Re: Okuma M 560 - 1192-07 Alarm- A MCS Motor overload A-Axis 5BB05CE - code on screen
Are you sure is isn't something stupid like leaving the brake on while positioning? Or output for brake is backwards so that brake on while positioning and off while stationary? How do you determine that setting is too low? Are you watching the load for the a axis and if so what values do you have when rotating?
Usually the overload is because current draw is high and will reset after motor cools back down. Is there any mechanical binding?
Best regards,
Experience is what you get just after you needed it.
