586,121 active members*
3,613 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
Results 1 to 20 of 30
Threaded View
    Jan 2008
    241
    Question Converting to UCCNC & UC300ETH-LPT5 (From Mach3/PP/SS)
    Hello,
    Just getting things setup up and running with the new hardware/software.
    I had the system up and running with Mach3 and through the parallel port.
    I was loosing steps due to the PP card issues.
    I got a hold of a smoothstepper for a week and had it running with a couple of clicks.
    Everything works no wiring issues...
    Now I have a UC300ETH-LPT5 and the software loaded up and plugged in, UC300 detects (And flash auto updated)
    Everything powered up, everything connected and I created a new profile and imported my Mach3 profile.
    (PP cable plugged into port 1 of the UC300)
    The limit switches work. The emerg stop works. The probe works (all signalling correctly through the Diags page)
    The motors lock up, but wont turn? Can't get the spindle to cycle on/off.
    I can't change the STEP/DIR pins, when I change them and click apply, they revert back to zero.
    Thoughts?
    Thanks!
    Attached Thumbnails Attached Thumbnails P_20170405_195131_vHDR_Auto.jpg   P_20170405_195207_vHDR_Auto.jpg
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
  1. Replies: 76
    Last Post: 03-27-2023, 11:26 PM
  2. uccnc or mach3
    By eldons in forum UCCNC Control Software
    Last Post: 04-02-2017, 06:31 PM
  3. UCCNC and UC300ETH - A real scary speed monster.
    By A_Camera in forum UCCNC Control Software
    Last Post: 11-24-2016, 06:21 AM
  4. Mach3 plugin is now available for the UC300ETH
    Last Post: 11-11-2016, 09:45 AM
  5. UCCNC and Mach3 Modbus MPG?
    By Signal9 in forum UCCNC Control Software
    Last Post: 09-19-2015, 07:42 PM
