586,119 active members*
3,532 visitors online*
Results 1 to 6 of 6
    Mar 2013
    344
    Return of Rapid Return Mid-April
    I called Tormach and they told me they expect to have the updated RT's in mid-April. I asked if I could pre-order but they said they will have a large enough supply.
    Oct 2010
    670
    Re: Return of Rapid Return Mid-April
    Looking to order one myself. Got my fingers crossed that they fixed everything this time around.
    Awall
    The Body Armor Dude - Andrew
    Mar 2013
    131
    What issues were they having?
    Apr 2016
    109
    See the videos from Keen in an earlier thread. He unfortunately found that the dimensions at the back of the spindle where the collet is supposed to mate was too large on all the initial run of RapidTurns. Tormach has been busy replacing the spindles for existing owners and presumably is getting ready to relaunch to everyone with proper dimension spindles.
    Mar 2013
    131
    Quote Originally Posted by Advil View Post
    Well, that is one hell of an oversight.
    Mar 2016
    54
    Quote Originally Posted by eltejano View Post
    Also spindle sensor problems. Mine was replaced complete due to the spindle issue and when running at over (approx.) 1000rpm the sensor is faulty, so X/Z axis traversing isn't smooth, and threading becomes impossible. After email exchanges with Tech Support who have been great, they agreed to send me a new sensor and cable, but i found out after a week of waiting they are backordered! Not sure when they will be available. The sensors in the new RTs are different than the originals (which in mine worked fine). I just wish I'd found the issue before sending the old one back! Luckily I'm not in a production environment, just a hobbyist, but it's still a shame to have the issue after all the hassle for the spindle. Let's hope this is the end of the issues; I am very pleased with the RT's capabilities and performance (otherwise) and for those who are waiting patiently, I'm sure you'll find it worth-it.
    Incidentally, on suggestion from Tormach, I checked the sensor was connected to the 12v output on the din plug (there's 5v there also), and tried different sensor gaps. Seems it's a bad sensor. Keen's other Rapid Turn thread has recent further detail.
    Cheers, Andy
    UK
  1. Will Rapid Turn Return?
    By jttoner in forum Tormach Personal CNC Mill
    Last Post: 02-18-2017, 07:19 PM
  2. Zero return
    By bubba107 in forum EMCO Mills
    Last Post: 10-22-2009, 01:49 AM
  3. Return to Zero
    By mikemill in forum Machines running Mach Software
    Last Post: 08-25-2009, 08:47 AM
