586,060 active members*
4,592 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > China NEMA 34 motor kit problems
Page 2 of 3 123
Results 21 to 40 of 44
  1. #21
    Jun 2005
    1730
    Re: China NEMA 34 motor kit problems
    Trell,
    You might want to use a standard ethernet cable, most newer cards can work and determine where transit and receive are automatically. I had several cross over cable that were actually missing several wires, I could not understand why they were not working correctly and I buzzed them out and low and behold several ways were not actually used in the cable. I got a standard ethernet cable that I tested on my home computer and pulled that in and all worked as expected. Just a thought.
    Russ
  2. #22
    Aug 2015
    142
    I use it mine with an standard cable , in a router , and it see it.
    There is an app who see if u connect tha uc300 eth , use that and config the ip of uc300eth with ur system
  3. #23
    Mar 2007
    113
    Got the UC300ETH from CNC4PC.com with there C10 break outboard and got everything running with 150 IMP with no issues but one.
    I am using ger21 screen set 2010 for tool touch off. I get the "Probe Active" light to come on when touching the tool in the router but it will not stop the the Z axis. Anyone got a ideal about this one.
    Feels good to get the CNC running again. Don't think I will ever build another cnc without a UC300ETH.
  4. #24
    What version of Mach3?
    What version of UC300ETH plugin?
    Are you running the 2010 macros?
    Is there any message displayed on the screen?
    I can install Mach3 on my laptop and go test this with my UC300ETH and see if I can duplicate it.
  5. #25
    Mar 2007
    113
    Ver R3.043.066 for mach3
    V1.006 for UC300ETH
    On starting Mach3 I do get some errors messages about DLL defective. Reload. Then UC100 V2_148.dll defective plug-in found ignoring.
    Uc300 V1_054.dll defective plug-in found ignoring.
    UC300 V1_056.dll. Defective plug-in found ignoring
    After hitting OK on the errors Mach3 will open and work.
    Working on a Vista machine
  6. #26
    Try changing Mach3 to 3.043.062
    You can download it from the FTP site:
    ftp://anonymous:[email protected]/
    Also, go into your Mach3\plugins folders and delete thos other plugins that are causing the error messages. You should only have the UC300ETH plugin in there.
  7. #27
    Try this plugin.
    Attached Files Attached Files
  8. #28
    Mar 2007
    113
    Got all the opening errors fixed. Thanks for that fix.
    Downloaded the Mach3 software and installed. Still will not stop the Z axis
  9. #29
    Try the new plugin I just posted.
    Make sure you delete the old one.
  10. #30
    Mar 2007
    113
    ger21, the wizard of the CNC.... looks like that fixed it right up.
    The Z axis downward movement on the first touch is as fast as it was but the 2nd downward movement is super slow like may .01 IMP. Is there a way I can make the 2nd movement a little faster?
  11. #31
    Mar 2007
    113
    Never mind it works fine TY for all the help
  12. #32
    Mar 2007
    113
    https://youtu.be/AXbGxwkzanY
    CNC running at 150 IPM wow it os so smooth compared to just a breakout board. Thanks for ever ones help.
  13. #33
    Mar 2007
    113
    Well, it is running a lot better, but having a issue with running a gcode
    When running a table leveling g code the CNC will stall but just sometimes. Driving me crazy. It will happen on the x axis most of the time but in different places.
    I have already checked the obvious problems and everything is free
    Anyone have any ideas??
  14. #34
    Aug 2015
    142
    If the cnc stalls then is aproblem with speed of stepers , what is voltage u use for driver ?
    The motors i think have low internal resistance , and they need high voltage in order to achive a high rpm .
  15. #35
    Mar 2007
    113
    Yes you are right. The stepper motors do need high voltage for speed but the CNC will stall at 80 IPM or at 130 IPM. I will try 50 I PM and see if that helps
  16. #36
    Try a higher microstep setting. It may be a resonance issue.
  17. #37
    Mar 2007
    113
    Ok got the step on the drive set to 10k and the step per inch set to 51055.369. Seems crazy but I have run two table level passes with no missed steps. Will do more testing tomorrow https://uploads.tapatalk-cdn.com/201...db02399418.jpg
    Hoping it keeps working
  18. #38
    Mar 2007
    113
    Seems like the CNC has stopped missing steps but nut got another issue.
    When running a square with gcode the cnc will round three of the four corners. When I run a sim in Vcrave everything looks fine and square but does not cut that way. Any one know what causes that. https://uploads.tapatalk-cdn.com/201...96a50c9fa6.jpg
  19. #39
    CV mode in Mach3.
    In General Config, enable "Stop CV on Angles >" and set it to 89.
  20. #40
    Mar 2007
    113
    Yep the CNC whisper done it again. Fixed it. Thanks again https://uploads.tapatalk-cdn.com/201...9543e73528.jpg
Page 2 of 3 123
  1. Wantai Nema 34 stepper motor kit. Problems.
    By Jussi_2 in forum Stepper Motors / Drives
    Last Post: 12-16-2017, 04:48 PM
  2. Stepper motor upgrade NEMA 34 or NEMA 42?
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2015, 04:59 AM
  3. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  4. Problems with Nema 23 570 oz/in step motor
    By brogger00 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-22-2011, 01:51 PM
