586,051 active members*
3,641 visitors online*
    Oct 2013
    34
    Siemens Servo
    Hello
    i got one Siemens 1HU 3056-0AF01.
    The seller has one Siemens 1HU 3056-0AF01-Z
    Im wondering what is the difference between them, what does the letter Z means?
    24221
    Re: Siemens Servo
    They most likely are identical motors with the -Z indication an option of some kind, it could be anything from a brake to a particular encoder option.
    If you can obtain a picture, at least you may be able to see if any physical differences.
    Al.
    Albert E.
    Oct 2013
    34
    Re: Siemens Servo
    Hi
    There is no Physical differences so its probably a brake or an encoder option as you say.Thank you for you help
  1. Need help about using a Siemens servo as spindle
    By Azalin in forum Benchtop Machines
    Last Post: 04-04-2015, 11:05 AM
  2. DC Brush Servo Siemens 1HU
    By Leblondmakino in forum Servo Motors / Drives
    Last Post: 02-24-2008, 09:21 AM
  3. Fanuc 401 with Siemens 1HU servo
    By Leblondmakino in forum Fanuc
    Last Post: 02-02-2008, 07:56 AM
  4. Reset Siemens servo amp
    By lizvern in forum Servo Motors / Drives
    Last Post: 09-17-2006, 05:44 AM
