586,675 active members*
3,184 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > X and Y axis problem. DOES NOT MATCH THE ACTUAL LASER HEAD
Results 1 to 20 of 26
Threaded View
    Mar 2017
    7
    Hi Guys,
    I'm quite desperate here now. After our laser cutter had skipping issues, we tried to restore the cutter to factory defaults. Once we did a restart, the head seems to be out of sync with the display and is now vibrating a lot when moving thru the y axis. Also, the X axis seems to be hitting the edges a lot. If you look at the picture with the screen, you can see that the Y axis is set to 0.0mm but the actual laser head is at the center. There is no way to move the head up and if I move it down, I can't bring it back up. The movement of the Y axis is also not smooth as compared to before. It makes loud noises whenever I move it.
    Any help or suggestion is highly appreciated.
    Hoping for your feedback!
  1. Laser head touch the left axis
    By medmouncef in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-11-2020, 03:54 PM
  2. Problem! - Laser Head going off table boundaries
    By quetzalstudio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-24-2017, 03:55 AM
  3. Decreasing the laser head transit time between actual cuts
    By vrc321 in forum Laser Control Software
    Last Post: 01-04-2017, 05:25 PM
  4. Build double head laser with motorized x axis on each head
    By amders in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2015, 02:41 PM
  5. Laser Head won't move along Y axis...
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-03-2012, 04:42 AM
