586,042 active members*
3,874 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Triple Play Solid State Limit Switch Noise Filter
Results 1 to 1 of 1
    Aug 2016
    7
    I have had issues off and on with VFD noise coupling onto my limit switches and causing false trips on the inputs. I have used software filtering with some success and also a relay voltage level conversion circuit. But I wanted something more robust. Long story short, I built a solid state filtering board that eliminates noise three ways:
    1. High voltage (24V) is used for all switch and input wiring. The 24V signaling is then attenuated down to 5V before being passed through step 2 below. The 24V to 5V conversion reduces all signals, including noise, by about 80%.
    2. Low pass filter slows down the signal edge and eliminates all high frequency noise
    3. Schmitt trigger buffering cleans up non-monotonic signal edges to prevent multiple triggers and produce a crisp clean signal. Using shmitt triggers instead of relays means no moving parts to fail over time.
    The circuit logics, calculations, BOM, board, and some scope shots are included. I may do a PCB later to clean things up.
    -Enjoy!
    Attached Thumbnails Attached Thumbnails LimitSwitchFilter-Ckt.jpg   LimitSwitchFilter-BOM.jpg   FilterBoard-Front.jpg   FilterBoard-Back.jpg
  1. Limit switch noise: Optocoupler, 12v, 24v?
    By Biggs427 in forum CNC Machine Related Electronics
    Last Post: 09-06-2023, 07:38 AM
  2. solid state prox switch question
    By xkadet in forum CNC Machine Related Electronics
    Last Post: 03-07-2013, 12:30 AM
  3. multiple solid state home/limit switches on one input
    By will gilmore in forum CNC Machine Related Electronics
    Last Post: 01-27-2010, 06:39 PM
  4. Solid-State limit switch experiment
    By Swede in forum CNC Machine Related Electronics
    Last Post: 01-08-2010, 08:20 PM
  5. Solid state limit switches
    Last Post: 01-04-2004, 01:22 AM
