Mini CNC Milling Machine of 4-axis
https://youtu.be/3qZ3pLygqhE
Product No: XK200
Product Name: Micro CNC Milling
Features
(1).Automatic 4 positions tool post.
(2).With sink and nozzles.
(3).High performance 2 axis cnc lathe controller,Optional siemens 808D or GSK980TB3 CNC controller..
(4). ARM 9 CPU+FPGA,Ethernet network interface,Support B macro function,PLC function,Mutil-language library function..
(5).Lathe CNC machine tools based entirely on the design and manufacture, reflects the structural integrity of facilitate future design ideas.
(6). The standard spec includes MPG hand wheel.
(7). USB and RS232 port, DNC function of USB.
(8). Network interface, supporting for remote monitoring and DNC file transfer processing.
(9). Control speed of G code.
(10). Selection of high -quality casting materials,more compact.
(11). A collection of double-nut ball screw, bearings and couplings with high precision positioning, while adding an automatic oil lubrication system, to protect your machine precision, extended service life.
(12). 220V single-phase AC power supply.
(13). Safety electrical components of high quality.
(14). Auto power off when door open.
(15). Applicable industry: technology development, advertising design, art, ocational technical college Education & Training CNC and DIY enthusiasts.
Optional Accessories
Technical parametersTurning diameter over bed(max) 210mm Chuck diameter 100mm Spindle speed 100-1750r/min(control speed of G code) Spindle through-hole 20mm Spindle mount MT3 Spindle motor power 500W X travel 80mm Z travel 290mm The max moving speed 2000mm/min The max feeding speed 1000mm/min Control system Adtech 4620,Optional siemens 808D or GSK980TB3 cnc controller Instruction DXF+G code template function, converting DXF automatically to G code for processing MPG handwheel 4 axis Tool position 4 Tool dimension 10*10mm Tailstock taper MT2 Tailstock sleeve diameter 20mm Travel of tailstock 25mm Positioning accuracy: 0.015mm Repeatability accuracy 0.02mm Power 220V/110V Weight(NW/GW) 180/200KG Overall dimension 1000*580*680mm Packing size 1100*700*610mm
Yornew Automation Equipment Co., Ltd.
ADDRESS3-2-3,4rd Lianfu,Leliu Town,Shunde Distr.,Foshan city,Guangdong,P.R.C
Tel: +(86) 757 2556 6186 MB:+(86) 137 0261 0648 Email: [email protected] http://www.yornew.com
