586,110 active members*
3,293 visitors online*
Results 1 to 13 of 13
    Jul 2013
    608
    GOTO ZERO Speed
    I am new to UCCNC. I noticed that when I press goto zero my machines move quite fast to the zeros.
    Is there a way to slow it down?
    I do not believe that goto zero responds to the Feedrate I enter on the MDI. Does anyone know?
    Thank you
    Re: GOTO ZERO Speed
    Goto Zero calls the M204 macro, which uses rapid moves. If you change the G00's to G01's, it'll move at the feedrate speed.
    Jul 2013
    608
    Re: GOTO ZERO Speed
    ..uh? lol
    So I input C01 into the MDI then my F20 and gotozero will feed at 20units/m ?
    Is that M204 macro and standard?
    Re: GOTO ZERO Speed
    No, you need to edit the M204.txt macro, replacing all of the G00's with G01's.
    Jul 2013
    608
    Re: GOTO ZERO Speed
    Oh okay. Thank you.
    maybe that is also the same case as to why jogging usually goes full sleep regardless or my F input.
    Which leads me to ask: What is the F input controlling then if jogging and actually cutting feed are controlled by something else.. (I am not regretting changing over from Mach 3, just going through some growing pains I guess)
    Re: GOTO ZERO Speed
    Cutting speed is controlled by the F word, just like Mach3. And I believe that Goto Zero works the same as Mach3 as well.
    Jogging I'm not sure about, but there's a jogging speed % on the jog screen. Not sure if that's a percent of feedrate or rapids?
    Re: GOTO ZERO Speed
    This is for the default screen. If you are using my 2017 screen, the macro is different. It's listed in the manual.
    Jul 2013
    608
    Re: GOTO ZERO Speed
    Thank you it was able to fix it with you help and it does respond to the F word now.
    I could not found M204. Macro in macro folder
    Hello i couldn't find M204.txt macro in macro folder.where can i get it
    Re: GOTO ZERO Speed
    Look in UCCNC\Profiles\Macro_Default
    I had mach3 not uc cnc
    I. Have mach3
  1. Goto (0,0,0) in Mach3
    By rbocaz in forum Mach Plasma / Laser
    Last Post: 11-05-2009, 02:08 PM
  2. (GOTO) function
    By traxxtito in forum Fanuc
    Last Post: 07-02-2009, 12:56 PM
  3. GOTO Z button
    By TMaster in forum Mach Mill
    Last Post: 05-30-2009, 01:18 PM
  4. Z goto 0 first ?
    By SScnc in forum Mach Mill
    Last Post: 08-10-2008, 06:31 PM
  5. GOTO Z
    By monte55 in forum Mach Software (ArtSoft software)
    Last Post: 02-06-2008, 04:03 PM
