586,075 active members*
4,112 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > PIC Open source Servo Driver Schematics development?
Page 5 of 5 345
Results 81 to 91 of 91
  1. #81
    Apr 2006
    54
    Linistepper Lini8 New PCB
    In linistepper-lini8 power transistor mounted between pcb and heathsink
    Regards
    Argun
    Attached Files Attached Files
  2. #82
    Oct 2005
    Hi Argun,
    Some components are mising in your component list (IC4, IC5, R11A, R12A, R46, R50-R52). Can you post full component list? Also I found discrepancy between schematic and pcb. In schematic resistor R51 attached to pin 4 of IC5, on pcb to pin 3. Can you check which is right?
    Regards,
    Romas
  3. #83
    Apr 2006
    54
    components for lini8
    Hi Argun,
    Regards,
    Romas
    Hi Romas,
    Sorry,
    Component list attched.
    R51 an IC5's photo diode are in series, there is no difference R51 position. The differences may occur during PCB drawing.
    Regards
    Argun
  4. #84
    Mar 2009
    Hi to community (this is my first message here)
    tachus42 > I' m interesting for your project, but I like to have info about LCD displsy that you use.
    Can you propose a good type for this driver?
    thanks in advance
    excuse me for my English, I'm Greek
  5. #85
    Jul 2009
    thanks
    :banana:
  6. #86
    Aug 2009
    Tôi mới bước đầu tìm hiểu về máy cnc, xin các đàn anh chỉ giáo
  7. #87
    Jul 2005
    just redrawn schematic and PCB on Eagle.
    I added 5v from motor supply, and the layout is made for rack mount.
    Naturally TIP112 must be mounted behind PCB on alu plate.
    I hope can be useful
  8. #88
    Apr 2004
    209
    So is this a servo driver or a stepping motor driver? granted I have not gone threw all of the posted pages but still I'm wondering? Last I knew lini stepper was an opensource stepping motor driver
  9. #89
    May 2005
    1397
    berin, you are absolutely correct. The Linistepper is a stepper driver, not a servo driver. This thread apparently took a turn... LOL.
  10. #90
    Sep 2011
    4
    Lini8 charge-pump modification appears to work only for Linistepper Version 1, with Enabled is High. In Linistepper Version 2, however, Enabled is active low. Any suggestions on how to make Lini8 modifications work with Linistepper Version 2? Best regards.
  11. #91
    Sep 2011
    4
    Quote Originally Posted by agelkom View Post
    Hi Argun,
    Regards,
    Romas
    Hi Romas,
    Sorry,
    Regards
    Argun
Page 5 of 5 345
  1. Open Source Driver electronics
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 11-22-2009, 09:42 PM
  2. Any ideas for open source CAM package?
    By galacticroot in forum OpenSource Software
    Last Post: 10-22-2007, 05:35 PM
  3. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  4. 2nd Generation DeskCNC servo driver released
    By imserv in forum News Announcements
    Last Post: 11-25-2004, 01:22 AM
  5. Open source driver designs
    By pminmo in forum CNC Machine Related Electronics
    Last Post: 05-05-2004, 03:29 PM
