Hi Guys,
I have a 1995 VMC15, 7500rpm 15hp. The problem is I will throw the main power switch and and the electrics in the rear panel will come on but I push the green on/brownout button and the controller will not come on. I checked continuity on the switch, fine. I don't see any of the LED lights in the side panel coming on. all the fuses look good. Could it be the 12v power supply is shot? Wouldn't I still hear the relay snap on when I hit the green button even if the 12v power supply was bad or is that interlocked to it?
Any help is appreciated.
Josh
