively high end small machines, seem like they should be good - are they?
    Richard
    Aug 2006
    44
    Re: RichAuto vs Mach3
    I recommend use the Richauto controller .
    I am in Los Angeles . If you need any help let me know .
    I like Linuxcnc (but I have no experience with either of those.)
    PS: it's free.
    Jun 2005
    1730
    If the RichAuto still has all the Chinese symbols which you see in many videos, I would steer clear unless you are fluent in Chinese. Some of the DSP controllers have fully been converted to English others only partially. There are more and more controllers hitting the market. One of the most recent is the CentroidCNC Acorn controller. It cost $265 but it comes with some very tested software by a big name in the industry. It just got introduced and starts shipping next Wednesday. Check out their link. I have absolutely nothing to do with this company but there are many followers on cnczone, their bigger controllers that run the same software get mounted on many commercial machines. Worth a look.
    Russ
    Centroid Acorn CNC controller, Step and Direction 4 axis CNC Control board with ethernet communication
    Jun 2015
    943
    Quote Originally Posted by dixdance View Post
    Richard
    You might want to consider using UCCNC with the Axiom machines.
    https://www.youtube.com/watch?v=KHKm-6MA2HQ
    https://www.youtube.com/watch?v=bsJM7VH_apU
    May 2015
    686
    Quote Originally Posted by Todd Zuercher View Post
    PS: it's free.
    x2
    Rod Webster
    www.vehiclemods.net.au
    Aug 2009
    119
    What would modification be required to run the Axiom with either UCCNC or Linuxcnc instead of the RichAuto?
    I don't know what type of hardware is in the Axiom control, but you'd need to replace it with a CNC Drive controller (and breakout boards) for UCCNC, or a Mesa board for LinuxCNC (unless you are using the parallel port).
    Aug 2009
    119
    I'm not sure exactly what that means Ger.
    Last year I replaced the stepper drivers in a Techno Davinci with Geckos and run it with Mach 3, would this be similar?
    There should be a controller board in your machine, that the drives are connected to. You need to replace this board with a CNC Drive controller.
    Jan 2019
    6
    I can control the external equipment by M-Code by Mach3 (for example: M7, M9) but I don't know how to do it by RichAuto.
    Because the output signal of Rich Auto for lamp only.
    Somebody, could you help me to control the external equipment by M-Code?
    How to do it for OUTPUT SIGNAL Y7, Y8?
    May 2016
    bonjour moi j,ai axiom pro6 2x36 et richAuto A11E et j'essaie de faire un update et me dis qu'il n'y a rien dedans auris'je supprimer sans m,en rendre compte mais je vois sur pc mais pas sur ma cnc comment faire pour avoir driver pour rich auto
  1. RICHAUTO A11E - No USB?
    By CHINNO in forum Controller & Computer Solutions
    Last Post: 03-07-2021, 04:13 PM
  2. richauto A11 dsp control
    By senthil_kkl in forum Controller & Computer Solutions
    Last Post: 10-13-2018, 06:50 AM
  3. Replies: 10
    Last Post: 08-02-2018, 09:17 AM
  4. Chinese 6090 on Richauto DSP
    By andrewdenhaan in forum Chinese Machines
    Last Post: 01-07-2016, 07:41 AM
  5. Need help on RichAuto A11S Handle
    By albeagle in forum Chinese Machines
    Last Post: 03-02-2015, 06:15 PM
