586,345 active members*
3,309 visitors online*
Results 1 to 17 of 17
    Apr 2017
    9
    Need Help!- MKX-4 Mach3 don't work 4th axis
    Hello.
    I have a MKX-4 card. the 4th axis works only as slave. At any other options an axis of 4 stop.
    Jun 2010
    4256
    Re: Need Help!- MKX-4 Mach3 don't work 4th axis
    Mach3 / Config / Slave Axis
    set all axes to 'None', restart mach.
    Cheers
    Roger
    Apr 2017
    9
    Problem that axis A doesn't work. Axis A works only in the slave mode together with other axis. It is necessary to me that axis A worked separately from other axes.
    Jun 2010
    4256
    Is your copy of Mach3 licenced?
    Cheers
    Roger
    Apr 2017
    9
    The demo, is a difference?
    Without a license, Mach3 will operate in Demo mode. While in Demo mode, the software has the following limitations:
    Mill & Plasma: 500 line gcode limit (10,000,000 limit after licensing)
    Turn: 50 line gcode limit (10,000,000 limit after licensing)
    Kernel Frequency locked at 25kHz (only applicable if using the parallel port driver)
    Set Next Line function disabled
    Run From Here function disabled
    Turn: Threading disabled
    Plasma: THC functions disabled
    Jun 2010
    4256
    Licence: it would help to know that.
    Anyhow, have you done the following yet?
    set all axes to 'None', restart Mach.
    Cheers
    Roger
    Apr 2017
    9
    I wanted to adjust at first the router, and then for work to buy the license. If the router doesn't work, the license isn't necessary to me
    Jun 2010
    4256
    I understand about the licence, but have you done the following yet?????
    Cheers
    Roger
    Apr 2017
    9
    Yes I tried this way. Axis A moves only in the slave mode together with other axis. At the disconnected slave axis A doesn't move.
    Jun 2010
    4256
    OK: that is vital information, needed to go any further.
    Now, when the A axis is slaved to (say) the X axis, the X axis pulses are also sent to the A driver. The fact that the A axis responds to X movements suggests that the Step/Dir pin definitions for the A axis are OK.
    When the A axis is not slaved to the X axis, then Mach generates pulses from the A values in the g-code, and should be sending them to the same pins.
    Can you give a little (short - 10 lines?) example of the sort of code which should be driving the A axis?
    Cheers
    Roger
    Apr 2017
    9
    G0 A10 or G1 A5 or ....
    Directly axis A doesn't work in any way. Also G codes and directly from the keypad of A+ and A- are ignored.
    I think a problem in the Chinese MKX-VI controller. The vendor is silent therefore I look for the help here.
    Jun 2010
    4256
    Mach3 / Config / Motor Tuning / A axis
    Can you take a screen shot of what this shows?
    Yes, I know, lots of strange questions. But I am on the opposite side of the world from you, and I have no idea what your system looks like.
    Oh - and what sort of drive does the A axis have? Stepper? Gearing?
    Cheers
    Roger
    Apr 2017
    9
    I will photograph everything and I will lay out later, it will take time, thanks for concern.
    Apr 2017
    9
    Once again thanks for concern. I understood. A problem in the MKX-VI controller hardware. This controller at the same time can work only with 3 axes from 6. Axes A, B and C work only in the slave mode along with the main axes. Chinese - that from them to take
    Quote Originally Posted by Kachik View Post
    Hello.
    Hi, I have exactly the same problems with the same controller and a license Mach3 version, did you fix it?
    Apr 2017
    9
    Hello.
    Yes, I bought a card that supports independent 4 axes. MKX-IVs come in MK3 - three axles, MK4 - four axles and MK6 - six axles.
    Thanks, I think I have the same problem. Thanks for your help.
  1. MKX-4 Mach3 don't work slave axis home
    By plUA in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-24-2018, 06:15 PM
  2. Mach3 arrow keys don't work
    By VSturmer in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2015, 01:11 AM
  3. Problem With Mach3 & Getting spindle to work.
    By badoxygeno2 in forum Machines running Mach Software
    Last Post: 12-28-2013, 05:35 AM
  4. AC Servoes to work on Mach3
    By Michael O in forum Servo Drives
    Last Post: 12-08-2010, 08:45 AM
  5. I need help for this file work with Mach3
    By newla in forum Mach Software (ArtSoft software)
    Last Post: 12-03-2007, 12:13 PM
