586,075 active members*
4,054 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc 31i b alarm sv0417 ill dig servo parameters x, y, z
    Apr 2017
    ok here is the story awea model 4025z/ fanuc 31i b serial 1222212,
    last week the spindle burned up. after rebuilding the spindle and reinstalling, i had to orientate the spindle using param 4077, after restarting alarm sv0417 ill dig servo parameters all 3 axis.
    went to diagnostics it sent me to 352 code 9053. we needed to run in the spindle so i went to param 1815 /it read 00000010 bit 4 and 5 vanished, so i changed bit 1 to 0 and set bit 4 and 5 to 1. alarm went away and i could run in the spindle in. when i tried to test the atc it stopped above the tool, then when i tried to run all 3 axis they all software over traveled. i thought big deal i'll just restart and do the cancel and p thing. well it homed just fine, but all 3 axis still would only travel 50% until they soft OT. i thought WTF. tried again after C + P to disable the over travel and it did, until after i homed it same problem. . i know i can go to 1320 or 1322 i dont recall right now, but i can set the distance to -999999.999 but then i noticed that all axis are reading inches incorrectly, and you cant run a program like that. . -x for instance will travel 24.000 but reads 48.000 . it actually only travels %50. its the same on all 3 axis. after cancel and p i can take them all to the hard stops but after i rehome its still.counts incorrectly . im sure some one accidentally hit a 0 somewhere it could of had a memory error. but i doubt that !. OK now my question, does any one how the correct parameters the distance to correct the count back to the actual limits? so if it moves a inch it reads a inch. oh it only software overtravels in -. + will home to 0.000 but it still counts distance wrong. + wont over travel
    i know this is along shot as i am a millwright and not a controls guy. so any help will be appreciated
    thanks mike
    Feb 2015
    161
    Re: fanuc 31i b alarm sv0417 ill dig servo parameters x, y, z
    Parameter 1815 bit 1 tells the control your axes have scales. That needs to be on for the axes with scales, or the control will not move properly.
    Apr 2017
    thanks stl but i tried that. alarm svo417 comes back no matter what other bits are loaded into 1815. what other bits need to be loaded for 1815 bit 1 to not alarm out the machine
    Quote Originally Posted by ddbmike View Post
    I have the same alarm in X axys. Can you help me??
  1. Replies: 0
    Last Post: 11-07-2016, 11:44 AM
  2. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  3. Replies: 6
    Last Post: 07-16-2010, 09:00 PM
  4. Help with FANUC 0i-Model A (servo parameters)
    By mr_electrician in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2008, 07:28 PM
  5. Servo alarm parameters
    By kevbo in forum Fanuc
    Last Post: 01-05-2008, 12:39 PM
