I have a 4x8 CNCRP4896 Pro setup with Nema 34 motor on X and Y is 2038 and wondering how it was calculated? The step for the Z axis is 5080. Just trying to figure this out, so I can try to calculate my rotary setup step.
As I am trying to setup a rotary, A axis and having trouble calculating the step per for it. The dip setting on all the module output is 2000, where the dip setting is off, on, on, off for 5, 6,7 and 8 with nema 34 servos. The rotary setup I got is this one with a gear ratio of 1:4 and and angle of 0.45 degrees per step. A axis works, but unable to get the correct step per and wondering how CNC router parts got 2038 for x and y axis.
Any help is appreciated.
Be Bliss.
