586,080 active members*
3,722 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Circles not coming out the right size
Results 1 to 17 of 17
    Feb 2017
    10
    I know this is another circle problem but I have searched through this forum and still haven't been able to solve my problem.
    First off I make Fidget Spinners out of wood. I use Fusion 360 to create the design then I export it as .dxf file into Aspire 8.5 then I use the post processor there to create the G code I use in Mach3.
    I make fidget spinners out of wood (eventually I want to upgrade to making them out of aluminum) that use skateboard bearings in them and the holes I need to cut out have to be almost exactly 22mm in diameter the wood I'm using right now is just some cheap poplar that's 1/4" or 19.05mm thick.
    The problem I'm having is when I pocket the circles they are right around .4mm too short in the x and .3mm short in the y axis, the circles themselves are somewhat round so that's good except for them being too short. I was hoping someone would know what I could do to fix this.
    I am using a Romaxx HS-1 machine, that is level and square I checked that out to make sure. Everything on the machine seems very solid and well built no slop in the x and y axis. Though there is some slop in the z axis that if I grab the bottom of it I can tip it about 2mm so I don't know if that would cause a problem or not and I don't know how to fix it.
    I'm using G Code (mm) (*.tap) and since everything in mach3 is set up in inches I'm putting G21 in the code to switch it to metric because that's what I work in all the time.
    I have tried turning backlash off which didn't help and I've messed around with CV a little bit but it's a little tough to understand.
    Here's some other stuff that might help out.
    Bit 6mm 4 flute tian coated
    pass depth 2mm
    step over 25%
    spindle speed I have a dwalt router set on #3
    feed rate 13.33 mm/sec
    plunge rate 10 mm/sec
    If you need any other info please let me know. I know there's some magic man/woman out there that can help me. lol
    P.S.
    Here is a quick cut I did in particle board of one of my spinners. I exported it from fusion 360 into aspire 8.5 then made the g code there. I only cut 2mm deep just to show you what it would look like.
    All of the holes should be 22mm in diameter
    The height should be 80.163mm
    The width should be 87.599mm
    Also here is the G code for the spinner.
    Feb 2009
    192
    Re: Circles not coming out the right size
    This is a common problem and is easily remedied. But first I must ask this question, have you calibrated your machine axis? If your answer is NO then you need to perform this step and this screen is available using the ALT-6 key combination. It's a straight forward procedure whereas you select the axis calibration button located just above the RESET button.
    I use a little test program to machine a 6 inch (my primary units) square and then actually measure the X and Y result. If it's of some value other than programmed select the faulty axis and simply enter the measured distance. Mach3 will adjust your motor steps to provide the desired outcome.
    Jul 2016
    660
    How thick is the material you want to be cut? do you really want to use a 6mm bit on such a small output to be machined? I do think if you use a 1/8 end mill do to just outlining stuff would be more efficient than pocketing specially aluminum material, it gets the job done faster to just cut it than pulverizing the whole circle though.
    Jul 2016
    660
    Try this code sir >>>> Spinner Sample
    If I were to load the file on our CNC machine using a 6mm size bit it will cut precisely on your desired measurements (22mm dia X 80.16mm height) or copy paste this code on a notepad then load it directly to MACH 3
    if it`s still offset then I guess you need to recalibrate your machine sir.
    Note: this code has 1mm pass with 1000 FRO 1000 Plunge rate, it`s only good for testing on wood because on aluminum it needs to have a 0.2-0.5mm pass for it not to stress the spindle motor or the tool bit itself. it had a 10mm deep cut because I dont know yet what`s your desired cut depth on your material.
    Code:
    (KH0UJ)
    ( T0 : 0.0 )
    G21 G90 G91.1 G64 G40
    G0 Z-3.0
    ( T0 : 0.0 )
    T0 M6
    ( 1 )
    G17
    M3 S1000
    G0 X0.0 Y8.0141
    G1 F1000.0 Z0.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.9983 Y-0.5032
    G1 X-7.9509 Y-1.0044
    G1 X-7.8722 Y-1.5017
    G1 X-7.7623 Y-1.993
    G1 X-7.6219 Y-2.4765
    G1 X-7.4513 Y-2.9502
    G1 X-7.2514 Y-3.4122
    G1 X-7.0228 Y-3.8608
    G1 X-6.7666 Y-4.2942
    G1 X-6.4836 Y-4.7106
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-4.7106 Y-6.4836
    G1 X-4.2942 Y-6.7666
    G1 X-3.8608 Y-7.0228
    G1 X-3.4122 Y-7.2514
    G1 X-2.9502 Y-7.4513
    G1 X-2.4765 Y-7.6219
    G1 X-1.993 Y-7.7623
    G1 X-1.5017 Y-7.8722
    G1 X-1.0044 Y-7.9509
    G1 X-0.5032 Y-7.9983
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 2 )
    S1000
    G1 Z-1.0
    G1 X0.5032 Y7.9983
    G1 X1.0044 Y7.9509
    G1 X1.5017 Y7.8722
    G1 X1.993 Y7.7623
    G1 X2.4765 Y7.6219
    G1 X2.9502 Y7.4513
    G1 X3.4122 Y7.2514
    G1 X3.8608 Y7.0228
    G1 X4.2942 Y6.7666
    G1 X4.7106 Y6.4836
    G1 X5.1084 Y6.175
    G1 X5.486 Y5.842
    G1 X5.842 Y5.486
    G1 X6.175 Y5.1084
    G1 X6.4836 Y4.7106
    G1 X6.7666 Y4.2942
    G1 X7.0228 Y3.8608
    G1 X7.2514 Y3.4122
    G1 X7.4513 Y2.9502
    G1 X7.6219 Y2.4765
    G1 X7.7623 Y1.993
    G1 X7.8722 Y1.5017
    G1 X7.9509 Y1.0044
    G1 X7.9983 Y0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y-0.5032
    G1 X7.9509 Y-1.0044
    G1 X7.8722 Y-1.5017
    G1 X7.7623 Y-1.993
    G1 X7.6219 Y-2.4765
    G1 X7.4513 Y-2.9502
    G1 X7.2514 Y-3.4122
    G1 X7.0228 Y-3.8608
    G1 X6.7666 Y-4.2942
    G1 X6.4836 Y-4.7106
    G1 X6.175 Y-5.1084
    G1 X5.842 Y-5.486
    G1 X5.486 Y-5.842
    G1 X5.1084 Y-6.175
    G1 X4.7106 Y-6.4836
    G1 X4.2942 Y-6.7666
    G1 X3.8608 Y-7.0228
    G1 X3.4122 Y-7.2514
    G1 X2.9502 Y-7.4513
    G1 X2.4765 Y-7.6219
    G1 X1.993 Y-7.7623
    G1 X1.5017 Y-7.8722
    G1 X1.0044 Y-7.9509
    G1 X0.5032 Y-7.9983
    G1 X0.0 Y-8.0141
    G1 X-1.993 Y-7.7623
    G1 X-5.1084 Y-6.175
    G1 X-5.486 Y-5.842
    G1 X-5.842 Y-5.486
    G1 X-6.175 Y-5.1084
    G1 X-7.7623 Y-1.993
    G1 X-8.0141 Y0.0
    G1 X-7.9983 Y0.5032
    G1 X-7.9509 Y1.0044
    G1 X-7.8722 Y1.5017
    G1 X-7.7623 Y1.993
    G1 X-7.6219 Y2.4765
    G1 X-7.4513 Y2.9502
    G1 X-7.2514 Y3.4122
    G1 X-7.0228 Y3.8608
    G1 X-6.7666 Y4.2942
    G1 X-6.4836 Y4.7106
    G1 X-6.175 Y5.1084
    G1 X-5.842 Y5.486
    G1 X-5.486 Y5.842
    G1 X-5.1084 Y6.175
    G1 X-4.7106 Y6.4836
    G1 X-4.2942 Y6.7666
    G1 X-3.8608 Y7.0228
    G1 X-3.4122 Y7.2514
    G1 X-2.9502 Y7.4513
    G1 X-2.4765 Y7.6219
    G1 X-1.993 Y7.7623
    G1 X-1.5017 Y7.8722
    G1 X-1.0044 Y7.9509
    G1 X-0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 3 )
    S1000
    G1 Z-2.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.7623 Y-1.993
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-1.993 Y-7.7623
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 4 )
    S1000
    G1 Z-3.0
    G1 X0.5032 Y7.9983
    G1 X1.0044 Y7.9509
    G1 X1.5017 Y7.8722
    G1 X1.993 Y7.7623
    G1 X2.4765 Y7.6219
    G1 X2.9502 Y7.4513
    G1 X3.4122 Y7.2514
    G1 X3.8608 Y7.0228
    G1 X4.2942 Y6.7666
    G1 X4.7106 Y6.4836
    G1 X5.1084 Y6.175
    G1 X5.486 Y5.842
    G1 X5.842 Y5.486
    G1 X6.175 Y5.1084
    G1 X6.4836 Y4.7106
    G1 X6.7666 Y4.2942
    G1 X7.0228 Y3.8608
    G1 X7.2514 Y3.4122
    G1 X7.4513 Y2.9502
    G1 X7.6219 Y2.4765
    G1 X7.7623 Y1.993
    G1 X7.8722 Y1.5017
    G1 X7.9509 Y1.0044
    G1 X7.9983 Y0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y-0.5032
    G1 X7.9509 Y-1.0044
    G1 X7.8722 Y-1.5017
    G1 X7.7623 Y-1.993
    G1 X7.6219 Y-2.4765
    G1 X7.4513 Y-2.9502
    G1 X7.2514 Y-3.4122
    G1 X7.0228 Y-3.8608
    G1 X6.7666 Y-4.2942
    G1 X6.4836 Y-4.7106
    G1 X6.175 Y-5.1084
    G1 X5.842 Y-5.486
    G1 X5.486 Y-5.842
    G1 X5.1084 Y-6.175
    G1 X4.7106 Y-6.4836
    G1 X4.2942 Y-6.7666
    G1 X3.8608 Y-7.0228
    G1 X3.4122 Y-7.2514
    G1 X2.9502 Y-7.4513
    G1 X2.4765 Y-7.6219
    G1 X1.993 Y-7.7623
    G1 X1.5017 Y-7.8722
    G1 X1.0044 Y-7.9509
    G1 X0.5032 Y-7.9983
    G1 X0.0 Y-8.0141
    G1 X-1.993 Y-7.7623
    G1 X-5.1084 Y-6.175
    G1 X-5.486 Y-5.842
    G1 X-5.842 Y-5.486
    G1 X-6.175 Y-5.1084
    G1 X-7.7623 Y-1.993
    G1 X-8.0141 Y0.0
    G1 X-7.9983 Y0.5032
    G1 X-7.9509 Y1.0044
    G1 X-7.8722 Y1.5017
    G1 X-7.7623 Y1.993
    G1 X-7.6219 Y2.4765
    G1 X-7.4513 Y2.9502
    G1 X-7.2514 Y3.4122
    G1 X-7.0228 Y3.8608
    G1 X-6.7666 Y4.2942
    G1 X-6.4836 Y4.7106
    G1 X-6.175 Y5.1084
    G1 X-5.842 Y5.486
    G1 X-5.486 Y5.842
    G1 X-5.1084 Y6.175
    G1 X-4.7106 Y6.4836
    G1 X-4.2942 Y6.7666
    G1 X-3.8608 Y7.0228
    G1 X-3.4122 Y7.2514
    G1 X-2.9502 Y7.4513
    G1 X-2.4765 Y7.6219
    G1 X-1.993 Y7.7623
    G1 X-1.5017 Y7.8722
    G1 X-1.0044 Y7.9509
    G1 X-0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 5 )
    S1000
    G1 Z-4.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.7623 Y-1.993
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-1.993 Y-7.7623
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 6 )
    S1000
    G1 Z-5.0
    G1 X0.5032 Y7.9983
    G1 X1.0044 Y7.9509
    G1 X1.5017 Y7.8722
    G1 X1.993 Y7.7623
    G1 X2.4765 Y7.6219
    G1 X2.9502 Y7.4513
    G1 X3.4122 Y7.2514
    G1 X3.8608 Y7.0228
    G1 X4.2942 Y6.7666
    G1 X4.7106 Y6.4836
    G1 X5.1084 Y6.175
    G1 X5.486 Y5.842
    G1 X5.842 Y5.486
    G1 X6.175 Y5.1084
    G1 X6.4836 Y4.7106
    G1 X6.7666 Y4.2942
    G1 X7.0228 Y3.8608
    G1 X7.2514 Y3.4122
    G1 X7.4513 Y2.9502
    G1 X7.6219 Y2.4765
    G1 X7.7623 Y1.993
    G1 X7.8722 Y1.5017
    G1 X7.9509 Y1.0044
    G1 X7.9983 Y0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y-0.5032
    G1 X7.9509 Y-1.0044
    G1 X7.8722 Y-1.5017
    G1 X7.7623 Y-1.993
    G1 X7.6219 Y-2.4765
    G1 X7.4513 Y-2.9502
    G1 X7.2514 Y-3.4122
    G1 X7.0228 Y-3.8608
    G1 X6.7666 Y-4.2942
    G1 X6.4836 Y-4.7106
    G1 X6.175 Y-5.1084
    G1 X5.842 Y-5.486
    G1 X5.486 Y-5.842
    G1 X5.1084 Y-6.175
    G1 X4.7106 Y-6.4836
    G1 X4.2942 Y-6.7666
    G1 X3.8608 Y-7.0228
    G1 X3.4122 Y-7.2514
    G1 X2.9502 Y-7.4513
    G1 X2.4765 Y-7.6219
    G1 X1.993 Y-7.7623
    G1 X1.5017 Y-7.8722
    G1 X1.0044 Y-7.9509
    G1 X0.5032 Y-7.9983
    G1 X0.0 Y-8.0141
    G1 X-1.993 Y-7.7623
    G1 X-5.1084 Y-6.175
    G1 X-5.486 Y-5.842
    G1 X-5.842 Y-5.486
    G1 X-6.175 Y-5.1084
    G1 X-7.7623 Y-1.993
    G1 X-8.0141 Y0.0
    G1 X-7.9983 Y0.5032
    G1 X-7.9509 Y1.0044
    G1 X-7.8722 Y1.5017
    G1 X-7.7623 Y1.993
    G1 X-7.6219 Y2.4765
    G1 X-7.4513 Y2.9502
    G1 X-7.2514 Y3.4122
    G1 X-7.0228 Y3.8608
    G1 X-6.7666 Y4.2942
    G1 X-6.4836 Y4.7106
    G1 X-6.175 Y5.1084
    G1 X-5.842 Y5.486
    G1 X-5.486 Y5.842
    G1 X-5.1084 Y6.175
    G1 X-4.7106 Y6.4836
    G1 X-4.2942 Y6.7666
    G1 X-3.8608 Y7.0228
    G1 X-3.4122 Y7.2514
    G1 X-2.9502 Y7.4513
    G1 X-2.4765 Y7.6219
    G1 X-1.993 Y7.7623
    G1 X-1.5017 Y7.8722
    G1 X-1.0044 Y7.9509
    G1 X-0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 7 )
    S1000
    G1 Z-6.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.7623 Y-1.993
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-1.993 Y-7.7623
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 8 )
    S1000
    G1 Z-7.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.7623 Y-1.993
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-1.993 Y-7.7623
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 9 )
    S1000
    G1 Z-8.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.7623 Y-1.993
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-1.993 Y-7.7623
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 10 )
    S1000
    G1 Z-9.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.7623 Y-1.993
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-1.993 Y-7.7623
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 11 )
    S1000
    G1 Z-10.0
    G1 X-0.5032 Y7.9983
    G1 X-1.0044 Y7.9509
    G1 X-1.5017 Y7.8722
    G1 X-1.993 Y7.7623
    G1 X-2.4765 Y7.6219
    G1 X-2.9502 Y7.4513
    G1 X-3.4122 Y7.2514
    G1 X-3.8608 Y7.0228
    G1 X-4.2942 Y6.7666
    G1 X-4.7106 Y6.4836
    G1 X-5.1084 Y6.175
    G1 X-5.486 Y5.842
    G1 X-5.842 Y5.486
    G1 X-6.175 Y5.1084
    G1 X-6.4836 Y4.7106
    G1 X-6.7666 Y4.2942
    G1 X-7.0228 Y3.8608
    G1 X-7.2514 Y3.4122
    G1 X-7.4513 Y2.9502
    G1 X-7.6219 Y2.4765
    G1 X-7.7623 Y1.993
    G1 X-7.8722 Y1.5017
    G1 X-7.9509 Y1.0044
    G1 X-7.9983 Y0.5032
    G1 X-8.0141 Y0.0
    G1 X-7.7623 Y-1.993
    G1 X-6.175 Y-5.1084
    G1 X-5.842 Y-5.486
    G1 X-5.486 Y-5.842
    G1 X-5.1084 Y-6.175
    G1 X-1.993 Y-7.7623
    G1 X0.0 Y-8.0141
    G1 X0.5032 Y-7.9983
    G1 X1.0044 Y-7.9509
    G1 X1.5017 Y-7.8722
    G1 X1.993 Y-7.7623
    G1 X2.4765 Y-7.6219
    G1 X2.9502 Y-7.4513
    G1 X3.4122 Y-7.2514
    G1 X3.8608 Y-7.0228
    G1 X4.2942 Y-6.7666
    G1 X4.7106 Y-6.4836
    G1 X5.1084 Y-6.175
    G1 X5.486 Y-5.842
    G1 X5.842 Y-5.486
    G1 X6.175 Y-5.1084
    G1 X6.4836 Y-4.7106
    G1 X6.7666 Y-4.2942
    G1 X7.0228 Y-3.8608
    G1 X7.2514 Y-3.4122
    G1 X7.4513 Y-2.9502
    G1 X7.6219 Y-2.4765
    G1 X7.7623 Y-1.993
    G1 X7.8722 Y-1.5017
    G1 X7.9509 Y-1.0044
    G1 X7.9983 Y-0.5032
    G1 X8.0141 Y0.0
    G1 X7.9983 Y0.5032
    G1 X7.9509 Y1.0044
    G1 X7.8722 Y1.5017
    G1 X7.7623 Y1.993
    G1 X7.6219 Y2.4765
    G1 X7.4513 Y2.9502
    G1 X7.2514 Y3.4122
    G1 X7.0228 Y3.8608
    G1 X6.7666 Y4.2942
    G1 X6.4836 Y4.7106
    G1 X6.175 Y5.1084
    G1 X5.842 Y5.486
    G1 X5.486 Y5.842
    G1 X5.1084 Y6.175
    G1 X4.7106 Y6.4836
    G1 X4.2942 Y6.7666
    G1 X3.8608 Y7.0228
    G1 X3.4122 Y7.2514
    G1 X2.9502 Y7.4513
    G1 X2.4765 Y7.6219
    G1 X1.993 Y7.7623
    G1 X1.5017 Y7.8722
    G1 X1.0044 Y7.9509
    G1 X0.5032 Y7.9983
    G1 X0.0 Y8.0141
    ( 12 )
    S1000
    G0 Z1.5
    G0 Y37.2843
    G1 Z0.0
    G1 X-0.4992 Y37.2686
    G1 X-0.9965 Y37.2216
    G1 X-1.4899 Y37.1435
    G1 X-1.9773 Y37.0345
    G1 X-2.457 Y36.8952
    G1 X-2.9269 Y36.726
    G1 X-3.3853 Y36.5276
    G1 X-3.8304 Y36.3008
    G1 X-4.2603 Y36.0466
    G1 X-4.6734 Y35.7658
    G1 X-5.0681 Y35.4597
    G1 X-5.4428 Y35.1294
    G1 X-5.796 Y34.7762
    G1 X-6.1263 Y34.4015
    G1 X-6.4324 Y34.0068
    G1 X-6.7132 Y33.5937
    G1 X-6.9674 Y33.1638
    G1 X-7.1942 Y32.7187
    G1 X-7.3926 Y32.2603
    G1 X-7.5618 Y31.7904
    G1 X-7.7011 Y31.3107
    G1 X-7.8101 Y30.8232
    G1 X-7.8882 Y30.3299
    G1 X-7.9352 Y29.8326
    G1 X-7.9509 Y29.3334
    G1 X-7.9352 Y28.8342
    G1 X-7.8882 Y28.3369
    G1 X-7.8101 Y27.8435
    G1 X-7.7011 Y27.3561
    G1 X-7.5618 Y26.8764
    G1 X-7.3926 Y26.4065
    G1 X-7.1942 Y25.9481
    G1 X-6.9674 Y25.503
    G1 X-6.7132 Y25.0731
    G1 X-6.4324 Y24.66
    G1 X-6.1263 Y24.2653
    G1 X-5.796 Y23.8906
    G1 X-5.4428 Y23.5374
    G1 X-5.0681 Y23.2071
    G1 X-4.6734 Y22.901
    G1 X-4.2603 Y22.6202
    G1 X-3.8304 Y22.366
    G1 X-3.3853 Y22.1392
    G1 X-2.9269 Y21.9408
    G1 X-2.457 Y21.7716
    G1 X-1.9773 Y21.6323
    G1 X-1.4899 Y21.5233
    G1 X-0.9965 Y21.4452
    G1 X-0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X0.4992 Y21.3982
    G1 X0.9965 Y21.4452
    G1 X1.4899 Y21.5233
    G1 X1.9773 Y21.6323
    G1 X2.457 Y21.7716
    G1 X2.9269 Y21.9408
    G1 X3.3853 Y22.1392
    G1 X3.8304 Y22.366
    G1 X4.2603 Y22.6202
    G1 X4.6734 Y22.901
    G1 X5.0681 Y23.2071
    G1 X5.4428 Y23.5374
    G1 X5.796 Y23.8906
    G1 X6.1263 Y24.2653
    G1 X6.4324 Y24.66
    G1 X6.7132 Y25.0731
    G1 X6.9674 Y25.503
    G1 X7.1942 Y25.9481
    G1 X7.3926 Y26.4065
    G1 X7.5618 Y26.8764
    G1 X7.7011 Y27.3561
    G1 X7.8101 Y27.8435
    G1 X7.8882 Y28.3369
    G1 X7.9352 Y28.8342
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y29.8326
    G1 X7.8882 Y30.3299
    G1 X7.8101 Y30.8232
    G1 X7.7011 Y31.3107
    G1 X7.5618 Y31.7904
    G1 X7.3926 Y32.2603
    G1 X7.1942 Y32.7187
    G1 X6.9674 Y33.1638
    G1 X6.7132 Y33.5937
    G1 X6.4324 Y34.0068
    G1 X6.1263 Y34.4015
    G1 X5.796 Y34.7762
    G1 X5.4428 Y35.1294
    G1 X5.0681 Y35.4597
    G1 X4.6734 Y35.7658
    G1 X4.2603 Y36.0466
    G1 X3.8304 Y36.3008
    G1 X3.3853 Y36.5276
    G1 X2.9269 Y36.726
    G1 X2.457 Y36.8952
    G1 X1.9773 Y37.0345
    G1 X1.4899 Y37.1435
    G1 X0.9965 Y37.2216
    G1 X0.4992 Y37.2686
    G1 X0.0 Y37.2843
    ( 13 )
    S1000
    G1 Z-1.0
    G1 X-2.457 Y36.8952
    G1 X-2.9269 Y36.726
    G1 X-5.796 Y34.7762
    G1 X-6.9674 Y25.503
    G1 X-6.4324 Y24.66
    G1 X-5.796 Y23.8906
    G1 X-4.6734 Y22.901
    G1 X-3.8304 Y22.366
    G1 X-2.457 Y21.7716
    G1 X0.0 Y21.3825
    G1 X0.4992 Y21.3982
    G1 X0.9965 Y21.4452
    G1 X1.4899 Y21.5233
    G1 X1.9773 Y21.6323
    G1 X2.457 Y21.7716
    G1 X2.9269 Y21.9408
    G1 X3.3853 Y22.1392
    G1 X3.8304 Y22.366
    G1 X4.2603 Y22.6202
    G1 X4.6734 Y22.901
    G1 X5.0681 Y23.2071
    G1 X5.4428 Y23.5374
    G1 X5.796 Y23.8906
    G1 X6.1263 Y24.2653
    G1 X6.4324 Y24.66
    G1 X6.7132 Y25.0731
    G1 X6.9674 Y25.503
    G1 X7.1942 Y25.9481
    G1 X7.3926 Y26.4065
    G1 X7.5618 Y26.8764
    G1 X7.7011 Y27.3561
    G1 X7.8101 Y27.8435
    G1 X7.8882 Y28.3369
    G1 X7.9352 Y28.8342
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y29.8326
    G1 X7.8882 Y30.3299
    G1 X7.8101 Y30.8232
    G1 X7.7011 Y31.3107
    G1 X7.5618 Y31.7904
    G1 X7.3926 Y32.2603
    G1 X7.1942 Y32.7187
    G1 X6.9674 Y33.1638
    G1 X6.7132 Y33.5937
    G1 X6.4324 Y34.0068
    G1 X6.1263 Y34.4015
    G1 X5.796 Y34.7762
    G1 X5.4428 Y35.1294
    G1 X5.0681 Y35.4597
    G1 X4.6734 Y35.7658
    G1 X4.2603 Y36.0466
    G1 X3.8304 Y36.3008
    G1 X3.3853 Y36.5276
    G1 X2.9269 Y36.726
    G1 X2.457 Y36.8952
    G1 X1.9773 Y37.0345
    G1 X1.4899 Y37.1435
    G1 X0.9965 Y37.2216
    G1 X0.4992 Y37.2686
    G1 X0.0 Y37.2843
    ( 14 )
    S1000
    G1 Z-2.0
    G1 X0.4992 Y37.2686
    G1 X0.9965 Y37.2216
    G1 X1.4899 Y37.1435
    G1 X1.9773 Y37.0345
    G1 X2.457 Y36.8952
    G1 X2.9269 Y36.726
    G1 X3.3853 Y36.5276
    G1 X3.8304 Y36.3008
    G1 X4.2603 Y36.0466
    G1 X4.6734 Y35.7658
    G1 X5.0681 Y35.4597
    G1 X5.4428 Y35.1294
    G1 X5.796 Y34.7762
    G1 X6.1263 Y34.4015
    G1 X6.4324 Y34.0068
    G1 X6.7132 Y33.5937
    G1 X6.9674 Y33.1638
    G1 X7.1942 Y32.7187
    G1 X7.3926 Y32.2603
    G1 X7.5618 Y31.7904
    G1 X7.7011 Y31.3107
    G1 X7.8101 Y30.8232
    G1 X7.8882 Y30.3299
    G1 X7.9352 Y29.8326
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y28.8342
    G1 X7.8882 Y28.3369
    G1 X7.8101 Y27.8435
    G1 X7.7011 Y27.3561
    G1 X7.5618 Y26.8764
    G1 X7.3926 Y26.4065
    G1 X7.1942 Y25.9481
    G1 X6.9674 Y25.503
    G1 X6.7132 Y25.0731
    G1 X6.4324 Y24.66
    G1 X6.1263 Y24.2653
    G1 X5.796 Y23.8906
    G1 X5.4428 Y23.5374
    G1 X5.0681 Y23.2071
    G1 X4.6734 Y22.901
    G1 X4.2603 Y22.6202
    G1 X3.8304 Y22.366
    G1 X3.3853 Y22.1392
    G1 X2.9269 Y21.9408
    G1 X2.457 Y21.7716
    G1 X1.9773 Y21.6323
    G1 X1.4899 Y21.5233
    G1 X0.9965 Y21.4452
    G1 X0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X-2.457 Y21.7716
    G1 X-3.8304 Y22.366
    G1 X-4.6734 Y22.901
    G1 X-5.796 Y23.8906
    G1 X-6.4324 Y24.66
    G1 X-6.9674 Y25.503
    G1 X-5.796 Y34.7762
    G1 X-2.9269 Y36.726
    G1 X-2.457 Y36.8952
    G1 X0.0 Y37.2843
    ( 15 )
    S1000
    G1 Z-3.0
    G1 X0.4992 Y37.2686
    G1 X0.9965 Y37.2216
    G1 X1.4899 Y37.1435
    G1 X1.9773 Y37.0345
    G1 X2.457 Y36.8952
    G1 X2.9269 Y36.726
    G1 X3.3853 Y36.5276
    G1 X3.8304 Y36.3008
    G1 X4.2603 Y36.0466
    G1 X4.6734 Y35.7658
    G1 X5.0681 Y35.4597
    G1 X5.4428 Y35.1294
    G1 X5.796 Y34.7762
    G1 X6.1263 Y34.4015
    G1 X6.4324 Y34.0068
    G1 X6.7132 Y33.5937
    G1 X6.9674 Y33.1638
    G1 X7.1942 Y32.7187
    G1 X7.3926 Y32.2603
    G1 X7.5618 Y31.7904
    G1 X7.7011 Y31.3107
    G1 X7.8101 Y30.8232
    G1 X7.8882 Y30.3299
    G1 X7.9352 Y29.8326
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y28.8342
    G1 X7.8882 Y28.3369
    G1 X7.8101 Y27.8435
    G1 X7.7011 Y27.3561
    G1 X7.5618 Y26.8764
    G1 X7.3926 Y26.4065
    G1 X7.1942 Y25.9481
    G1 X6.9674 Y25.503
    G1 X6.7132 Y25.0731
    G1 X6.4324 Y24.66
    G1 X6.1263 Y24.2653
    G1 X5.796 Y23.8906
    G1 X5.4428 Y23.5374
    G1 X5.0681 Y23.2071
    G1 X4.6734 Y22.901
    G1 X4.2603 Y22.6202
    G1 X3.8304 Y22.366
    G1 X3.3853 Y22.1392
    G1 X2.9269 Y21.9408
    G1 X2.457 Y21.7716
    G1 X1.9773 Y21.6323
    G1 X1.4899 Y21.5233
    G1 X0.9965 Y21.4452
    G1 X0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X-2.457 Y21.7716
    G1 X-3.8304 Y22.366
    G1 X-4.6734 Y22.901
    G1 X-5.796 Y23.8906
    G1 X-6.4324 Y24.66
    G1 X-6.9674 Y25.503
    G1 X-5.796 Y34.7762
    G1 X-2.9269 Y36.726
    G1 X-2.457 Y36.8952
    G1 X0.0 Y37.2843
    ( 16 )
    S1000
    G1 Z-4.0
    G1 X0.4992 Y37.2686
    G1 X0.9965 Y37.2216
    G1 X1.4899 Y37.1435
    G1 X1.9773 Y37.0345
    G1 X2.457 Y36.8952
    G1 X2.9269 Y36.726
    G1 X3.3853 Y36.5276
    G1 X3.8304 Y36.3008
    G1 X4.2603 Y36.0466
    G1 X4.6734 Y35.7658
    G1 X5.0681 Y35.4597
    G1 X5.4428 Y35.1294
    G1 X5.796 Y34.7762
    G1 X6.1263 Y34.4015
    G1 X6.4324 Y34.0068
    G1 X6.7132 Y33.5937
    G1 X6.9674 Y33.1638
    G1 X7.1942 Y32.7187
    G1 X7.3926 Y32.2603
    G1 X7.5618 Y31.7904
    G1 X7.7011 Y31.3107
    G1 X7.8101 Y30.8232
    G1 X7.8882 Y30.3299
    G1 X7.9352 Y29.8326
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y28.8342
    G1 X7.8882 Y28.3369
    G1 X7.8101 Y27.8435
    G1 X7.7011 Y27.3561
    G1 X7.5618 Y26.8764
    G1 X7.3926 Y26.4065
    G1 X7.1942 Y25.9481
    G1 X6.9674 Y25.503
    G1 X6.7132 Y25.0731
    G1 X6.4324 Y24.66
    G1 X6.1263 Y24.2653
    G1 X5.796 Y23.8906
    G1 X5.4428 Y23.5374
    G1 X5.0681 Y23.2071
    G1 X4.6734 Y22.901
    G1 X4.2603 Y22.6202
    G1 X3.8304 Y22.366
    G1 X3.3853 Y22.1392
    G1 X2.9269 Y21.9408
    G1 X2.457 Y21.7716
    G1 X1.9773 Y21.6323
    G1 X1.4899 Y21.5233
    G1 X0.9965 Y21.4452
    G1 X0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X-2.457 Y21.7716
    G1 X-3.8304 Y22.366
    G1 X-4.6734 Y22.901
    G1 X-5.796 Y23.8906
    G1 X-6.4324 Y24.66
    G1 X-6.9674 Y25.503
    G1 X-5.796 Y34.7762
    G1 X-2.9269 Y36.726
    G1 X-2.457 Y36.8952
    G1 X0.0 Y37.2843
    ( 17 )
    S1000
    G1 Z-5.0
    G1 X0.4992 Y37.2686
    G1 X0.9965 Y37.2216
    G1 X1.4899 Y37.1435
    G1 X1.9773 Y37.0345
    G1 X2.457 Y36.8952
    G1 X2.9269 Y36.726
    G1 X3.3853 Y36.5276
    G1 X3.8304 Y36.3008
    G1 X4.2603 Y36.0466
    G1 X4.6734 Y35.7658
    G1 X5.0681 Y35.4597
    G1 X5.4428 Y35.1294
    G1 X5.796 Y34.7762
    G1 X6.1263 Y34.4015
    G1 X6.4324 Y34.0068
    G1 X6.7132 Y33.5937
    G1 X6.9674 Y33.1638
    G1 X7.1942 Y32.7187
    G1 X7.3926 Y32.2603
    G1 X7.5618 Y31.7904
    G1 X7.7011 Y31.3107
    G1 X7.8101 Y30.8232
    G1 X7.8882 Y30.3299
    G1 X7.9352 Y29.8326
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y28.8342
    G1 X7.8882 Y28.3369
    G1 X7.8101 Y27.8435
    G1 X7.7011 Y27.3561
    G1 X7.5618 Y26.8764
    G1 X7.3926 Y26.4065
    G1 X7.1942 Y25.9481
    G1 X6.9674 Y25.503
    G1 X6.7132 Y25.0731
    G1 X6.4324 Y24.66
    G1 X6.1263 Y24.2653
    G1 X5.796 Y23.8906
    G1 X5.4428 Y23.5374
    G1 X5.0681 Y23.2071
    G1 X4.6734 Y22.901
    G1 X4.2603 Y22.6202
    G1 X3.8304 Y22.366
    G1 X3.3853 Y22.1392
    G1 X2.9269 Y21.9408
    G1 X2.457 Y21.7716
    G1 X1.9773 Y21.6323
    G1 X1.4899 Y21.5233
    G1 X0.9965 Y21.4452
    G1 X0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X-2.457 Y21.7716
    G1 X-3.8304 Y22.366
    G1 X-4.6734 Y22.901
    G1 X-5.796 Y23.8906
    G1 X-6.4324 Y24.66
    G1 X-6.9674 Y25.503
    G1 X-5.796 Y34.7762
    G1 X-2.9269 Y36.726
    G1 X-2.457 Y36.8952
    G1 X0.0 Y37.2843
    ( 18 )
    S1000
    G1 Z-6.0
    G1 X-2.457 Y36.8952
    G1 X-2.9269 Y36.726
    G1 X-5.796 Y34.7762
    G1 X-6.9674 Y25.503
    G1 X-6.4324 Y24.66
    G1 X-5.796 Y23.8906
    G1 X-4.6734 Y22.901
    G1 X-3.8304 Y22.366
    G1 X-2.457 Y21.7716
    G1 X0.0 Y21.3825
    G1 X0.4992 Y21.3982
    G1 X0.9965 Y21.4452
    G1 X1.4899 Y21.5233
    G1 X1.9773 Y21.6323
    G1 X2.457 Y21.7716
    G1 X2.9269 Y21.9408
    G1 X3.3853 Y22.1392
    G1 X3.8304 Y22.366
    G1 X4.2603 Y22.6202
    G1 X4.6734 Y22.901
    G1 X5.0681 Y23.2071
    G1 X5.4428 Y23.5374
    G1 X5.796 Y23.8906
    G1 X6.1263 Y24.2653
    G1 X6.4324 Y24.66
    G1 X6.7132 Y25.0731
    G1 X6.9674 Y25.503
    G1 X7.1942 Y25.9481
    G1 X7.3926 Y26.4065
    G1 X7.5618 Y26.8764
    G1 X7.7011 Y27.3561
    G1 X7.8101 Y27.8435
    G1 X7.8882 Y28.3369
    G1 X7.9352 Y28.8342
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y29.8326
    G1 X7.8882 Y30.3299
    G1 X7.8101 Y30.8232
    G1 X7.7011 Y31.3107
    G1 X7.5618 Y31.7904
    G1 X7.3926 Y32.2603
    G1 X7.1942 Y32.7187
    G1 X6.9674 Y33.1638
    G1 X6.7132 Y33.5937
    G1 X6.4324 Y34.0068
    G1 X6.1263 Y34.4015
    G1 X5.796 Y34.7762
    G1 X5.4428 Y35.1294
    G1 X5.0681 Y35.4597
    G1 X4.6734 Y35.7658
    G1 X4.2603 Y36.0466
    G1 X3.8304 Y36.3008
    G1 X3.3853 Y36.5276
    G1 X2.9269 Y36.726
    G1 X2.457 Y36.8952
    G1 X1.9773 Y37.0345
    G1 X1.4899 Y37.1435
    G1 X0.9965 Y37.2216
    G1 X0.4992 Y37.2686
    G1 X0.0 Y37.2843
    ( 19 )
    S1000
    G1 Z-7.0
    G1 X0.4992 Y37.2686
    G1 X0.9965 Y37.2216
    G1 X1.4899 Y37.1435
    G1 X1.9773 Y37.0345
    G1 X2.457 Y36.8952
    G1 X2.9269 Y36.726
    G1 X3.3853 Y36.5276
    G1 X3.8304 Y36.3008
    G1 X4.2603 Y36.0466
    G1 X4.6734 Y35.7658
    G1 X5.0681 Y35.4597
    G1 X5.4428 Y35.1294
    G1 X5.796 Y34.7762
    G1 X6.1263 Y34.4015
    G1 X6.4324 Y34.0068
    G1 X6.7132 Y33.5937
    G1 X6.9674 Y33.1638
    G1 X7.1942 Y32.7187
    G1 X7.3926 Y32.2603
    G1 X7.5618 Y31.7904
    G1 X7.7011 Y31.3107
    G1 X7.8101 Y30.8232
    G1 X7.8882 Y30.3299
    G1 X7.9352 Y29.8326
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y28.8342
    G1 X7.8882 Y28.3369
    G1 X7.8101 Y27.8435
    G1 X7.7011 Y27.3561
    G1 X7.5618 Y26.8764
    G1 X7.3926 Y26.4065
    G1 X7.1942 Y25.9481
    G1 X6.9674 Y25.503
    G1 X6.7132 Y25.0731
    G1 X6.4324 Y24.66
    G1 X6.1263 Y24.2653
    G1 X5.796 Y23.8906
    G1 X5.4428 Y23.5374
    G1 X5.0681 Y23.2071
    G1 X4.6734 Y22.901
    G1 X4.2603 Y22.6202
    G1 X3.8304 Y22.366
    G1 X3.3853 Y22.1392
    G1 X2.9269 Y21.9408
    G1 X2.457 Y21.7716
    G1 X1.9773 Y21.6323
    G1 X1.4899 Y21.5233
    G1 X0.9965 Y21.4452
    G1 X0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X-2.457 Y21.7716
    G1 X-3.8304 Y22.366
    G1 X-4.6734 Y22.901
    G1 X-5.796 Y23.8906
    G1 X-6.4324 Y24.66
    G1 X-6.9674 Y25.503
    G1 X-5.796 Y34.7762
    G1 X-2.9269 Y36.726
    G1 X-2.457 Y36.8952
    G1 X0.0 Y37.2843
    ( 20 )
    S1000
    G1 Z-8.0
    G1 X0.4992 Y37.2686
    G1 X0.9965 Y37.2216
    G1 X1.4899 Y37.1435
    G1 X1.9773 Y37.0345
    G1 X2.457 Y36.8952
    G1 X2.9269 Y36.726
    G1 X3.3853 Y36.5276
    G1 X3.8304 Y36.3008
    G1 X4.2603 Y36.0466
    G1 X4.6734 Y35.7658
    G1 X5.0681 Y35.4597
    G1 X5.4428 Y35.1294
    G1 X5.796 Y34.7762
    G1 X6.1263 Y34.4015
    G1 X6.4324 Y34.0068
    G1 X6.7132 Y33.5937
    G1 X6.9674 Y33.1638
    G1 X7.1942 Y32.7187
    G1 X7.3926 Y32.2603
    G1 X7.5618 Y31.7904
    G1 X7.7011 Y31.3107
    G1 X7.8101 Y30.8232
    G1 X7.8882 Y30.3299
    G1 X7.9352 Y29.8326
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y28.8342
    G1 X7.8882 Y28.3369
    G1 X7.8101 Y27.8435
    G1 X7.7011 Y27.3561
    G1 X7.5618 Y26.8764
    G1 X7.3926 Y26.4065
    G1 X7.1942 Y25.9481
    G1 X6.9674 Y25.503
    G1 X6.7132 Y25.0731
    G1 X6.4324 Y24.66
    G1 X6.1263 Y24.2653
    G1 X5.796 Y23.8906
    G1 X5.4428 Y23.5374
    G1 X5.0681 Y23.2071
    G1 X4.6734 Y22.901
    G1 X4.2603 Y22.6202
    G1 X3.8304 Y22.366
    G1 X3.3853 Y22.1392
    G1 X2.9269 Y21.9408
    G1 X2.457 Y21.7716
    G1 X1.9773 Y21.6323
    G1 X1.4899 Y21.5233
    G1 X0.9965 Y21.4452
    G1 X0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X-2.457 Y21.7716
    G1 X-3.8304 Y22.366
    G1 X-4.6734 Y22.901
    G1 X-5.796 Y23.8906
    G1 X-6.4324 Y24.66
    G1 X-6.9674 Y25.503
    G1 X-5.796 Y34.7762
    G1 X-2.9269 Y36.726
    G1 X-2.457 Y36.8952
    G1 X0.0 Y37.2843
    ( 21 )
    S1000
    G1 Z-9.0
    G1 X0.4992 Y37.2686
    G1 X0.9965 Y37.2216
    G1 X1.4899 Y37.1435
    G1 X1.9773 Y37.0345
    G1 X2.457 Y36.8952
    G1 X2.9269 Y36.726
    G1 X3.3853 Y36.5276
    G1 X3.8304 Y36.3008
    G1 X4.2603 Y36.0466
    G1 X4.6734 Y35.7658
    G1 X5.0681 Y35.4597
    G1 X5.4428 Y35.1294
    G1 X5.796 Y34.7762
    G1 X6.1263 Y34.4015
    G1 X6.4324 Y34.0068
    G1 X6.7132 Y33.5937
    G1 X6.9674 Y33.1638
    G1 X7.1942 Y32.7187
    G1 X7.3926 Y32.2603
    G1 X7.5618 Y31.7904
    G1 X7.7011 Y31.3107
    G1 X7.8101 Y30.8232
    G1 X7.8882 Y30.3299
    G1 X7.9352 Y29.8326
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y28.8342
    G1 X7.8882 Y28.3369
    G1 X7.8101 Y27.8435
    G1 X7.7011 Y27.3561
    G1 X7.5618 Y26.8764
    G1 X7.3926 Y26.4065
    G1 X7.1942 Y25.9481
    G1 X6.9674 Y25.503
    G1 X6.7132 Y25.0731
    G1 X6.4324 Y24.66
    G1 X6.1263 Y24.2653
    G1 X5.796 Y23.8906
    G1 X5.4428 Y23.5374
    G1 X5.0681 Y23.2071
    G1 X4.6734 Y22.901
    G1 X4.2603 Y22.6202
    G1 X3.8304 Y22.366
    G1 X3.3853 Y22.1392
    G1 X2.9269 Y21.9408
    G1 X2.457 Y21.7716
    G1 X1.9773 Y21.6323
    G1 X1.4899 Y21.5233
    G1 X0.9965 Y21.4452
    G1 X0.4992 Y21.3982
    G1 X0.0 Y21.3825
    G1 X-2.457 Y21.7716
    G1 X-3.8304 Y22.366
    G1 X-4.6734 Y22.901
    G1 X-5.796 Y23.8906
    G1 X-6.4324 Y24.66
    G1 X-6.9674 Y25.503
    G1 X-5.796 Y34.7762
    G1 X-2.9269 Y36.726
    G1 X-2.457 Y36.8952
    G1 X0.0 Y37.2843
    ( 22 )
    S1000
    G1 Z-10.0
    G1 X-2.457 Y36.8952
    G1 X-2.9269 Y36.726
    G1 X-5.796 Y34.7762
    G1 X-6.9674 Y25.503
    G1 X-6.4324 Y24.66
    G1 X-5.796 Y23.8906
    G1 X-4.6734 Y22.901
    G1 X-3.8304 Y22.366
    G1 X-2.457 Y21.7716
    G1 X0.0 Y21.3825
    G1 X0.4992 Y21.3982
    G1 X0.9965 Y21.4452
    G1 X1.4899 Y21.5233
    G1 X1.9773 Y21.6323
    G1 X2.457 Y21.7716
    G1 X2.9269 Y21.9408
    G1 X3.3853 Y22.1392
    G1 X3.8304 Y22.366
    G1 X4.2603 Y22.6202
    G1 X4.6734 Y22.901
    G1 X5.0681 Y23.2071
    G1 X5.4428 Y23.5374
    G1 X5.796 Y23.8906
    G1 X6.1263 Y24.2653
    G1 X6.4324 Y24.66
    G1 X6.7132 Y25.0731
    G1 X6.9674 Y25.503
    G1 X7.1942 Y25.9481
    G1 X7.3926 Y26.4065
    G1 X7.5618 Y26.8764
    G1 X7.7011 Y27.3561
    G1 X7.8101 Y27.8435
    G1 X7.8882 Y28.3369
    G1 X7.9352 Y28.8342
    G1 X7.9509 Y29.3334
    G1 X7.9352 Y29.8326
    G1 X7.8882 Y30.3299
    G1 X7.8101 Y30.8232
    G1 X7.7011 Y31.3107
    G1 X7.5618 Y31.7904
    G1 X7.3926 Y32.2603
    G1 X7.1942 Y32.7187
    G1 X6.9674 Y33.1638
    G1 X6.7132 Y33.5937
    G1 X6.4324 Y34.0068
    G1 X6.1263 Y34.4015
    G1 X5.796 Y34.7762
    G1 X5.4428 Y35.1294
    G1 X5.0681 Y35.4597
    G1 X4.6734 Y35.7658
    G1 X4.2603 Y36.0466
    G1 X3.8304 Y36.3008
    G1 X3.3853 Y36.5276
    G1 X2.9269 Y36.726
    G1 X2.457 Y36.8952
    G1 X1.9773 Y37.0345
    G1 X1.4899 Y37.1435
    G1 X0.9965 Y37.2216
    G1 X0.4992 Y37.2686
    G1 X0.0 Y37.2843
    ( 23 )
    S1000
    G0 Z1.5
    G0 X-25.4035 Y-6.7018
    G1 Z0.0
    G1 X-25.9036 Y-6.7176
    G1 X-26.4017 Y-6.7646
    G1 X-26.8959 Y-6.8429
    G1 X-27.3842 Y-6.9521
    G1 X-27.8647 Y-7.0917
    G1 X-28.3355 Y-7.2612
    G1 X-28.7947 Y-7.4599
    G1 X-29.2406 Y-7.687
    G1 X-29.6712 Y-7.9417
    G1 X-30.0851 Y-8.223
    G1 X-30.4805 Y-8.5297
    G1 X-30.8558 Y-8.8606
    G1 X-31.2096 Y-9.2144
    G1 X-31.5405 Y-9.5897
    G1 X-31.8472 Y-9.9851
    G1 X-32.1284 Y-10.3989
    G1 X-32.3831 Y-10.8296
    G1 X-32.6103 Y-11.2754
    G1 X-32.809 Y-11.7346
    G1 X-32.9785 Y-12.2054
    G1 X-33.1181 Y-12.6859
    G1 X-33.2272 Y-13.1742
    G1 X-33.3055 Y-13.6684
    G1 X-33.3526 Y-14.1666
    G1 X-33.3683 Y-14.6667
    G1 X-33.3526 Y-15.1668
    G1 X-33.3055 Y-15.665
    G1 X-33.2272 Y-16.1592
    G1 X-33.1181 Y-16.6475
    G1 X-32.9785 Y-17.128
    G1 X-32.809 Y-17.5988
    G1 X-32.6103 Y-18.058
    G1 X-32.3831 Y-18.5038
    G1 X-32.1284 Y-18.9345
    G1 X-31.8472 Y-19.3483
    G1 X-31.5405 Y-19.7437
    G1 X-31.2096 Y-20.119
    G1 X-30.8558 Y-20.4728
    G1 X-30.4805 Y-20.8037
    G1 X-30.0851 Y-21.1104
    G1 X-29.6712 Y-21.3916
    G1 X-29.2406 Y-21.6464
    G1 X-28.7947 Y-21.8735
    G1 X-28.3355 Y-22.0722
    G1 X-27.8647 Y-22.2417
    G1 X-27.3842 Y-22.3813
    G1 X-26.8959 Y-22.4905
    G1 X-26.4017 Y-22.5688
    G1 X-25.9036 Y-22.6158
    G1 X-25.4035 Y-22.6316
    G1 X-24.9033 Y-22.6158
    G1 X-24.4052 Y-22.5688
    G1 X-23.911 Y-22.4905
    G1 X-23.4227 Y-22.3813
    G1 X-22.9422 Y-22.2417
    G1 X-22.4714 Y-22.0722
    G1 X-22.0122 Y-21.8735
    G1 X-21.5664 Y-21.6464
    G1 X-21.1357 Y-21.3916
    G1 X-20.7218 Y-21.1104
    G1 X-20.3265 Y-20.8037
    G1 X-19.9511 Y-20.4728
    G1 X-19.5973 Y-20.119
    G1 X-19.2664 Y-19.7437
    G1 X-18.9598 Y-19.3483
    G1 X-18.6785 Y-18.9345
    G1 X-18.4238 Y-18.5038
    G1 X-18.1966 Y-18.058
    G1 X-17.9979 Y-17.5988
    G1 X-17.8284 Y-17.128
    G1 X-17.6888 Y-16.6475
    G1 X-17.5797 Y-16.1592
    G1 X-17.5014 Y-15.665
    G1 X-17.4543 Y-15.1668
    G1 X-17.4386 Y-14.6667
    G1 X-17.4543 Y-14.1666
    G1 X-17.5014 Y-13.6684
    G1 X-17.5797 Y-13.1742
    G1 X-17.6888 Y-12.6859
    G1 X-17.8284 Y-12.2054
    G1 X-17.9979 Y-11.7346
    G1 X-18.1966 Y-11.2754
    G1 X-18.4238 Y-10.8296
    G1 X-18.6785 Y-10.3989
    G1 X-18.9598 Y-9.9851
    G1 X-19.2664 Y-9.5897
    G1 X-19.5973 Y-9.2144
    G1 X-19.9511 Y-8.8606
    G1 X-20.3265 Y-8.5297
    G1 X-20.7218 Y-8.223
    G1 X-21.1357 Y-7.9417
    G1 X-21.5664 Y-7.687
    G1 X-22.0122 Y-7.4599
    G1 X-22.4714 Y-7.2612
    G1 X-22.9422 Y-7.0917
    G1 X-23.4227 Y-6.9521
    G1 X-23.911 Y-6.8429
    G1 X-24.4052 Y-6.7646
    G1 X-24.9033 Y-6.7176
    G1 X-25.4035 Y-6.7018
    ( 24 )
    S1000
    G1 Z-1.0
    ( 25 )
    S1000
    G1 Z-2.0
    ( 26 )
    S1000
    G1 Z-3.0
    ( 27 )
    S1000
    G1 Z-4.0
    ( 28 )
    S1000
    G1 Z-5.0
    ( 29 )
    S1000
    G1 Z-6.0
    ( 30 )
    S1000
    G1 Z-7.0
    ( 31 )
    S1000
    G1 Z-8.0
    ( 32 )
    S1000
    G1 Z-9.0
    ( 33 )
    S1000
    G1 Z-10.0
    ( 34 )
    S1000
    G0 Z1.5
    G0 X25.4035 Y-6.7095
    G1 Z0.0
    G1 X25.9031 Y-6.7252
    G1 X26.4008 Y-6.7722
    G1 X26.8945 Y-6.8504
    G1 X27.3823 Y-6.9595
    G1 X27.8624 Y-7.0989
    G1 X28.3327 Y-7.2682
    G1 X28.7915 Y-7.4668
    G1 X29.2369 Y-7.6937
    G1 X29.6672 Y-7.9482
    G1 X30.0806 Y-8.2292
    G1 X30.4756 Y-8.5355
    G1 X30.8506 Y-8.8661
    G1 X31.204 Y-9.2196
    G1 X31.5346 Y-9.5946
    G1 X31.841 Y-9.9896
    G1 X32.122 Y-10.403
    G1 X32.3764 Y-10.8333
    G1 X32.6034 Y-11.2787
    G1 X32.8019 Y-11.7374
    G1 X32.9712 Y-12.2078
    G1 X33.1107 Y-12.6878
    G1 X33.2198 Y-13.1757
    G1 X33.298 Y-13.6694
    G1 X33.345 Y-14.1671
    G1 X33.3607 Y-14.6667
    G1 X33.345 Y-15.1663
    G1 X33.298 Y-15.664
    G1 X33.2198 Y-16.1577
    G1 X33.1107 Y-16.6456
    G1 X32.9712 Y-17.1256
    G1 X32.8019 Y-17.5959
    G1 X32.6034 Y-18.0547
    G1 X32.3764 Y-18.5001
    G1 X32.122 Y-18.9304
    G1 X31.841 Y-19.3438
    G1 X31.5346 Y-19.7388
    G1 X31.204 Y-20.1138
    G1 X30.8506 Y-20.4673
    G1 X30.4756 Y-20.7978
    G1 X30.0806 Y-21.1042
    G1 X29.6672 Y-21.3852
    G1 X29.2369 Y-21.6397
    G1 X28.7915 Y-21.8666
    G1 X28.3327 Y-22.0651
    G1 X27.8624 Y-22.2345
    G1 X27.3823 Y-22.3739
    G1 X26.8945 Y-22.483
    G1 X26.4008 Y-22.5612
    G1 X25.9031 Y-22.6082
    G1 X25.4035 Y-22.6239
    G1 X24.9038 Y-22.6082
    G1 X24.4062 Y-22.5612
    G1 X23.9124 Y-22.483
    G1 X23.4246 Y-22.3739
    G1 X22.9445 Y-22.2345
    G1 X22.4742 Y-22.0651
    G1 X22.0154 Y-21.8666
    G1 X21.57 Y-21.6397
    G1 X21.1398 Y-21.3852
    G1 X20.7263 Y-21.1042
    G1 X20.3313 Y-20.7978
    G1 X19.9564 Y-20.4673
    G1 X19.6029 Y-20.1138
    G1 X19.2723 Y-19.7388
    G1 X18.9659 Y-19.3438
    G1 X18.6849 Y-18.9304
    G1 X18.4305 Y-18.5001
    G1 X18.2035 Y-18.0547
    G1 X18.005 Y-17.5959
    G1 X17.8357 Y-17.1256
    G1 X17.6962 Y-16.6456
    G1 X17.5872 Y-16.1577
    G1 X17.509 Y-15.664
    G1 X17.4619 Y-15.1663
    G1 X17.4462 Y-14.6667
    G1 X17.4619 Y-14.1671
    G1 X17.509 Y-13.6694
    G1 X17.5872 Y-13.1757
    G1 X17.6962 Y-12.6878
    G1 X17.8357 Y-12.2078
    G1 X18.005 Y-11.7374
    G1 X18.2035 Y-11.2787
    G1 X18.4305 Y-10.8333
    G1 X18.6849 Y-10.403
    G1 X18.9659 Y-9.9896
    G1 X19.2723 Y-9.5946
    G1 X19.6029 Y-9.2196
    G1 X19.9564 Y-8.8661
    G1 X20.3313 Y-8.5355
    G1 X20.7263 Y-8.2292
    G1 X21.1398 Y-7.9482
    G1 X21.57 Y-7.6937
    G1 X22.0154 Y-7.4668
    G1 X22.4742 Y-7.2682
    G1 X22.9445 Y-7.0989
    G1 X23.4246 Y-6.9595
    G1 X23.9124 Y-6.8504
    G1 X24.4062 Y-6.7722
    G1 X24.9038 Y-6.7252
    G1 X25.4035 Y-6.7095
    ( 35 )
    S1000
    G1 Z-1.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 36 )
    S1000
    G1 Z-2.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 37 )
    S1000
    G1 Z-3.0
    G1 X31.204 Y-9.2196
    G1 X31.841 Y-9.9896
    G1 X32.122 Y-10.403
    G1 X33.298 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X17.509 Y-15.664
    G1 X21.57 Y-7.6937
    ( 38 )
    S1000
    G1 Z-4.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 39 )
    S1000
    G1 Z-5.0
    G1 X31.204 Y-9.2196
    G1 X31.841 Y-9.9896
    G1 X32.122 Y-10.403
    G1 X33.298 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X17.509 Y-15.664
    G1 X21.57 Y-7.6937
    ( 40 )
    S1000
    G1 Z-6.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 41 )
    S1000
    G1 Z-7.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 42 )
    S1000
    G1 Z-8.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 43 )
    S1000
    G1 Z-9.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 44 )
    S1000
    G1 Z-10.0
    G1 X21.57 Y-7.6937
    G1 X17.509 Y-15.664
    G1 X21.57 Y-21.6397
    G1 X33.298 Y-15.664
    G1 X32.122 Y-10.403
    G1 X31.841 Y-9.9896
    G1 X31.204 Y-9.2196
    ( 45 )
    S1000
    G0 Z1.5
    G0 X-18.4493 Y9.7168
    G1 Z0.0
    G1 X-18.1669 Y10.1324
    G1 X-17.9111 Y10.5648
    G1 X-17.683 Y11.0125
    G1 X-17.4835 Y11.4736
    G1 X-17.3133 Y11.9463
    G1 X-17.1731 Y12.4288
    G1 X-17.0635 Y12.9191
    G1 X-16.9849 Y13.4153
    G1 X-16.9377 Y13.9155
    G1 X-16.9219 Y14.4177
    G1 X-16.9377 Y14.9198
    G1 X-16.9849 Y15.42
    G1 X-17.0635 Y15.9163
    G1 X-17.1731 Y16.4066
    G1 X-17.3133 Y16.889
    G1 X-17.4835 Y17.3618
    G1 X-17.683 Y17.8228
    G1 X-17.8701 Y18.1968
    G1 X-17.8871 Y18.2235
    G1 X-18.1464 Y18.6684
    G1 X-18.219 Y18.7912
    G1 X-18.465 Y19.2123
    G1 X-19.0114 Y20.2802
    G1 X-19.4969 Y21.3795
    G1 X-19.9189 Y22.5047
    G1 X-20.2761 Y23.6521
    G1 X-20.5671 Y24.8181
    G1 X-20.7912 Y25.9987
    G1 X-20.9476 Y27.1902
    G1 X-21.0358 Y28.3887
    G1 X-21.0554 Y29.5903
    G1 X-21.0064 Y30.791
    G1 X-20.8891 Y31.987
    G1 X-20.7037 Y33.1743
    G1 X-20.4509 Y34.3491
    G1 X-20.1314 Y35.5076
    G1 X-19.7464 Y36.646
    G1 X-19.2971 Y37.7606
    G1 X-18.7849 Y38.8477
    G1 X-18.2116 Y39.9038
    G1 X-17.5789 Y40.9255
    G1 X-16.889 Y41.9095
    G1 X-16.144 Y42.8525
    G1 X-15.3465 Y43.7514
    G1 X-14.499 Y44.6034
    G1 X-13.6043 Y45.4057
    G1 X-12.6653 Y46.1556
    G1 X-11.685 Y46.8507
    G1 X-10.6667 Y47.4888
    G1 X-9.6136 Y48.0677
    G1 X-8.5292 Y48.5856
    G1 X-7.417 Y49.0408
    G1 X-6.2807 Y49.4319
    G1 X-5.1239 Y49.7574
    G1 X-3.9504 Y50.0165
    G1 X-2.7641 Y50.2081
    G1 X-1.5687 Y50.3318
    G1 X-0.3683 Y50.3871
    G1 X0.0 Y50.3831
    G1 X0.3683 Y50.3871
    G1 X1.5687 Y50.3318
    G1 X2.7641 Y50.2081
    G1 X3.9504 Y50.0165
    G1 X5.1239 Y49.7574
    G1 X6.2807 Y49.4319
    G1 X7.417 Y49.0408
    G1 X8.5292 Y48.5856
    G1 X9.6136 Y48.0677
    G1 X10.6667 Y47.4888
    G1 X11.685 Y46.8507
    G1 X12.6653 Y46.1556
    G1 X13.6043 Y45.4057
    G1 X14.499 Y44.6034
    G1 X15.3465 Y43.7514
    G1 X16.144 Y42.8525
    G1 X16.889 Y41.9095
    G1 X17.5789 Y40.9255
    G1 X18.2116 Y39.9038
    G1 X18.7849 Y38.8477
    G1 X19.2971 Y37.7606
    G1 X19.7464 Y36.646
    G1 X20.1314 Y35.5076
    G1 X20.4509 Y34.3491
    G1 X20.7037 Y33.1743
    G1 X20.8891 Y31.987
    G1 X21.0064 Y30.791
    G1 X21.0554 Y29.5903
    G1 X21.0358 Y28.3887
    G1 X20.9476 Y27.1902
    G1 X20.7912 Y25.9987
    G1 X20.5671 Y24.8181
    G1 X20.2761 Y23.6521
    G1 X19.9189 Y22.5047
    G1 X19.4969 Y21.3795
    G1 X19.0114 Y20.2802
    G1 X18.465 Y19.2123
    G1 X18.219 Y18.7912
    G1 X18.1464 Y18.6684
    G1 X17.8871 Y18.2235
    G1 X17.8701 Y18.1968
    G1 X17.683 Y17.8228
    G1 X17.4835 Y17.3618
    G1 X17.3133 Y16.889
    G1 X17.1731 Y16.4066
    G1 X17.0635 Y15.9163
    G1 X16.9849 Y15.42
    G1 X16.9377 Y14.9198
    G1 X16.9219 Y14.4177
    G1 X16.9377 Y13.9155
    G1 X16.9849 Y13.4153
    G1 X17.0635 Y12.9191
    G1 X17.1731 Y12.4288
    G1 X17.3133 Y11.9463
    G1 X17.4835 Y11.4736
    G1 X17.683 Y11.0125
    G1 X17.9111 Y10.5648
    G1 X18.1669 Y10.1324
    G1 X18.4493 Y9.7168
    G1 X18.7572 Y9.3198
    G1 X19.0895 Y8.943
    G1 X19.4447 Y8.5877
    G1 X19.8216 Y8.2554
    G1 X20.2186 Y7.9475
    G1 X20.6341 Y7.6651
    G1 X21.0666 Y7.4094
    G1 X21.5142 Y7.1813
    G1 X21.9753 Y6.9817
    G1 X22.448 Y6.8115
    G1 X22.9305 Y6.6714
    G1 X23.4208 Y6.5618
    G1 X23.9171 Y6.4832
    G1 X24.4231 Y6.4353
    G1 X25.9387 Y6.3818
    G1 X27.0865 Y6.3229
    G1 X28.2911 Y6.1913
    G1 X29.4862 Y5.9907
    G1 X30.6678 Y5.7216
    G1 X31.8319 Y5.385
    G1 X32.9747 Y4.982
    G1 X34.0925 Y4.5139
    G1 X35.1815 Y3.9823
    G1 X36.2381 Y3.389
    G1 X37.2588 Y2.7358
    G1 X38.2403 Y2.025
    G1 X39.1792 Y1.2589
    G1 X40.0725 Y0.4401
    G1 X40.9173 Y-0.4288
    G1 X41.7106 Y-1.3448
    G1 X42.4499 Y-2.3049
    G1 X43.1328 Y-3.306
    G1 X43.757 Y-4.3447
    G1 X44.3204 Y-5.4176
    G1 X44.8211 Y-6.5211
    G1 X45.2575 Y-7.6516
    G1 X45.6282 Y-8.8053
    G1 X45.9319 Y-9.9785
    G1 X46.1676 Y-11.1671
    G1 X46.3345 Y-12.3674
    G1 X46.4321 Y-13.5753
    G1 X46.4601 Y-14.7868
    G1 X46.4183 Y-15.9979
    G1 X46.3069 Y-17.2045
    G1 X46.1263 Y-18.4028
    G1 X45.8771 Y-19.5887
    G1 X45.5601 Y-20.7583
    G1 X45.1763 Y-21.9077
    G1 X44.727 Y-23.0332
    G1 X44.2137 Y-24.1309
    G1 X43.6393 Y-25.1953
    G1 X43.0022 Y-26.2288
    G1 X42.3079 Y-27.2221
    G1 X41.5576 Y-28.1737
    G1 X40.7539 Y-29.0806
    G1 X39.8993 Y-29.9398
    G1 X38.9967 Y-30.7484
    G1 X38.0491 Y-31.5037
    G1 X37.0596 Y-32.2033
    G1 X36.0315 Y-32.8447
    G1 X34.9682 Y-33.426
    G1 X33.8732 Y-33.9452
    G1 X32.7502 Y-34.4005
    G1 X31.6028 Y-34.7904
    G1 X30.4349 Y-35.1137
    G1 X29.2504 Y-35.3693
    G1 X28.0531 Y-35.5563
    G1 X26.847 Y-35.6741
    G1 X25.6362 Y-35.7224
    G1 X24.4246 Y-35.7009
    G1 X23.2162 Y-35.6098
    G1 X22.015 Y-35.4493
    G1 X20.8251 Y-35.2199
    G1 X19.6504 Y-34.9225
    G1 X18.4947 Y-34.558
    G1 X17.3619 Y-34.1277
    G1 X16.2557 Y-33.6328
    G1 X15.1798 Y-33.0752
    G1 X14.1378 Y-32.4566
    G1 X13.1331 Y-31.7791
    G1 X12.169 Y-31.0449
    G1 X11.2487 Y-30.2564
    G1 X10.3754 Y-29.4164
    G1 X9.5518 Y-28.5274
    G1 X8.7807 Y-27.5926
    G1 X8.0646 Y-26.615
    G1 X7.406 Y-25.5978
    G1 X7.0557 Y-24.9817
    G1 X7.0113 Y-24.8946
    G1 X6.8775 Y-24.6683
    G1 X6.8635 Y-24.6437
    G1 X6.7569 Y-24.4641
    G1 X6.4731 Y-24.0466
    G1 X6.1652 Y-23.6496
    G1 X5.833 Y-23.2727
    G1 X5.4777 Y-22.9174
    G1 X5.1008 Y-22.5852
    G1 X4.7038 Y-22.2773
    G1 X4.2883 Y-21.9949
    G1 X3.8558 Y-21.7391
    G1 X3.4082 Y-21.511
    G1 X2.9471 Y-21.3115
    G1 X2.4744 Y-21.1413
    G1 X1.9919 Y-21.0011
    G1 X1.5016 Y-20.8915
    G1 X1.0054 Y-20.8129
    G1 X0.5052 Y-20.7656
    G1 X0.0026 Y-20.7499
    G1 X-0.5056 Y-20.7657
    G1 X-1.0054 Y-20.8129
    G1 X-1.5016 Y-20.8915
    G1 X-1.9919 Y-21.0011
    G1 X-2.4744 Y-21.1413
    G1 X-2.9471 Y-21.3115
    G1 X-3.4082 Y-21.511
    G1 X-3.8558 Y-21.7391
    G1 X-4.2883 Y-21.9949
    G1 X-4.7038 Y-22.2773
    G1 X-5.1008 Y-22.5852
    G1 X-5.4777 Y-22.9174
    G1 X-5.833 Y-23.2727
    G1 X-6.1652 Y-23.6496
    G1 X-6.4731 Y-24.0466
    G1 X-6.7569 Y-24.4641
    G1 X-6.8635 Y-24.6437
    G1 X-6.8775 Y-24.6683
    G1 X-7.0113 Y-24.8946
    G1 X-7.0557 Y-24.9817
    G1 X-7.406 Y-25.5978
    G1 X-8.0646 Y-26.615
    G1 X-8.7807 Y-27.5926
    G1 X-9.5518 Y-28.5274
    G1 X-10.3754 Y-29.4164
    G1 X-11.2487 Y-30.2564
    G1 X-12.169 Y-31.0449
    G1 X-13.1331 Y-31.7791
    G1 X-14.1378 Y-32.4566
    G1 X-15.1798 Y-33.0752
    G1 X-16.2557 Y-33.6328
    G1 X-17.3619 Y-34.1277
    G1 X-18.4947 Y-34.558
    G1 X-19.6504 Y-34.9225
    G1 X-20.8251 Y-35.2199
    G1 X-22.015 Y-35.4493
    G1 X-23.2162 Y-35.6098
    G1 X-24.4246 Y-35.7009
    G1 X-25.6362 Y-35.7224
    G1 X-26.847 Y-35.6741
    G1 X-28.0531 Y-35.5563
    G1 X-29.2504 Y-35.3693
    G1 X-30.4349 Y-35.1137
    G1 X-31.6028 Y-34.7904
    G1 X-32.7502 Y-34.4005
    G1 X-33.8732 Y-33.9452
    G1 X-34.9682 Y-33.426
    G1 X-36.0315 Y-32.8447
    G1 X-37.0596 Y-32.2033
    G1 X-38.0491 Y-31.5037
    G1 X-38.9967 Y-30.7484
    G1 X-39.8993 Y-29.9398
    G1 X-40.7539 Y-29.0806
    G1 X-41.5576 Y-28.1737
    G1 X-42.3079 Y-27.2221
    G1 X-43.0022 Y-26.2288
    G1 X-43.6393 Y-25.1953
    G1 X-44.2137 Y-24.1309
    G1 X-44.727 Y-23.0332
    G1 X-45.1763 Y-21.9077
    G1 X-45.5601 Y-20.7583
    G1 X-45.8771 Y-19.5887
    G1 X-46.1263 Y-18.4028
    G1 X-46.3069 Y-17.2045
    G1 X-46.4183 Y-15.9979
    G1 X-46.4601 Y-14.7868
    G1 X-46.4321 Y-13.5753
    G1 X-46.3345 Y-12.3674
    G1 X-46.1676 Y-11.1671
    G1 X-45.9319 Y-9.9785
    G1 X-45.6282 Y-8.8053
    G1 X-45.2575 Y-7.6516
    G1 X-44.8211 Y-6.5211
    G1 X-44.3204 Y-5.4176
    G1 X-43.757 Y-4.3447
    G1 X-43.1328 Y-3.306
    G1 X-42.4499 Y-2.3049
    G1 X-41.7106 Y-1.3448
    G1 X-40.9173 Y-0.4288
    G1 X-40.0725 Y0.4401
    G1 X-39.1792 Y1.2589
    G1 X-38.2403 Y2.025
    G1 X-37.2588 Y2.7358
    G1 X-36.2381 Y3.389
    G1 X-35.1815 Y3.9823
    G1 X-34.0925 Y4.5139
    G1 X-32.9747 Y4.982
    G1 X-31.8319 Y5.385
    G1 X-30.6678 Y5.7216
    G1 X-29.4862 Y5.9907
    G1 X-28.2911 Y6.1913
    G1 X-27.0865 Y6.3229
    G1 X-25.9387 Y6.3818
    G1 X-24.4231 Y6.4353
    G1 X-23.9171 Y6.4832
    G1 X-23.4208 Y6.5618
    G1 X-22.9305 Y6.6714
    G1 X-22.448 Y6.8115
    G1 X-21.9753 Y6.9817
    G1 X-21.5142 Y7.1813
    G1 X-21.0666 Y7.4094
    G1 X-20.6341 Y7.6651
    G1 X-20.2186 Y7.9475
    G1 X-19.8216 Y8.2554
    G1 X-19.4447 Y8.5877
    G1 X-19.0895 Y8.943
    G1 X-18.7572 Y9.3198
    G1 X-18.4493 Y9.7168
    ( 46 )
    S1000
    G1 Z-1.0
    G1 X-19.0895 Y8.943
    G1 X-22.448 Y6.8115
    G1 X-31.8319 Y5.385
    G1 X-32.9747 Y4.982
    G1 X-36.2381 Y3.389
    G1 X-38.2403 Y2.025
    G1 X3.4082 Y-21.511
    G1 X5.833 Y-23.2727
    G1 X7.406 Y-25.5978
    G1 X8.0646 Y-26.615
    G1 X43.757 Y-4.3447
    G1 X43.1328 Y-3.306
    G1 X40.0725 Y0.4401
    G1 X39.1792 Y1.2589
    G1 X38.2403 Y2.025
    G1 X37.2588 Y2.7358
    G1 X36.2381 Y3.389
    G1 X35.1815 Y3.9823
    G1 X34.0925 Y4.5139
    G1 X32.9747 Y4.982
    G1 X31.8319 Y5.385
    G1 X30.6678 Y5.7216
    G1 X29.4862 Y5.9907
    G1 X28.2911 Y6.1913
    G1 X27.0865 Y6.3229
    G1 X25.9387 Y6.3818
    G1 X24.4231 Y6.4353
    G1 X23.9171 Y6.4832
    G1 X23.4208 Y6.5618
    G1 X22.9305 Y6.6714
    G1 X22.448 Y6.8115
    G1 X21.9753 Y6.9817
    G1 X21.5142 Y7.1813
    G1 X21.0666 Y7.4094
    G1 X20.6341 Y7.6651
    G1 X20.2186 Y7.9475
    G1 X19.8216 Y8.2554
    G1 X19.4447 Y8.5877
    G1 X19.0895 Y8.943
    G1 X18.7572 Y9.3198
    G1 X18.4493 Y9.7168
    G1 X17.683 Y11.0125
    G1 X16.9849 Y15.42
    G1 X17.3133 Y16.889
    G1 X17.683 Y17.8228
    G1 X18.219 Y18.7912
    G1 X18.465 Y19.2123
    G1 X21.0064 Y30.791
    G1 X20.8891 Y31.987
    G1 X19.7464 Y36.646
    G1 X16.889 Y41.9095
    G1 X16.144 Y42.8525
    G1 X14.499 Y44.6034
    G1 X11.685 Y46.8507
    G1 X9.6136 Y48.0677
    G1 X8.5292 Y48.5856
    G1 X7.417 Y49.0408
    G1 X6.2807 Y49.4319
    G1 X5.1239 Y49.7574
    G1 X3.9504 Y50.0165
    G1 X2.7641 Y50.2081
    G1 X1.5687 Y50.3318
    G1 X0.3683 Y50.3871
    G1 X0.0 Y50.3831
    G1 X-7.417 Y49.0408
    G1 X-16.9849 Y15.42
    ( 47 )
    S1000
    G1 Z-2.0
    G1 X-19.0895 Y8.943
    G1 X-22.448 Y6.8115
    G1 X-31.8319 Y5.385
    G1 X-32.9747 Y4.982
    G1 X-36.2381 Y3.389
    G1 X-38.2403 Y2.025
    G1 X3.4082 Y-21.511
    G1 X5.833 Y-23.2727
    G1 X7.406 Y-25.5978
    G1 X8.0646 Y-26.615
    G1 X43.757 Y-4.3447
    G1 X43.1328 Y-3.306
    G1 X40.0725 Y0.4401
    G1 X39.1792 Y1.2589
    G1 X38.2403 Y2.025
    G1 X37.2588 Y2.7358
    G1 X36.2381 Y3.389
    G1 X35.1815 Y3.9823
    G1 X34.0925 Y4.5139
    G1 X32.9747 Y4.982
    G1 X31.8319 Y5.385
    G1 X30.6678 Y5.7216
    G1 X29.4862 Y5.9907
    G1 X28.2911 Y6.1913
    G1 X27.0865 Y6.3229
    G1 X25.9387 Y6.3818
    G1 X24.4231 Y6.4353
    G1 X23.9171 Y6.4832
    G1 X23.4208 Y6.5618
    G1 X22.9305 Y6.6714
    G1 X22.448 Y6.8115
    G1 X21.9753 Y6.9817
    G1 X21.5142 Y7.1813
    G1 X21.0666 Y7.4094
    G1 X20.6341 Y7.6651
    G1 X20.2186 Y7.9475
    G1 X19.8216 Y8.2554
    G1 X19.4447 Y8.5877
    G1 X19.0895 Y8.943
    G1 X18.7572 Y9.3198
    G1 X18.4493 Y9.7168
    G1 X17.683 Y11.0125
    G1 X16.9849 Y15.42
    G1 X17.3133 Y16.889
    G1 X17.683 Y17.8228
    G1 X18.219 Y18.7912
    G1 X18.465 Y19.2123
    G1 X21.0064 Y30.791
    G1 X20.8891 Y31.987
    G1 X19.7464 Y36.646
    G1 X16.889 Y41.9095
    G1 X16.144 Y42.8525
    G1 X14.499 Y44.6034
    G1 X11.685 Y46.8507
    G1 X9.6136 Y48.0677
    G1 X8.5292 Y48.5856
    G1 X7.417 Y49.0408
    G1 X6.2807 Y49.4319
    G1 X5.1239 Y49.7574
    G1 X3.9504 Y50.0165
    G1 X2.7641 Y50.2081
    G1 X1.5687 Y50.3318
    G1 X0.3683 Y50.3871
    G1 X0.0 Y50.3831
    G1 X-7.417 Y49.0408
    G1 X-16.9849 Y15.42
    ( 48 )
    S1000
    G1 Z-3.0
    G1 X-19.0895 Y8.943
    G1 X-22.448 Y6.8115
    G1 X-31.8319 Y5.385
    G1 X-32.9747 Y4.982
    G1 X-36.2381 Y3.389
    G1 X-38.2403 Y2.025
    G1 X3.4082 Y-21.511
    G1 X5.833 Y-23.2727
    G1 X7.406 Y-25.5978
    G1 X8.0646 Y-26.615
    G1 X43.757 Y-4.3447
    G1 X43.1328 Y-3.306
    G1 X40.0725 Y0.4401
    G1 X39.1792 Y1.2589
    G1 X38.2403 Y2.025
    G1 X37.2588 Y2.7358
    G1 X36.2381 Y3.389
    G1 X35.1815 Y3.9823
    G1 X34.0925 Y4.5139
    G1 X32.9747 Y4.982
    G1 X31.8319 Y5.385
    G1 X30.6678 Y5.7216
    G1 X29.4862 Y5.9907
    G1 X28.2911 Y6.1913
    G1 X27.0865 Y6.3229
    G1 X25.9387 Y6.3818
    G1 X24.4231 Y6.4353
    G1 X23.9171 Y6.4832
    G1 X23.4208 Y6.5618
    G1 X22.9305 Y6.6714
    G1 X22.448 Y6.8115
    G1 X21.9753 Y6.9817
    G1 X21.5142 Y7.1813
    G1 X21.0666 Y7.4094
    G1 X20.6341 Y7.6651
    G1 X20.2186 Y7.9475
    G1 X19.8216 Y8.2554
    G1 X19.4447 Y8.5877
    G1 X19.0895 Y8.943
    G1 X18.7572 Y9.3198
    G1 X18.4493 Y9.7168
    G1 X17.683 Y11.0125
    G1 X16.9849 Y15.42
    G1 X17.3133 Y16.889
    G1 X17.683 Y17.8228
    G1 X18.219 Y18.7912
    G1 X18.465 Y19.2123
    G1 X21.0064 Y30.791
    G1 X20.8891 Y31.987
    G1 X19.7464 Y36.646
    G1 X16.889 Y41.9095
    G1 X16.144 Y42.8525
    G1 X14.499 Y44.6034
    G1 X11.685 Y46.8507
    G1 X9.6136 Y48.0677
    G1 X8.5292 Y48.5856
    G1 X7.417 Y49.0408
    G1 X6.2807 Y49.4319
    G1 X5.1239 Y49.7574
    G1 X3.9504 Y50.0165
    G1 X2.7641 Y50.2081
    G1 X1.5687 Y50.3318
    G1 X0.3683 Y50.3871
    G1 X0.0 Y50.3831
    G1 X-7.417 Y49.0408
    G1 X-16.9849 Y15.42
    ( 49 )
    S1000
    G1 Z-4.0
    G1 X-16.9849 Y15.42
    G1 X-7.417 Y49.0408
    G1 X0.0 Y50.3831
    G1 X0.3683 Y50.3871
    G1 X1.5687 Y50.3318
    G1 X2.7641 Y50.2081
    G1 X3.9504 Y50.0165
    G1 X5.1239 Y49.7574
    G1 X6.2807 Y49.4319
    G1 X7.417 Y49.0408
    G1 X8.5292 Y48.5856
    G1 X9.6136 Y48.0677
    G1 X11.685 Y46.8507
    G1 X14.499 Y44.6034
    G1 X16.144 Y42.8525
    G1 X16.889 Y41.9095
    G1 X19.7464 Y36.646
    G1 X20.8891 Y31.987
    G1 X21.0064 Y30.791
    G1 X18.465 Y19.2123
    G1 X18.219 Y18.7912
    G1 X17.683 Y17.8228
    G1 X17.3133 Y16.889
    G1 X16.9849 Y15.42
    G1 X17.683 Y11.0125
    G1 X18.4493 Y9.7168
    G1 X18.7572 Y9.3198
    G1 X19.0895 Y8.943
    G1 X19.4447 Y8.5877
    G1 X19.8216 Y8.2554
    G1 X20.2186 Y7.9475
    G1 X20.6341 Y7.6651
    G1 X21.0666 Y7.4094
    G1 X21.5142 Y7.1813
    G1 X21.9753 Y6.9817
    G1 X22.448 Y6.8115
    G1 X22.9305 Y6.6714
    G1 X23.4208 Y6.5618
    G1 X23.9171 Y6.4832
    G1 X24.4231 Y6.4353
    G1 X25.9387 Y6.3818
    G1 X27.0865 Y6.3229
    G1 X28.2911 Y6.1913
    G1 X29.4862 Y5.9907
    G1 X30.6678 Y5.7216
    G1 X31.8319 Y5.385
    G1 X32.9747 Y4.982
    G1 X34.0925 Y4.5139
    G1 X35.1815 Y3.9823
    G1 X36.2381 Y3.389
    G1 X37.2588 Y2.7358
    G1 X38.2403 Y2.025
    G1 X39.1792 Y1.2589
    G1 X40.0725 Y0.4401
    G1 X43.1328 Y-3.306
    G1 X43.757 Y-4.3447
    G1 X8.0646 Y-26.615
    G1 X7.406 Y-25.5978
    G1 X5.833 Y-23.2727
    G1 X3.4082 Y-21.511
    G1 X-38.2403 Y2.025
    G1 X-36.2381 Y3.389
    G1 X-32.9747 Y4.982
    G1 X-31.8319 Y5.385
    G1 X-22.448 Y6.8115
    G1 X-19.0895 Y8.943
    ( 50 )
    S1000
    G1 Z-5.0
    G1 X-19.0895 Y8.943
    G1 X-22.448 Y6.8115
    G1 X-31.8319 Y5.385
    G1 X-32.9747 Y4.982
    G1 X-36.2381 Y3.389
    G1 X-38.2403 Y2.025
    G1 X3.4082 Y-21.511
    G1 X5.833 Y-23.2727
    G1 X7.406 Y-25.5978
    G1 X8.0646 Y-26.615
    G1 X43.757 Y-4.3447
    G1 X43.1328 Y-3.306
    G1 X40.0725 Y0.4401
    G1 X39.1792 Y1.2589
    G1 X38.2403 Y2.025
    G1 X37.2588 Y2.7358
    G1 X36.2381 Y3.389
    G1 X35.1815 Y3.9823
    G1 X34.0925 Y4.5139
    G1 X32.9747 Y4.982
    G1 X31.8319 Y5.385
    G1 X30.6678 Y5.7216
    G1 X29.4862 Y5.9907
    G1 X28.2911 Y6.1913
    G1 X27.0865 Y6.3229
    G1 X25.9387 Y6.3818
    G1 X24.4231 Y6.4353
    G1 X23.9171 Y6.4832
    G1 X23.4208 Y6.5618
    G1 X22.9305 Y6.6714
    G1 X22.448 Y6.8115
    G1 X21.9753 Y6.9817
    G1 X21.5142 Y7.1813
    G1 X21.0666 Y7.4094
    G1 X20.6341 Y7.6651
    G1 X20.2186 Y7.9475
    G1 X19.8216 Y8.2554
    G1 X19.4447 Y8.5877
    G1 X19.0895 Y8.943
    G1 X18.7572 Y9.3198
    G1 X18.4493 Y9.7168
    G1 X17.683 Y11.0125
    G1 X16.9849 Y15.42
    G1 X17.3133 Y16.889
    G1 X17.683 Y17.8228
    G1 X18.219 Y18.7912
    G1 X18.465 Y19.2123
    G1 X21.0064 Y30.791
    G1 X20.8891 Y31.987
    G1 X19.7464 Y36.646
    G1 X16.889 Y41.9095
    G1 X16.144 Y42.8525
    G1 X14.499 Y44.6034
    G1 X11.685 Y46.8507
    G1 X9.6136 Y48.0677
    G1 X8.5292 Y48.5856
    G1 X7.417 Y49.0408
    G1 X6.2807 Y49.4319
    G1 X5.1239 Y49.7574
    G1 X3.9504 Y50.0165
    G1 X2.7641 Y50.2081
    G1 X1.5687 Y50.3318
    G1 X0.3683 Y50.3871
    G1 X0.0 Y50.3831
    G1 X-7.417 Y49.0408
    G1 X-16.9849 Y15.42
    ( 51 )
    S1000
    G1 Z-6.0
    G1 X-19.0895 Y8.943
    G1 X-22.448 Y6.8115
    G1 X-31.8319 Y5.385
    G1 X-32.9747 Y4.982
    G1 X-36.2381 Y3.389
    G1 X-38.2403 Y2.025
    G1 X3.4082 Y-21.511
    G1 X5.833 Y-23.2727
    G1 X7.406 Y-25.5978
    G1 X8.0646 Y-26.615
    G1 X43.757 Y-4.3447
    G1 X43.1328 Y-3.306
    G1 X40.0725 Y0.4401
    G1 X39.1792 Y1.2589
    G1 X38.2403 Y2.025
    G1 X37.2588 Y2.7358
    G1 X36.2381 Y3.389
    G1 X35.1815 Y3.9823
    G1 X34.0925 Y4.5139
    G1 X32.9747 Y4.982
    G1 X31.8319 Y5.385
    G1 X30.6678 Y5.7216
    G1 X29.4862 Y5.9907
    G1 X28.2911 Y6.1913
    G1 X27.0865 Y6.3229
    G1 X25.9387 Y6.3818
    G1 X24.4231 Y6.4353
    G1 X23.9171 Y6.4832
    G1 X23.4208 Y6.5618
    G1 X22.9305 Y6.6714
    G1 X22.448 Y6.8115
    G1 X21.9753 Y6.9817
    G1 X21.5142 Y7.1813
    G1 X21.0666 Y7.4094
    G1 X20.6341 Y7.6651
    G1 X20.2186 Y7.9475
    G1 X19.8216 Y8.2554
    G1 X19.4447 Y8.5877
    G1 X19.0895 Y8.943
    G1 X18.7572 Y9.3198
    G1 X18.4493 Y9.7168
    G1 X17.683 Y11.0125
    G1 X16.9849 Y15.42
    G1 X17.3133 Y16.889
    G1 X17.683 Y17.8228
    G1 X18.219 Y18.7912
    G1 X18.465 Y19.2123
    G1 X21.0064 Y30.791
    G1 X20.8891 Y31.987
    G1 X19.7464 Y36.646
    G1 X16.889 Y41.9095
    G1 X16.144 Y42.8525
    G1 X14.499 Y44.6034
    G1 X11.685 Y46.8507
    G1 X9.6136 Y48.0677
    G1 X8.5292 Y48.5856
    G1 X7.417 Y49.0408
    G1 X6.2807 Y49.4319
    G1 X5.1239 Y49.7574
    G1 X3.9504 Y50.0165
    G1 X2.7641 Y50.2081
    G1 X1.5687 Y50.3318
    G1 X0.3683 Y50.3871
    G1 X0.0 Y50.3831
    G1 X-7.417 Y49.0408
    G1 X-16.9849 Y15.42
    ( 52 )
    S1000
    G1 Z-7.0
    G1 X-16.9849 Y15.42
    G1 X-7.417 Y49.0408
    G1 X0.0 Y50.3831
    G1 X0.3683 Y50.3871
    G1 X1.5687 Y50.3318
    G1 X2.7641 Y50.2081
    G1 X3.9504 Y50.0165
    G1 X5.1239 Y49.7574
    G1 X6.2807 Y49.4319
    G1 X7.417 Y49.0408
    G1 X8.5292 Y48.5856
    G1 X9.6136 Y48.0677
    G1 X11.685 Y46.8507
    G1 X14.499 Y44.6034
    G1 X16.144 Y42.8525
    G1 X16.889 Y41.9095
    G1 X19.7464 Y36.646
    G1 X20.8891 Y31.987
    G1 X21.0064 Y30.791
    G1 X18.465 Y19.2123
    G1 X18.219 Y18.7912
    G1 X17.683 Y17.8228
    G1 X17.3133 Y16.889
    G1 X16.9849 Y15.42
    G1 X17.683 Y11.0125
    G1 X18.4493 Y9.7168
    G1 X18.7572 Y9.3198
    G1 X19.0895 Y8.943
    G1 X19.4447 Y8.5877
    G1 X19.8216 Y8.2554
    G1 X20.2186 Y7.9475
    G1 X20.6341 Y7.6651
    G1 X21.0666 Y7.4094
    G1 X21.5142 Y7.1813
    G1 X21.9753 Y6.9817
    G1 X22.448 Y6.8115
    G1 X22.9305 Y6.6714
    G1 X23.4208 Y6.5618
    G1 X23.9171 Y6.4832
    G1 X24.4231 Y6.4353
    G1 X25.9387 Y6.3818
    G1 X27.0865 Y6.3229
    G1 X28.2911 Y6.1913
    G1 X29.4862 Y5.9907
    G1 X30.6678 Y5.7216
    G1 X31.8319 Y5.385
    G1 X32.9747 Y4.982
    G1 X34.0925 Y4.5139
    G1 X35.1815 Y3.9823
    G1 X36.2381 Y3.389
    G1 X37.2588 Y2.7358
    G1 X38.2403 Y2.025
    G1 X39.1792 Y1.2589
    G1 X40.0725 Y0.4401
    G1 X43.1328 Y-3.306
    G1 X43.757 Y-4.3447
    G1 X8.0646 Y-26.615
    G1 X7.406 Y-25.5978
    G1 X5.833 Y-23.2727
    G1 X3.4082 Y-21.511
    G1 X-38.2403 Y2.025
    G1 X-36.2381 Y3.389
    G1 X-32.9747 Y4.982
    G1 X-31.8319 Y5.385
    G1 X-22.448 Y6.8115
    G1 X-19.0895 Y8.943
    ( 53 )
    S1000
    G1 Z-8.0
    G1 X-16.9849 Y15.42
    G1 X-7.417 Y49.0408
    G1 X0.0 Y50.3831
    G1 X0.3683 Y50.3871
    G1 X1.5687 Y50.3318
    G1 X2.7641 Y50.2081
    G1 X3.9504 Y50.0165
    G1 X5.1239 Y49.7574
    G1 X6.2807 Y49.4319
    G1 X7.417 Y49.0408
    G1 X8.5292 Y48.5856
    G1 X9.6136 Y48.0677
    G1 X11.685 Y46.8507
    G1 X14.499 Y44.6034
    G1 X16.144 Y42.8525
    G1 X16.889 Y41.9095
    G1 X19.7464 Y36.646
    G1 X20.8891 Y31.987
    G1 X21.0064 Y30.791
    G1 X18.465 Y19.2123
    G1 X18.219 Y18.7912
    G1 X17.683 Y17.8228
    G1 X17.3133 Y16.889
    G1 X16.9849 Y15.42
    G1 X17.683 Y11.0125
    G1 X18.4493 Y9.7168
    G1 X18.7572 Y9.3198
    G1 X19.0895 Y8.943
    G1 X19.4447 Y8.5877
    G1 X19.8216 Y8.2554
    G1 X20.2186 Y7.9475
    G1 X20.6341 Y7.6651
    G1 X21.0666 Y7.4094
    G1 X21.5142 Y7.1813
    G1 X21.9753 Y6.9817
    G1 X22.448 Y6.8115
    G1 X22.9305 Y6.6714
    G1 X23.4208 Y6.5618
    G1 X23.9171 Y6.4832
    G1 X24.4231 Y6.4353
    G1 X25.9387 Y6.3818
    G1 X27.0865 Y6.3229
    G1 X28.2911 Y6.1913
    G1 X29.4862 Y5.9907
    G1 X30.6678 Y5.7216
    G1 X31.8319 Y5.385
    G1 X32.9747 Y4.982
    G1 X34.0925 Y4.5139
    G1 X35.1815 Y3.9823
    G1 X36.2381 Y3.389
    G1 X37.2588 Y2.7358
    G1 X38.2403 Y2.025
    G1 X39.1792 Y1.2589
    G1 X40.0725 Y0.4401
    G1 X43.1328 Y-3.306
    G1 X43.757 Y-4.3447
    G1 X8.0646 Y-26.615
    G1 X7.406 Y-25.5978
    G1 X5.833 Y-23.2727
    G1 X3.4082 Y-21.511
    G1 X-38.2403 Y2.025
    G1 X-36.2381 Y3.389
    G1 X-32.9747 Y4.982
    G1 X-31.8319 Y5.385
    G1 X-22.448 Y6.8115
    G1 X-19.0895 Y8.943
    ( 54 )
    S1000
    G1 Z-9.0
    G1 X-19.0895 Y8.943
    G1 X-22.448 Y6.8115
    G1 X-31.8319 Y5.385
    G1 X-32.9747 Y4.982
    G1 X-36.2381 Y3.389
    G1 X-38.2403 Y2.025
    G1 X3.4082 Y-21.511
    G1 X5.833 Y-23.2727
    G1 X7.406 Y-25.5978
    G1 X8.0646 Y-26.615
    G1 X43.757 Y-4.3447
    G1 X43.1328 Y-3.306
    G1 X40.0725 Y0.4401
    G1 X39.1792 Y1.2589
    G1 X38.2403 Y2.025
    G1 X37.2588 Y2.7358
    G1 X36.2381 Y3.389
    G1 X35.1815 Y3.9823
    G1 X34.0925 Y4.5139
    G1 X32.9747 Y4.982
    G1 X31.8319 Y5.385
    G1 X30.6678 Y5.7216
    G1 X29.4862 Y5.9907
    G1 X28.2911 Y6.1913
    G1 X27.0865 Y6.3229
    G1 X25.9387 Y6.3818
    G1 X24.4231 Y6.4353
    G1 X23.9171 Y6.4832
    G1 X23.4208 Y6.5618
    G1 X22.9305 Y6.6714
    G1 X22.448 Y6.8115
    G1 X21.9753 Y6.9817
    G1 X21.5142 Y7.1813
    G1 X21.0666 Y7.4094
    G1 X20.6341 Y7.6651
    G1 X20.2186 Y7.9475
    G1 X19.8216 Y8.2554
    G1 X19.4447 Y8.5877
    G1 X19.0895 Y8.943
    G1 X18.7572 Y9.3198
    G1 X18.4493 Y9.7168
    G1 X17.683 Y11.0125
    G1 X16.9849 Y15.42
    G1 X17.3133 Y16.889
    G1 X17.683 Y17.8228
    G1 X18.219 Y18.7912
    G1 X18.465 Y19.2123
    G1 X21.0064 Y30.791
    G1 X20.8891 Y31.987
    G1 X19.7464 Y36.646
    G1 X16.889 Y41.9095
    G1 X16.144 Y42.8525
    G1 X14.499 Y44.6034
    G1 X11.685 Y46.8507
    G1 X9.6136 Y48.0677
    G1 X8.5292 Y48.5856
    G1 X7.417 Y49.0408
    G1 X6.2807 Y49.4319
    G1 X5.1239 Y49.7574
    G1 X3.9504 Y50.0165
    G1 X2.7641 Y50.2081
    G1 X1.5687 Y50.3318
    G1 X0.3683 Y50.3871
    G1 X0.0 Y50.3831
    G1 X-7.417 Y49.0408
    G1 X-16.9849 Y15.42
    ( 55 )
    S1000
    G1 Z-10.0
    G1 X-16.9849 Y15.42
    G1 X-7.417 Y49.0408
    G1 X0.0 Y50.3831
    G1 X0.3683 Y50.3871
    G1 X1.5687 Y50.3318
    G1 X2.7641 Y50.2081
    G1 X3.9504 Y50.0165
    G1 X5.1239 Y49.7574
    G1 X6.2807 Y49.4319
    G1 X7.417 Y49.0408
    G1 X8.5292 Y48.5856
    G1 X9.6136 Y48.0677
    G1 X11.685 Y46.8507
    G1 X14.499 Y44.6034
    G1 X16.144 Y42.8525
    G1 X16.889 Y41.9095
    G1 X19.7464 Y36.646
    G1 X20.8891 Y31.987
    G1 X21.0064 Y30.791
    G1 X18.465 Y19.2123
    G1 X18.219 Y18.7912
    G1 X17.683 Y17.8228
    G1 X17.3133 Y16.889
    G1 X16.9849 Y15.42
    G1 X17.683 Y11.0125
    G1 X18.4493 Y9.7168
    G1 X18.7572 Y9.3198
    G1 X19.0895 Y8.943
    G1 X19.4447 Y8.5877
    G1 X19.8216 Y8.2554
    G1 X20.2186 Y7.9475
    G1 X20.6341 Y7.6651
    G1 X21.0666 Y7.4094
    G1 X21.5142 Y7.1813
    G1 X21.9753 Y6.9817
    G1 X22.448 Y6.8115
    G1 X22.9305 Y6.6714
    G1 X23.4208 Y6.5618
    G1 X23.9171 Y6.4832
    G1 X24.4231 Y6.4353
    G1 X25.9387 Y6.3818
    G1 X27.0865 Y6.3229
    G1 X28.2911 Y6.1913
    G1 X29.4862 Y5.9907
    G1 X30.6678 Y5.7216
    G1 X31.8319 Y5.385
    G1 X32.9747 Y4.982
    G1 X34.0925 Y4.5139
    G1 X35.1815 Y3.9823
    G1 X36.2381 Y3.389
    G1 X37.2588 Y2.7358
    G1 X38.2403 Y2.025
    G1 X39.1792 Y1.2589
    G1 X40.0725 Y0.4401
    G1 X43.1328 Y-3.306
    G1 X43.757 Y-4.3447
    G1 X8.0646 Y-26.615
    G1 X7.406 Y-25.5978
    G1 X5.833 Y-23.2727
    G1 X3.4082 Y-21.511
    G1 X-38.2403 Y2.025
    G1 X-36.2381 Y3.389
    G1 X-32.9747 Y4.982
    G1 X-31.8319 Y5.385
    G1 X-22.448 Y6.8115
    G1 X-19.0895 Y8.943
    G0 Z3.0
    G0 X0 Y0
    G0 Z0
    M5
    M30
    Feb 2017
    10
    Re: Circles not coming out the right size
    I had calibrated it before but I decided to do it again. It came out perfect, it moved exactly how far it was supposed to and the X, Y, and Z steps were what the manufacturer said they were going to be.
    Feb 2017
    10
    Quote Originally Posted by KH0UJ View Post
    How thick is the material you want to be cut? do you really want to use a 6mm bit on such a small output to be machined? I do think if you use a 1/8 end mill do to just outlining stuff would be more efficient than pocketing specially aluminum material, it gets the job done faster to just cut it than pulverizing the whole circle though.
    I cut out the spinner using your g code and it came out almost perfect about .2mm too small. The material I will mainly be cutting through is 1/4".
    I did switch to a 4mm end mill and just did a profile cut for the holes and the outline. That did help some but was still small around .2mm.
    Jul 2016
    660
    OK so 4mm size tool bit, 6.35mm thick aluminum material? how much pass do you want it to be for I dont know how strong your CNC was, is the 1000 feed rate and plunge rate 1000 OK for you? because I usually work on aluminum @ 0.2mm pass, feed rate of 400 and plunge rate of 100 with 1/8 single flute carbide tool bit.
    Feb 2017
    10
    The feed rate and plunge was fine for the wood but I haven't cut any aluminum yet. I wanted to make sure everything was cutting correctly before I started on aluminum. I have 2 sheets of aluminum 4"x 12"x 1/4" sitting by for when I do start.
    The machine I'm using is a Romaxx HS-1 Romaxx CNC Router HS-1 machine a CNC workhorse | Romaxx CNC Router Systems it's a very well built machine really solid. I just wanted to get this circle problem under control before I started cutting aluminum.
    Jul 2016
    660
    Sorry double post, my hand is too big on the smart phone
    Jul 2016
    660
    Quote Originally Posted by darkclown View Post
    So the circle was still elipse using the sketchup code sir? @ which axis had a longer measurement? It's perfectly fine here using my cnc machine, i do think you need to recalibrate in mach 3 on which axis is longer, for example the y axis is longer then go to calibration page then choose y axis then input 10mm then when it ask for how long it travelled you enter 10.2mm, in that way it will re adjust it's calibration to achieve perfect cutting measurement.
    Feb 2017
    10
    OK so I did what you said and re calibrated in mach 3. The circle that was coming from my machine was way screwed up so I had to adjust both the X and Y axis. After doing that I did a couple test circles and they weren't perfect but they are a lot better then before. My question is, the circles are still a little off on both axis should I try re calibrating again would that help or should I need to only re calibrate once to correct the problem?
    Thanks for all your help I do appreciate it.
    Jul 2016
    660
    You`re almost there sir you need to fine tune on your output cut to have a perfect circle, but if you want an easier step you can try sample cutting square instead of a circle, like for example 40mm X 40mm, it`s easier for you to measure squares than circles and it`s the same thing, so if you perfected the 40mm X 40mm square it should be perfect on all circle cuts on your machine, it`s the same fine tuning step but easier to measure
    I wouldn't consider a Romaxx to be "really solid". and I think that the issues you are seeing are mostly related to flex in the machine.
    Feb 2017
    10
    OK so I took your advise and cut out a square and measured it and of course it was off on the measurements so I re calibrated it and adding in the updated measurements and cut out a new square. So I measured this new square and it was still off and I thought this can't be right and if it's not getting better with the re calibration and the software it must be something mechanical on the machine itself that's messing everything up.
    So before I go on yes I'm a newbie to CNC this is my first machine and even though I'm having troubles with it it's all a learning experience to me. I have always loved this quote by Thomas A. Edison "I have not failed. I've just found 10,000 ways that won't work."
    Well to make a long story I did fix my problem finally. The problem wasn't in the calibration but the machine itself. The problem was with the Z axis being lose it was only like 1-2mm off but that was enough to screw everything up. It didn't dawn on me at all that this little bit of play in the Z axis would be what was messing me up all this time.
    The other problem was that when I received this machine it didn't come with an owners manual or any documentation on the machine at all. I emailed the owner several times with my problem and after week of no responses from him I decided to take matters into my own hands even though I had no idea how to even fix the problem. So I grabbed my crescent wrench and went to work on the machine and finally found out through trial and error that all I had to do to fix the problem was use my wrench to tweak some of the bearings in the Z axis slide and that seemed to solve my problem.
    I wanted to thank everyone that took the time to help me out especially KH0UJ you didn't have to but you did and for that I am very grateful.
    Thanks again
    Jun 2010
    4256
    We strongly disapprove of using a crescent wrench when you should be using a big hammer...
    Cheers
    Oct 2005
    8
    null
    Dec 2012
    46
    I use Fusion 360 to create the design then I export it as .dxf file into Aspire 8.5 then I use the post processor there to create the G code I use in Mach3.
    Since Fusion 360 is capable of doing the CAM (creating the g-code), why are you exporting to DXF and importing into Aspire? The g-code you posted does not have any g2 (arc) commands - the code is not carving a true circle but is approximating it with a series of short line segments. MACH 3 understands arc commands, and this may lead to cleaner results. In Fusion 360, use the “Mach3 arcs” post processor.
    I think the conversion to dxf and import into Aspire may be altering your geometry slightly, exacerbating any issues.
    Tubular latex pressure vessel configuration engineer
  1. My parts are coming out the wrong size!
    By bremerr in forum DIY CNC Router Table Machines
    Last Post: 12-18-2015, 04:43 PM
  2. Holes not coming out correct size
    By dwessels in forum Benchtop Machines
    Last Post: 11-28-2011, 06:36 PM
  3. How do I make CAD/CAM size match machined size?
    By RedCoder in forum Benchtop Machines
    Last Post: 12-07-2010, 11:13 PM
  4. circles arent circles
    By xlr8r in forum DynaTorch
    Last Post: 01-18-2009, 06:26 PM
  5. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
