586,597 active members*
3,394 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Need Solid Modelling Help
    Apr 2017
    New to Gibbscam. Using 2016. What I am attempting to do is to revolve some geometry that I have imported from AutoCAD LT 2017. The part is cylindrical. I am able to select the geometry on the imported drawing and "Revolve" it, creating a single solid cylindrical object that looks pretty close. My issue is that I don't know how to create the part with an inside diameter also, as opposed to it being a complete solid. I would like, when I "Revolve", for the inside diameter to be established as well as the outside. Im fairly certain that there is something that I am not doin correctly. Any help would be appreciated.
    May 2006
    803
    Re: Need Solid Modelling Help
    If you have solids just define the circle which represents the bore and extrude thru to remove it.
    Apr 2017
    Thank you Bostosh. Would I able to accomplish ID threads using a similar method?
    May 2006
    803
    Do the tap drill thru then,
    I go to a CAD site which has the bolt and fasteners CAD modeled,
    and download the solid then subtract it from you other model.
    Are you doing single point threading or ? do you need a specific thread size?
    Been doing this too long
  1. Looking for a 3D Modelling Package
    By pbd1971 in forum Uncategorised CAD Discussion
    Last Post: 10-05-2011, 05:35 PM
  2. Which drawing/solid modelling package
    By fitzpatrick2362 in forum Uncategorised CAM Discussion
    Last Post: 03-07-2011, 05:20 AM
  3. PRS modelling
    By betterfly in forum Musical Instrument Design and Construction
    Last Post: 08-13-2008, 10:00 PM
  4. Learning 3D modelling
    By randyf1965 in forum Uncategorised CAD Discussion
    Last Post: 01-12-2006, 01:27 PM
