586,108 active members*
3,293 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need Al_The_Man's Help!!!
    Mar 2010
    813
    Hi Al,
    On my Huanyang VFD with out Amps set for display I receive 0.0 to 0.3 averagely. How am I to interpret this? Is this additional Amps to my set amps in (PD142). I can't imagine it being my total amp draw when running.
    Thanks in Advance,
    Dan
    Anyone else with a answer will be extremely appreciated.
    24221
    Re: Need Al_The_Man's Help!!!
    I don't have the manual where I am right now, but IIRC PD142 just sets the plate current of the motor so you don't exceed it an possibly burn the motor out.
    I will check later.
    Are you talking front read out or the analogue meter output?
    Al.
    Albert E.
    Mar 2010
    813
    I will check later.
    Al.
    The front read out. On the huanyang there is a display choice for this "out amps" there's also a read for modbus for out amps both displaying the same. Just not sure how to interpret the read. It increases and decreases while spindle spins up or down. Making cuts it increases as well, been deliberately making deep cuts and went up as far as 1.6. but under no load it's 0.0 - 0.3.
    Been searching the internet and learned a lot with running and full load amps but still no answer. I knew you were the best choice to get close. Thanks or your reply and have a Happy Easter Sunday!
    Dan
    Sep 2019
    15
    Al I need your help also!! My name is also AL . I can’t get the website to work properly on my phone. That’s not my issue but that’s why I can’t contact you. I have a Fanuc on question. [email protected],
    Thanks in Advance,
    Dan
    Anyone else with a answer will be extremely appreciated.[/QUOTE]
  1. For Al_The_Man
    By h3ndrix in forum CNC Machine Related Electronics
    Last Post: 03-23-2004, 05:07 PM
