587,033 active members*
3,459 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Cncrouterparts changed from V bearings to linear guides
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Re: Cncrouterparts changed from V bearings to linear guides
    Would it even be worth it for me to look into UCCNC?
    If your happy with mach3, then probably not. If you have issues with Mach3, then I'd consider it.
    Someone posted a thread recently about swapping the ESS for a UC300ETH in the CNCRP plug and play system. You probably need to make some changes to get everything working properly.You need to use a charge pump safety system, and perhaps swap out the breakout board.
  2. #22
    Jan 2013
    31
    Everything works one for one far as inputs and outputs go. The difference is the initial state of the relays. CRP didn't use a charge pump as they trust the ESS to behave properly on start up. The UC300 initializes its outputs to active low which turns on the active low relays in the CRP electronics. You can disable the motors and turn off your spindle when you power down. Then power them on after UCCNC is up on your computer and communicating over ethernet with the UC300.
    I've communicated with CNC Drive about initializing inputs to the proper state on start up and they are considering it. It would be safer during start up to have a charge pump to enable relays. That means the three relays built into the custom break out board inside the electronics would have to be abandoned for safety critical task and moved to an external relay board.
    I'm 3D printing an adapter as the hole pattern is not the same for ESS and UC300.
    I've been running my machine with UCCNC and it works well for me. They have been responsive with bug fixes and suggestions.
    EDIT - forgot to add the disclaimer - you are on your own modifying the electronics. CRP sells the plug and play electronics as a complete kit and doesn't suggest changing anything.
  3. #23
    Mar 2017
    164
    Quote Originally Posted by skrap853 View Post
    I've communicated with CNC Drive about initializing inputs to the proper state on start up and they are considering it. It would be safer during start up to have a charge pump to enable relays. .
    Guys , what's a charge pump?
  4. #24
    The software sends out a 12.5Khz PWM signal when the software has control over the machine. You use this signal to make sure that you're electronics can't do anything until they see this signal. It's purpose is to keep things from moving, or motors from turning on, before the control software actually has control.
  5. #25
    Mar 2017
    164
    Thanks .Wow, I never would have guessed that one
Page 2 of 2 12
  1. Linear slides vs linear guides
    By mindoverflow in forum Linear and Rotary Motion
    Last Post: 07-25-2012, 04:23 PM
  2. Replies: 1
    Last Post: 05-04-2011, 05:16 PM
  3. PBC Linear Offers New Profile Rail Linear Guides
    By Pacific Bearing in forum News Announcements
    Last Post: 04-30-2009, 09:53 PM
  4. Linear Rails/guides and Bearings - What size is best?
    By Shawnusa in forum Linear and Rotary Motion
    Last Post: 10-29-2005, 04:51 PM
  5. Linear Guides with Teflon Bearings
    By cely in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2004, 11:05 PM
