586,094 active members*
3,993 visitors online*
    Jan 2006
    114
    Laser tube won't fire the beam
    Hi all,
    I've got a really weird problem with my laser tube.
    At a certain value on the mA meter the laser is actually lasering
    (See video: https://youtu.be/Luo7nPPR1G0)
    When I change the value of the potentiometer to adjust the laser output than no actual beam is comming out of the tube.
    Inside the tube I see the beam building (purple beam) but it doesn't come out of the tube.
    I've tried with a piece of paper between the tube and the first mirror.
    (See video: https://youtu.be/jmNyCu5M8-E)
    My laser is a 1200mm long 60watt glass tube, water cooled.
    Does anyone have an idea of whats happening, what is the issue and/or how to solve this?
    Many Thanks!
    Pierke
    Jul 2016
    660
    Re: Laser tube won't fire the beam
    Try sanding the contact posts and the HV clips on the glass tube with a 240 grit sand paper to have a fresh contacts, and test it again if it works in some cases it`s loosing power due to carbon build up on the contact points
    If I can just see your video maybe I can relate on the problem, but im not seeing it, it says access forbidden
    Jul 2013
    230
    Did you solve this problem?
    I'm trying to buy one, same issue.
    Rob
    Jul 2016
    660
    if you already sanded the HV contacts there`s a test switch on the power supply on it. try pressing that if it fires, that switch will fire the tube @ 100%, try that first to eliminate software issues (machine parameters) if it still does`nt then I guess your tube is worn out, if you dont know how to refill it then I guess you need to replace it
    Jul 2013
    230
    I'll give it a shot.
    But I'd like to buy it on the cheap so if I fix it for the guy it goes up to 2K. Too much for me.
    Thanks for your help
  1. Laser suddenly won't fire - tube or power supply?
    By jbarber in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 08-16-2020, 03:41 AM
  2. gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    By badrawy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2020, 01:41 AM
  3. CO2 laser tube beam characteristics?
    By AlexTsekenis in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 03-23-2017, 10:45 AM
  4. Laser beam turn around inside tube
    By DV0001 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-20-2015, 09:47 PM
  5. Burned on only positive laser tube end when test fire
    By 18111 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-22-2013, 07:00 PM
