586,070 active members*
3,543 visitors online*
Thread: MSG-803
    MSG-803
    Hi All.This is reza.
    I use a NC system type MSG-803.After many times the system could not boot up,I found there is problem with the CPU of the main board.Could you please tell me,how I can purchase another cpu .The specs. of the NC system written on the back of the case is as follow:
    PART NO.= E77090A04 - DESIGN NO. = PA03215-B013 - SER NO. = 532 - DATE = 1999-5 - MORI SEIKI CO., LTD.
    In addition the following words are written on the cpu:
    PA03220-E010 A1
    PD-2114F16S A1 P9401426
    Thank's.
    Re: MSG-803
    Hi reza,
    I have a MSG-803 (used) I could offer you. I think it has the same CPU installed and boots up straight away.
    there is a, original flash card plugged in with an OS/2 Mori kernel.
    Uli
