586,058 active members*
4,449 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > Alternatives to "Solar flux" stainless welding flux?
    Feb 2007
    I'm trying to weld thin gage stainless and it's a more feasible option to use a flux rather than to purge. I'd like to know if there's any cheaper fluxes out there than solar flux. Perhaps a flux intended for brazing/welding? I can't find the temp. range for solar flux so if anyone knows that info, I'd appreciate it.
    Thanks.
    Feb 2007
    5
    are you trying to gas weld s/s?
    In my experience s/s does't like heat, if you gas weld it I'm quit sure you will not like what happens.
    If you can tig weld it that will work much better for you, I allways use argon.
    Hope this helps
    Nov 2006
    251
    I believe there is a silver solder and flux you can use but i cant for the life of me remember there grades and names but I can remember silver soldering carbide strips on pump blades years ago and it was quite successful.If you feather a neautral flame on your oxy you might find reasonable results without any flux at all with that 1mm thick sheet.Regards greg b
  1. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  2. QDJ Series Great Flux Portal Precision Oil-Filtering Dispenser
    By fire4427zlm in forum News Announcements
    Last Post: 02-10-2007, 02:37 AM
  3. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
  4. How do I fix 4"x1/4" flat to 3"x3"x1/8 box without welding?
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 10-18-2005, 02:18 PM
