586,058 active members*
4,263 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas overrides Something weird ?!?
Results 1 to 7 of 7
    Jun 2012
    125
    We have 6 Haas machines. On 5 of them when using the buttons to override the feed % it will increment to 200% at the highest. On one of them we had an operator discover that if you keep pressing the +10 button it will run all the way 999%.
    Is there a way to change the percent max to match the 200% like my other machine?
    Mar 2010
    1852
    Re: Haas overrides Something weird ?!?
    I'm betting that machine is your newest one or has the latest software! I ran a newer one that did that, I liked it.
    Mike
    Jun 2012
    125
    Quote Originally Posted by Machineit View Post
    Mike
    It is a 1999 machine that has recently had a software update to 11.24F. I dont like it because the operators on second shift dont always catch that kind of item and have broken cutters. They have just pressed the + button for so many years that they dont even notice that they are 400% feed rate and not 200% that is alot of speed change. I just want to know what bit to change to make it 200% max again.
    Mar 2010
    1852
    Probably have to change your software back. I wish I could get it!
    Mike
    Oct 2010
    171
    Might check Settings 88 and possibly 144.
    PM
    Jun 2003
    1365
    I'm 99% sure mine goes way over 200% as well. It might go to 400, but I can't recall, I don't generally crank it up that high.
    Mar 2014
    133
    It's your machine vintage/software. Machineit is correct. Does this machine have a run,setup/memory keys on the operators pendant? What I mean by keys is actually keys like to you house door key. Not the button/keyboard keys. Anyway, you also have some override settings that you can setup your machine at limited feed rates,jogging feed rates, tool changes, rapids %'s, etc. Hope this helps because chances are your local HFO will not change the software. The only reason why I say this is the versoin software you have probably fixed some known glitches in your previous versions of software.
  1. Reset Feed & RPM overrides with gcode
    By scott216 in forum Tormach PathPilot™
    Last Post: 11-18-2015, 10:56 PM
  2. Predator overrides
    By robrea in forum BobCad-Cam
    Last Post: 05-27-2010, 05:04 PM
  3. Weird?
    By Klox in forum Uncategorised CAM Discussion
    Last Post: 11-19-2003, 05:04 AM
