586,060 active members*
4,042 visitors online*
Thread: diy rails
    Feb 2017
    6
    diy rails
    what about using this diy istead of supported rails !?
    my frame will be alumium 40*80
    i will use it in 3d printer or router
    Sent from my ASUS_Z00A using Tapatalk
    Feb 2006
    210
    They should work fine, but use too many bearings. Look up the skate bearings on conduit threads. They work very early
    Well and are cheap and easy. Many will say you must have 'real' linear bearings tondo any real work. That's fine but my router has been running for 11 years on conduit and skate bearings. It's run about 3 hours today. I wear out routers, not bearings or conduit. Accuracy is excellent, maybe 3 or 4 thou but mostly unmeasurable. I cut mostly plywood and oak, with the occasional aluminum.
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    1943
    Re: diy rails
    Quote Originally Posted by beone View Post
    I've been thinking about a router build and would love to see a picture of your machine.
    Feb 2017
    6
    Re: diy rails
    can i see photo of your machine!?
  1. Rails - Rails
    By Autonow in forum Linear and Rotary Motion
    Last Post: 04-26-2011, 07:07 PM
  2. THK Rails
    By baithog in forum DIY CNC Router Table Machines
    Last Post: 08-03-2010, 04:37 PM
  3. Thomson Bars, V-Rails, or Linear Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-18-2009, 09:39 AM
  4. How many rails?
    By sp1nm0nkey in forum Linear and Rotary Motion
    Last Post: 10-21-2007, 07:47 PM
  5. Design of plasma table, high rails or low rails?
    By Apples in forum Waterjet General Topics
    Last Post: 12-18-2006, 09:21 PM
