586,069 active members*
3,356 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 1000 Vickers Acramatic 2100 Controller Display Washed Out
Results 1 to 8 of 8
    May 2010
    64
    Hello and thank you in advance for any help offered! Was setting up my mill today, looked over and my controller display was blank with a blue/black squiggly line running through it. I quickly powered it down, as it was powering down, the screen display came back, but was washed out with lines running through it. When I booted back up...wash out screen display and it now looks like you are looking through the touch screen rather then being displayed on the touch screen, if that makes sense. Touch screen still works, seems to respond as normal. Anybody else have any experience with this type of problem?
    Thank you again, Bill
    Dec 2006
    584
    Re: Arrow 1000 Vickers Acramatic 2100 Controller Display Washed Out
    Bill,
    If you have the old CRT this is somewhat normal for a control of that age. You have some adjustments in the CRT in the back. It may be time to upgrade to a LED screen. You should only need a new display if the touch screen is working.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    May 2010
    64
    Quote Originally Posted by meckardt55 View Post
    Bill,
    Thank you for the responce! any experance/info you can offer on what it takes to upgrade to a LED Screen in one of these controllers?...but if I can just get it back to normal...and feel assoured its not about to go out for good...thats a result!
    May 2010
    64
    just found this....assuming its the CRT and not a board...transformer...etc?
    New Universal retrofit LCD Monitor for Milacron Acramatic 2100 and Tree TPC-2100
    Apr 2015
    77
    I swapped out the CRT with a LCD today. Somewhat reasonably priced on eBay.
    The display is a Sharp LQ121S1LG45 with a generic VGA module.
    Fits like a glove!
    May 2010
    64
    Quote Originally Posted by larspeed View Post
    Fits like a glove!
    GREAT!!! Thank you for sharing your results, I have yet to spend the money, but will feel much better about it now!
    Dec 2006
    584
    Can you give us more info on what you used and what the total price was.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Apr 2015
    77
    Hi, meckardt55!
    Sure can do - i bought a kit similar to this;
    Display Kit on eBay
    The difference between my display and the one in the link above are backlight type - my display have tubes but this one seems to have LED.
    Price is about the same (mine was 85$), but my purchase included a 12V power supply.
    There are several displays to choose from if you do a search on eBay, but be certain that you choose a 12.1 inch unit with 4:3 picture format, 800x600 resolution.
    I had to connect a male/male adapter to fit the original VGA-cable and hook up the provided 12V supply to the original mains.
    The display itself sits neatly in the original foam surrounding the screen - will have to secure it better, perhaps with strips of double sided tape.
    Regards
  1. cincinnati arrow 1000 acramatic 2100 batteries
    By dbills in forum Cincinnati CNC
    Last Post: 10-24-2017, 08:32 PM
  2. Cincinnati Acramatic 2100 (Vickers)
    By atif.naseer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2013, 07:47 AM
  3. Arrow 1000 W/Acramatic 2100 - PC crashing
    By Heinster in forum Cincinnati CNC
    Last Post: 02-11-2011, 10:57 PM
  4. Arrow 500 - Acramatic 2100 No Power to Controller
    By hodge_thomas in forum Cincinnati CNC
    Last Post: 05-10-2010, 01:36 PM
  5. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
