586,072 active members*
4,514 visitors online*
Page 2 of 4 1234
Results 21 to 40 of 74
  1. #21
    Mar 2014
    1131
    Re: SIEG C6 Retrofit [Ongoing]
    Yup, 1500 RPM.
    I'm glad you like it.
    Sent from my GT-I9300 using Tapatalk
  2. #22
    Mar 2014
    1131
    I finished the model for the indexing wheel. I'll be using two C3 from cnc4pc.
  3. #23
    Mar 2014
    1131
    Bad thing happened. I broke the 2mm end mill during the cutting and I had to continue with 3mm end mill. This cause a little larger slots. Do you think it will still work?
  4. #24
    Mar 2004
    1306
    Yes. The slot width makes no difference.
    Nice progress you are making.
    Mark
    Regards,
    Mark
  5. #25
    Apr 2003
    354
    I don't recall what control you're using but if it's Mach you will use only single-slot indexing.
    Milton in Tennessee ya'll!
  6. #26
    Mar 2014
    1131
    @RotarySMP thanks Mark.
    @DICKEYBIRD
    I will start with Mach which is familiar to me then I'll switch to LinuxCNC.
  7. #27
    Mar 2014
    1131
    Installed.
    How many sensors do I need? I see some use 2 and some use 3.
  8. #28
    Mar 2004
    1306
    One for the index slot, and then either another onefor pulse, or two for the pulse, spaced 90° of tooth phase apart, which would give you a quadrature signal. This means 4x resolution verses the single pulse signal, and the machine controller will be able to sense direction of rotation, which it can't off a single pulse.
    http://www.dynapar.com/Technology/En...ature_Encoder/
    Mark
    Regards,
    Mark
  9. #29
    Mar 2014
    1131
    Thanks Mark.
    The spindle will turn only in one direction so I need 2 sensors?
  10. #30
    Mar 2004
    1306
    I used a similar encoder on my Boley
    Boley 4L
    Post #18
    I planned for three sensors, but also only have two connected. ~50 tooth rev seems to work fine under LinuxCNC.
    Mark
    Regards,
    Mark
  11. #31
    Mar 2014
    1131
    Thanks Mark.
    Here's a short video of cutting the indexing wheel.
    https://youtu.be/uYWlWoIMuuI
  12. #32
    Mar 2014
    1131
    Just received the telescopic ball screw covers.
    Attached Thumbnails Attached Thumbnails IMG_20170531_142240.jpg   IMG_20170531_142240.jpg
  13. #33
    Mar 2014
    1131
    Small update after my last post.
    I've finally finished the housings for the telescopic ball screw covers.
    And I've added an oil nipple for the Z axis ball nut.
  14. #34
    Mar 2014
    1131
    I decided to use these connectors for the steppers and spindle motor. I also have military type expensive connectors but I like these more. 10 amps rated each pin.
    Attached Thumbnails Attached Thumbnails IMG_20170620_105535.jpg   IMG_20170620_105550.jpg
  15. #35
    Apr 2003
    354
    You're making great progress!
    Do you have a link to the supplier of those connectors?
  16. #36
    Mar 2014
    1131
    Thanks.
    I got these connectors from an online store in Turkey. I don't know if they ship overseas but here's the links:
    Female socket:
    Mete 403012 5x10A Çok Kontaklı Eğik Makine-Online Satış
    Male plug:
    Mete 403019 5x10A Çok Kontaklı Fiş-Online Satış
    These are made in Turkey but I've seen very similar ones (actually identical) on ebay from the Chinese.
    Same connector used on a spindle:
    TOP 3KW ER20 AIR-COOLED SPINDLE MOTOR & 3KW INVERTER DRIVE VFD FOUR BEARING | eBay
  17. #37
    Mar 2014
    1131
    Not the same but similar.
    6 PIN CONECTOR SET INDUSTRIAL AND CNC 600V 6A SOVIET MADE SILVER PLATE
  18. #38
    Apr 2003
    354
    Thanks, much appreciated!
  19. #39
    Mar 2014
    1131
    Time for an update. I needed a 500x500x300 electronics box but these dimensions are very uncommon. So I had to made mine.
    I added two place for 120mm computer fan for inner circulation. One will blow fresh air from outside-to-inside and other will blow the air from inside-to-outside.
    I've used hammered silver paint.
    Edit: I've used about 170 blind rivets. My right hand still hurts.
  20. #40
    Mar 2014
    1131
    Now it's time to setup the electronics. I'll be using a C11GS at first but will add an ESS and a C24 board to have more inputs.
    Nice that the power supply for the X axis stepper is DIN rail type. Also, I'll be looking for a good rail adapter for the stepper drivers. There are tons of adapters on the net but I don't know which one to buy.
    Attached Thumbnails Attached Thumbnails IMG_4163.JPG   IMG_4164.JPG   IMG_4165.JPG
Page 2 of 4 1234
  1. Sieg SX3 6000rpm retrofit kit for mach3
    By slektning in forum Benchtop Machines
    Last Post: 01-28-2010, 06:08 AM
  2. Replies: 31
    Last Post: 11-27-2008, 06:55 AM
  3. SIEG X3 Budget DIY CNC Conversion Ongoing Project Summary
    By Ninhil in forum X3/SX3/G0619/G0463
    Last Post: 03-07-2007, 01:26 AM
  4. SIEG rotary table retrofit
    By ints99 in forum Syil Products
    Last Post: 12-17-2006, 06:11 AM
  5. CNC Retrofit for Sieg X2... KDN Tool?
    By Zippi in forum Benchtop Machines
    Last Post: 01-19-2006, 09:27 AM
