586,043 active members*
3,687 visitors online*
Page 1 of 3 123
Results 1 to 20 of 56
    Jan 2009
    234
    $100 China Made ETS's on Ebay ??
    The $100 China Electronic Tool Setters "CNC Tool Presetter" Anyone use One?
    I think the Tormach's is Normally Open Can anyone Confirm? They Sell both on NO and NC
    Must Specify Type?
    Type:
    1,Normally open with stroke protection and blowing
    2,Normally open with stroke protection
    3,Normally closed with stroke protection and blowing
    4,Normally closed with stroke protection.
    Before you paid it,pls contact which type you want
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
    Aug 2007
    701
    Re: $100 China Made ETS's on Ebay ??
    I was seriously thinking of getting one of these. I am surprised no one here has posted about it.
    CNC Tool Presetter, Automatic CNC Tool Setting Gauge for Z Axis a
    Jan 2009
    234
    brianbonedoc,
    I think the one in your link is a Normally Closed Passive the Tormach ETS under specs says "Normally Open Sensing Logic" Manual Says both the Digitizing Probe & ETS are Active High = Open.
    I cannot find the PDF i was reading have read a bunch, but I think Tormach Says Wire Their ETS on the accessory plug...
    Din ETS
    Pin 3 +12V
    Pin 4 0V
    Pin 5 Signal
    The manual also says if you jumper pin 4 & 5 the accessory indicator in the software will activate to test port. So this is telling me it is Normally Open.
    So the 66A Tool Setter is Normaly Open 10-24V Input.
    Aug 2007
    701
    Yeah my passive probe (renishaw mp3) is normally closed. It uses the same circuitry so the tool presenter would be the same NC I believe. I didn't look at the specs too much as there are a bunch pretty similar. I still think it's worth a shot. Why don't u be the guinea pig?
    Jan 2009
    234
    Ok, May be Worth Being a Gunea Pig... From the Path Pilot screen ETC Uses the same settings as the active probe.
    Ebay seller wanted 130 for the NO one so Went with This One $99.99 on aliexpress...
    So We shall find out in 12-20 Days...
    Aug 2007
    701
    Can't wait to see how this works out. Too bad pathpilot can't measure tools while in he middle of a program like mach3 could.
    Sep 2005
    1195
    Hello,
    How to use this ETS? Is there utube link to this ETS...
    Is this the same as cnc z probe Click image for larger version.
Name:	Z probe.jpg
    Jun 2012
    311
    Tormach will work with either NO or NC. It has to be configured to one or the other, see the manual. Passive probe is NC, the more expensive one is NO. I believe their tool setter is NO.
    I bought a second passive probe to use as a tool setter. Made a base with magnets to hold it to the table as well as a touch pad to replace the stylus.
    Jan 2009
    234
    It just passed thru customs in SFO and Accepted by USPS so should be here this weekend or early next week.
    Jan 2009
    234
    Ahhh Duplicate Post!
    Apr 2016
    109
    Quote Originally Posted by Contract_Pilot View Post
    Awesome. We're waiting to hear how it works. Here are some other (relatively) inexpensive ideas:
    I already have a Wildhorse probe. It works far better than any $100 probe has a right to. With an hour of fighting with it I've been getting consistent results to within a few tenths. Which is fine for a Tormach. Sure, it may not remain accurate forever but it's $100. Also Keen's new ITTP should be available soon.
    Second thing: The Wildhorse probes come with an optional kit that makes them a toolsetter and they already have the Tormach plug on them. Just plug and go. But the Chinese one you are getting is a little more purpose built sensible design and shape for a toolsetter.
    Third: Your post reminded me of several products that Millfast makes that let you keep your probe and toolsetter plugged in at the same time. $100 probe, $100 toosetter, $100 dual adapter = $300 for full probing of parts and tools hooked up full time.
    That's less money than one manual Haimer probe. Interesting.
    Here's the link to the Millfast adapters:
    Adapters
    Mar 2013
    344
    Ditto on the Wildhorse.
    Jan 2009
    234
    Advil, The China one is Active NC (Like the Tormach) not Passive NC like the others.
    Jan 2009
    234
    It Arrived Today see Unboxing and Photos Here Waiting on the Din Connector to arrive... should be in Saturday!! Then the Fun Of Testing it Begins!
    Mar 2006
    36
    Looks like you have it going in your blog. How is it working out?
    Mike
    Jan 2009
    234
    Seems to work been busy with getting the shop in order no time to play with it.
    Jan 2009
    234
    I got to play yesterday or last night .0005 or less repeatability.. not bad will do further testing. but so far worth $100.00 expect a video in a week or 2 if i have the time.
    Dec 2016
    37
    How did you get on with testing this?
    Looks interesting.
    Jan 2009
    234
    Have been busy have not had any time to play mess with it other than touching off a few tools setting up a test indicator and repeating it.
    Apr 2005
    419
    Can you give me some pointers on wiring it? I have the 6-wire NO version (sk-66a-kc) and I'm putting 24V across red/grey but the brown/orange circuit seems to be open and there is no LED regardless of the state of the ETS.
Page 1 of 3 123
  1. Made in china
    By lout63 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2011, 08:27 AM
  2. buying a tube from china (ebay)
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-23-2010, 04:16 PM
  3. Machines made in China
    By vernonpurcell in forum Bending, Forging, Extrusion...
    Last Post: 03-27-2008, 05:59 AM
  4. Made in Australia (Made in taiwan, china)
    By carbidecraters in forum MetalWork Discussion
    Last Post: 01-10-2006, 09:05 PM
  5. Starrett made in China?
    By CNCBoss in forum Community Club House
    Last Post: 05-16-2005, 10:48 PM
